RTEMS 6.1-rc2
systemeventreceive.c File Reference
This source file contains the implementation of rtems_event_system_receive(). More...
#include <rtems/rtems/eventimpl.h>
#include <rtems/rtems/tasksdata.h>
rtems_status_code rtems_event_system_receive (rtems_event_set event_in, rtems_option option_set, rtems_interval ticks, rtems_event_set *event_out)
 Receives or gets a system event set from the executing task.
◆ rtems_event_system_receive()
rtems_status_code rtems_event_system_receive ( rtems_event_set  event_in,
rtems_event_set event_out
Parameters
event_inis the event set of interest. Use RTEMS_PENDING_EVENTS to get the pending events.
option_setis the option set.
ticksis the timeout in clock ticks if the RTEMS_WAIT option was set. Use RTEMS_NO_TIMEOUT to wait potentially forever.
event_outis the pointer to an event set. The received or pending events are stored in the referenced event set if the operation was successful.
This directive performs the same actions as the rtems_event_receive() directive except that it operates with a different set of events for each task.
Constraints
The following constraints apply to this directive:
  • The directive may be called from within device driver initialization context.
  • The directive may be called from within task context.
  • The timeout functionality of the directive requires a clock tick.
