RTEMS 6.1-rc2
tasks.h File Reference
This header file defines the main parts of the Tasks Manager API. More...
#include <stdbool.h>
#include <stddef.h>
#include <stdint.h>
#include <sys/cpuset.h>
#include <rtems/rtems/attr.h>
#include <rtems/rtems/modes.h>
#include <rtems/score/context.h>
#include <rtems/score/cpu.h>
#include <rtems/score/stack.h>
#include <rtems/score/watchdogticks.h>
struct  rtems_task_config
 This structure defines the configuration of a task constructed by rtems_task_construct(). More...
struct  rtems_initialization_tasks_table
 This structure defines the properties of the Classic API user initialization task. More...
#define RTEMS_CONFIGURED_MINIMUM_STACK_SIZE   0
 This constant can be used to indicate that the task should be created with the configured minimum stack size.
#define RTEMS_CURRENT_PRIORITY   0
 This constant is passed to rtems_task_set_priority() when the caller wants to obtain the current priority.
#define RTEMS_MAXIMUM_PRIORITY   _RTEMS_Maximum_priority()
 This runtime constant represents the lowest (least important) task priority of the scheduler with index zero.
#define RTEMS_MINIMUM_PRIORITY   1
 This compile time constant provides the highest (most important) task priority settable by the API.
#define RTEMS_MINIMUM_STACK_SIZE   STACK_MINIMUM_SIZE
 This compile time constant provides the minimum task stack size recommended for the target architecture.
#define RTEMS_NO_PRIORITY   RTEMS_CURRENT_PRIORITY
 This compile time constant may be used for the rtems_task_set_priority() directive to get the current task priority.
#define RTEMS_SELF   OBJECTS_ID_OF_SELF
 This compile time constant may be used to identify the calling task in task related directives.
#define RTEMS_TASK_STORAGE_ALIGNMENT   CPU_STACK_ALIGNMENT
 This compile time constant defines the recommended alignment of a task storage area in bytes.
#define RTEMS_TASK_STORAGE_SIZE(_size, _attributes)    ( ( _size ) + CONTEXT_FP_SIZE )
 Gets the recommended task storage area size for the size and task attributes.
#define RTEMS_YIELD_PROCESSOR   WATCHDOG_NO_TIMEOUT
 This compile time constant may be passed to the rtems_task_wake_after() directive as the interval when a task wishes to yield the processor.
typedef CPU_Uint32ptr rtems_task_argument
 This integer type represents task argument values.
typedef void rtems_task
 This type defines the return type of task entry points.
typedef rtems_task(* rtems_task_entry) (rtems_task_argument)
 This type defines the task entry point of an RTEMS task.
typedef struct _Thread_Control rtems_tcb
 This structure represents the TCB.
typedef bool(* rtems_task_visitor) (rtems_tcb *, void *)
 Visitor routines invoked by rtems_task_iterate() shall have this type.
rtems_task_priority _RTEMS_Maximum_priority (void)
 Returns the maximum priority of the scheduler with index zero.
rtems_status_code rtems_task_create (rtems_name name, rtems_task_priority initial_priority, size_t stack_size, rtems_mode initial_modes, rtems_attribute attribute_set, rtems_id *id)
 Creates a task.
rtems_status_code rtems_task_construct (const rtems_task_config *config, rtems_id *id)
 Constructs a task from the specified task configuration.
rtems_status_code rtems_task_ident (rtems_name name, uint32_t node, rtems_id *id)
 Identifies a task by the object name.
rtems_id rtems_task_self (void)
 Gets the task identifier of the calling task.
rtems_status_code rtems_task_start (rtems_id id, rtems_task_entry entry_point, rtems_task_argument argument)
 Starts the task.
rtems_status_code rtems_task_restart (rtems_id id, rtems_task_argument argument)
 Restarts the task.
rtems_status_code rtems_task_delete (rtems_id id)
 Deletes the task.
RTEMS_NO_RETURN void rtems_task_exit (void)
 Deletes the calling task.
rtems_status_code rtems_task_suspend (rtems_id id)
 Suspends the task.
rtems_status_code rtems_task_resume (rtems_id id)
 Resumes the task.
rtems_status_code rtems_task_is_suspended (rtems_id id)
 Checks if the task is suspended.
rtems_status_code rtems_task_set_priority (rtems_id id, rtems_task_priority new_priority, rtems_task_priority *old_priority)
 Sets the real priority or gets the current priority of the task.
rtems_status_code rtems_task_get_priority (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority *priority)
 Gets the current priority of the task with respect to the scheduler.
rtems_status_code rtems_task_mode (rtems_mode mode_set, rtems_mode mask, rtems_mode *previous_mode_set)
 Gets and optionally sets the mode of the calling task.
rtems_status_code rtems_task_wake_after (rtems_interval ticks)
 Wakes up after a count of clock ticks have occurred or yields the processor.
rtems_status_code rtems_task_wake_when (const rtems_time_of_day *time_buffer)
 Wakes up when specified.
rtems_status_code rtems_task_get_scheduler (rtems_id task_id, rtems_id *scheduler_id)
 Gets the home scheduler of the task.
rtems_status_code rtems_task_set_scheduler (rtems_id task_id, rtems_id scheduler_id, rtems_task_priority priority)
 Sets the home scheduler for the task.
rtems_status_code rtems_task_get_affinity (rtems_id id, size_t cpusetsize, cpu_set_t *cpuset)
 Gets the processor affinity of the task.
rtems_status_code rtems_task_set_affinity (rtems_id id, size_t cpusetsize, const cpu_set_t *cpuset)
 Sets the processor affinity of the task.
void rtems_task_iterate (rtems_task_visitor visitor, void *arg)
 Iterates over all tasks and invokes the visitor routine for each task.
