RTEMS 6.1-rc2
rtems.h
2
11/*
12 * Copyright (C) 2020 embedded brains GmbH & Co. KG
13 * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
14 *
16 * modification, are permitted provided that the following conditions
17 * are met:
18 * 1. Redistributions of source code must retain the above copyright
19 * notice, this list of conditions and the following disclaimer.
20 * 2. Redistributions in binary form must reproduce the above copyright
21 * notice, this list of conditions and the following disclaimer in the
22 * documentation and/or other materials provided with the distribution.
23 *
24 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34 * POSSIBILITY OF SUCH DAMAGE.
35 */
36
37/*
38 * This file is part of the RTEMS quality process and was automatically
39 * generated. If you find something that needs to be fixed or
40 * worded better please post a report or patch to an RTEMS mailing list
41 * or raise a bug report:
42 *
43 * https://www.rtems.org/bugs.html
44 *
45 * For information on updating and regenerating please refer to the How-To
46 * section in the Software Requirements Engineering chapter of the
47 * RTEMS Software Engineering manual. The manual is provided as a part of
48 * a release. For development sources please refer to the online
49 * documentation at:
50 *
51 * https://docs.rtems.org
52 */
53
54/* Generated from spec:/rtems/if/header */
55
56#ifndef _RTEMS_H
57#define _RTEMS_H
58
59#include <rtems/config.h>
60#include <rtems/extension.h>
61#include <rtems/fatal.h>
62#include <rtems/init.h>
63#include <rtems/io.h>
64#include <rtems/rtems/barrier.h>
65#include <rtems/rtems/cache.h>
66#include <rtems/rtems/clock.h>
67#include <rtems/rtems/dpmem.h>
68#include <rtems/rtems/event.h>
69#include <rtems/rtems/intr.h>
70#include <rtems/rtems/message.h>
71#include <rtems/rtems/object.h>
72#include <rtems/rtems/options.h>
73#include <rtems/rtems/part.h>
74#include <rtems/rtems/ratemon.h>
75#include <rtems/rtems/region.h>
77#include <rtems/rtems/sem.h>
78#include <rtems/rtems/signal.h>
79#include <rtems/rtems/status.h>
80#include <rtems/rtems/support.h>
81#include <rtems/rtems/tasks.h>
82#include <rtems/rtems/timer.h>
83#include <rtems/rtems/types.h>
84
85#if defined(RTEMS_MULTIPROCESSING)
86 #include <rtems/rtems/mp.h>
87#endif
88
89#ifdef __cplusplus
90extern "C" {
91#endif
92
93/* Generated from spec:/rtems/if/group */
94
103#ifdef __cplusplus
104}
105#endif
106
107#endif /* _RTEMS_H */
This header file defines the Barrier Manager API.
This header file defines the Fatal Error Manager API.
This header file defines the IO Manager API.
This header file defines the Cache Manager API.
This header file defines the Clock Manager API.
This header file provides the Timer Manager API.
This header file provides types used by the Classic API.
This header file defines the Dual-Ported Memory Manager API.
This header file defines the User Extensions Manager API.
This header file defines the parts of the Signal Manager API.
This header file defines the Initialization Manager API.
This header file defines the Interrupt Manager API.
This header file defines the Message Manager API.
This header file defines the Multiprocessing Manager API.
This header file provides the Classic API directive options.
This header file provides the Partition Manager API.
This header file defines the Rate-Monotonic Manager API.
This header file defines the Region Manager API.
This header file provides the Object Services API.
This header file provides the Event Manager API.
This header file defines the main parts of the Scheduler Manager API.
This header file provides the status codes of Classic API directives and support functions.
This header file defines the Semaphore Manager API.
This header file defines support services of the API.
This header file defines the main parts of the Tasks Manager API.
