RTEMS 6.1-rc2
tasksdata.h
2
14/*
15 * COPYRIGHT (c) 1989-2014.
16 * On-Line Applications Research Corporation (OAR).
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_RTEMS_TASKSDATA_H
41#define _RTEMS_RTEMS_TASKSDATA_H
42
43#include <rtems/rtems/tasks.h>
44#include <rtems/rtems/asrdata.h>
46#include <rtems/score/thread.h>
47
48#ifdef __cplusplus
49extern "C" {
50#endif
51
63typedef struct {
70
76
84
91
96typedef struct {
102
107
113
122
129
135
138#ifdef __cplusplus
139}
140#endif
141
142#endif
143/* end of include file */
This header file provides data structures used by the implementation and the Application Configuratio...
rtems_task(* rtems_task_entry)(rtems_task_argument)
This type defines the task entry point of an RTEMS task.
Definition: tasks.h:239
CPU_Uint32ptr rtems_task_argument
This integer type represents task argument values.
Definition: tasks.h:100
const rtems_initialization_tasks_table _RTEMS_tasks_User_task_table
Initialization table for the first user task.
Definition: taskinitdefault.c:43
Thread_Information _RTEMS_tasks_Information
void _RTEMS_tasks_Construct_user_task(void)
Constructs and starts the Classic API initialization task using rtems_task_construct() and the config...
Definition: taskconstructuser.c:46
void _RTEMS_tasks_Initialize_user_task(void)
Creates and starts the Classic API initialization task using rtems_task_create() and the configuratio...
Definition: taskinitusers.c:47
const RTEMS_tasks_User_task_config _RTEMS_tasks_User_task_config
This structure provides the configuration of the Classic API initialization task.
This header file provides interfaces of the Thread Handler which are used by the implementation and t...
Definition: asrdata.h:57
This structure is used to manage a set of events.
Definition: eventdata.h:56
Definition: tasksdata.h:63
Thread_Action Signal_action
Signal post-switch action in case signals are pending.
Definition: tasksdata.h:74
Event_Control Event
Definition: tasksdata.h:65
ASR_Information Signal
Definition: tasksdata.h:69
Event_Control System_event
Definition: tasksdata.h:67
This structure provides the configuration to construct and start the Classic API initialization task.
Definition: tasksdata.h:96
rtems_task_config config
This member provides the task configuration for rtems_task_construct().
Definition: tasksdata.h:101
rtems_task_entry entry_point
This member provides the task entry point for rtems_task_start().
Definition: tasksdata.h:106
rtems_task_argument argument
This member provides the task argument for rtems_task_start().
Definition: tasksdata.h:111
Thread action.
Definition: thread.h:681
The thread object information.
Definition: thread.h:1098
This structure defines the properties of the Classic API user initialization task.
Definition: tasks.h:249
This structure defines the configuration of a task constructed by rtems_task_construct().
Definition: tasks.h:110
This header file defines the main parts of the Tasks Manager API.
