RTEMS 6.1-rc2
systemeventsend.c File Reference
This source file contains the implementation of rtems_event_system_send(). More...
#include <rtems/rtems/eventimpl.h>
#include <rtems/rtems/tasksdata.h>
rtems_status_code rtems_event_system_send (rtems_id id, rtems_event_set event_in)
 Sends the system event set to the task.
◆ rtems_event_system_send()
rtems_status_code rtems_event_system_send ( rtems_id  id,
Parameters
idis the identifier of the target task to receive the event set.
event_inis the event set to send.
Constraints
The following constraints apply to this directive:
  • The directive may be called from within interrupt context.
  • The directive may be called from within device driver initialization context.
  • The directive may be called from within task context.
  • The directive may unblock a task. This may cause the calling task to be preempted.
