RTEMS 6.1-rc2
This header file provides the interfaces of the Time of Day Handler and the Time of Day Handler Action Hooks. More...
#include <rtems/score/status.h>
#include <rtems/score/timestamp.h>
#include <rtems/score/timecounterimpl.h>
#include <rtems/score/watchdogticks.h>
#include <sys/time.h>
#include <time.h>
struct | TOD_Control |
TOD control. More... | |
struct | TOD_Hook |
Structure to manage each TOD action hook. More... | |
#define | TOD_SECONDS_PER_MINUTE (uint32_t)60 |
#define | TOD_MINUTES_PER_HOUR (uint32_t)60 |
#define | TOD_MONTHS_PER_YEAR (uint32_t)12 |
#define | TOD_DAYS_PER_YEAR (uint32_t)365 |
#define | TOD_HOURS_PER_DAY (uint32_t)24 |
#define | TOD_SECONDS_PER_DAY |
#define | TOD_SECONDS_PER_NON_LEAP_YEAR (365 * TOD_SECONDS_PER_DAY) |
#define | TOD_MILLISECONDS_PER_SECOND (uint32_t)1000 |
#define | TOD_MICROSECONDS_PER_SECOND (uint32_t)1000000 |
#define | TOD_NANOSECONDS_PER_SECOND (uint32_t)1000000000 |
#define | TOD_NANOSECONDS_PER_MICROSECOND (uint32_t)1000 |
#define | TOD_SECONDS_1970_THROUGH_1988 |
#define | TOD_SECONDS_1970_THROUGH_2400 13569465600 |
Seconds from 1970-01-01T00:00:00Z to 2400-01-01T00:00:00Z. | |
#define | TOD_BASE_YEAR 1988 |
Earliest year to which an time of day can be initialized. | |
#define | TOD_LATEST_YEAR 2099 |
Latest year to which a time of day can be initialized. | |
#define | TOD_TICKS_PER_SECOND _Watchdog_Ticks_per_second |
Gets number of ticks in a second. | |
Typedefs | |
typedef struct TOD_Hook | TOD_Hook |
Structure to manage each TOD action hook. | |
Enumerations | |
enum | TOD_Action { TOD_ACTION_SET_CLOCK } |
Possible actions where a registered hook could be invoked. More... | |
void | _TOD_Lock (void) |
Locks the time of day mutex. | |
void | _TOD_Unlock (void) |
Unlocks the time of day mutex. | |
Status_Control | _TOD_Is_valid_new_time_of_day (const struct timespec *tod) |
Checks the time point is a valid new time of day for _TOD_Set(). | |
Status_Control | _TOD_Set (const struct timespec *tod, ISR_lock_Context *lock_context) |
Sets the time of day. | |
void | _TOD_Hook_Register (TOD_Hook *hook) |
Add a TOD Action Hook. | |
void | _TOD_Hook_Unregister (TOD_Hook *hook) |
Remove a TOD Action Hook. | |
Status_Control | _TOD_Hook_Run (TOD_Action action, const struct timespec *tod) |
Run the TOD Action Hooks. | |
TOD_Control | _TOD |
TOD Management information. | |
const uint16_t | _TOD_Days_to_date [2][13] |
This array contains the number of days in all months up to the month indicated by the index of the second dimension. | |
Chain_Control | _TOD_Hooks |
Set of registered methods for TOD Actions. | |
#define TOD_BASE_YEAR 1988 |
The following constant define the earliest year to which an time of day can be initialized. This is considered the epoch.
#define TOD_LATEST_YEAR 2099 |
The following constant defines the latest year to which an RTEMS time of day can be set using rtems_clock_set().
32 bits can accept as latest point in time 2106-Feb-7 6:28:15 but to simplify the implementation, is was decided to only check that the year is not greater than the year of this constant. The year 2099 was chosen because all years evenly divisible by 4 from 1988 to 2099 are leap years. In this time frame, years evenly divisible by 100 are no leap years unless they are evenly divisible by 400. Thus the year 2000 is a leap year.
The internal CLOCK_REALTIME can run centuries longer but in contrast to the POSIX API, the RTEMS Classic API does not support this for efficiency reasons.
#define TOD_SECONDS_1970_THROUGH_1988 |
Seconds from January 1, 1970 to January 1, 1988. Used to account for differences between POSIX API and RTEMS core. The timespec format time is kept in POSIX compliant form.
#define TOD_SECONDS_1970_THROUGH_2400 13569465600 |
This is the latest time of day which should be set by _TOD_Set(). The year 2400 was chosen to guarantee a defined CLOCK_REALTIME within the range of a system uptime of about 114 years.
