RTEMS
6.1-rc2
include
score
timecounterimpl.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (c) 2015 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_TIMECOUNTERIMPL_H
38
#define _RTEMS_SCORE_TIMECOUNTERIMPL_H
39
40
rtems/score/timecounter.h
41
sys/timetc.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
/* __cplusplus */
46
59
void
_Timecounter_Set_clock
60
const
struct
bintime *bt,
61
ISR_lock_Context
*lock_context
62
63
66
#ifdef __cplusplus
67
68
#endif
/* __cplusplus */
69
70
#endif
/* _RTEMS_SCORE_TIMECOUNTERIMPL_H */
void _Timecounter_Set_clock(const struct bintime *bt, ISR_lock_Context *lock_context)
Sets the timecounter clock to the given value.
timecounter.h
This header file provides interfaces of the Timecounter Handler which are used by the implementation ...
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition:
isrlock.h:81
timetc.h
This header file provides interfaces of the timecounter implementation.
