RTEMS 6.1-rc2
u8 __attribute__::AddrCycles |
Number of address cycles
u8 __attribute__::BitsPerCell |
Number of bits per cell
u16 __attribute__::BlockEndurance |
Block endurance
u16 __attribute__::BlockEnduranceGVB |
Block endurance for guaranteed valid block
u32 __attribute__::BlocksPerLun |
Number of blocks per LUN
u32 __attribute__::BytesPerPage |
Number of data bytes per page
u32 __attribute__::BytesPerPartialPage |
Number of data bytes per partial page
u16 __attribute__::ClkInputPinCap |
CLK input pin capacitance
u16 __attribute__::Crc |
Integrity CRC
u8 __attribute__::DateCode[2] |
Date code
u8 __attribute__::DeviceManufacturer[12] |
Device manufacturer
u8 __attribute__::DeviceModel[20] |
Device model
u8 __attribute__::DrvStrength |
Driver strength support
u8 __attribute__::EccBits |
Number of bits ECC correctability
u16 __attribute__::ExtParamPageLen |
Extended Parameter Page Length
u8 __attribute__::EzNandSupport |
EZ NAND support
u16 __attribute__::Features |
Features supported
u8 __attribute__::GuaranteedValidBlock |
Guaranteed valid blocks at beginning of target
u16 __attribute__::InputPinCap |
Input pin capacitance typical
u8 __attribute__::InputPinCapMax |
Input pin capacitance maximum
u16 __attribute__::IOPinCap |
I/O pin capacitance
u8 __attribute__::IOPinCapacitance |
I/O pin capacitance, maximum
u8 __attribute__::JedecJtgPrmAdvCmd |
ONFI JEDEC JTG primary advanced command support
u8 __attribute__::JedecManufacturerId |
JEDEC Manufacturer ID
u16 __attribute__::MaxBadBlocksPerLun |
Bad blocks maximum per LUN
u8 __attribute__::NumLuns |
Number of LUN's
u8 __attribute__::NumOfParamPages |
Number of Parameter Pages
u8 __attribute__::NVDDR2Features |
NVDDR2 Features
u8 __attribute__::NVDDR2TimingMode |
NVDDR2 timing mode support
u8 __attribute__::NVDDR2WarmupCycles |
NVDDR2 Warmup Cycles
u8 __attribute__::NVDDRTimingMode |
NVDDR timing mode support
u16 __attribute__::OptionalCmds |
Optional commands supported
u32 __attribute__::PagesPerBlock |
Number of pages per block
u8 __attribute__::PartialProgAttr |
Partial programming attributes
u8 __attribute__::PlaneAddrBits |
Number of plane address bits
u8 __attribute__::PlaneOperationAttr |
Multi-plane operation attributes
u8 __attribute__::ProgramsPerPage |
Number of programs per page
u8 __attribute__::Reserved0 |
Reserved (11)
u8 __attribute__::Reserved1 |
Reserved (15-31)
u8 __attribute__::Reserved2[13] |
Reserved (67-79)
u8 __attribute__::Reserved3[12] |
Reserved (116 - 127)
u8 __attribute__::Reserved4[4] |
Reserved (160 - 163)
u16 __attribute__::Revision |
Revision Number
u16 __attribute__::SDRPagecacheTimingMode |
SDR Program cache timing mode
u16 __attribute__::SDRTimingMode |
SDR Timing mode support
u8 __attribute__::Signature[4] |
Parameter page signature
u16 __attribute__::SpareBytesPerPage |
Number of spare bytes per page
u16 __attribute__::SpareBytesPerPartialPage |
Number of spare bytes per partial page
u8 __attribute__::SynFeatures |
NVDDR/NVDDR2 features
u16 __attribute__::TAdl |
Program page register clear enhancement value
u16 __attribute__::TBers |
Maximum block erase time
u16 __attribute__::TCcs |
Maximum change column setup time
u16 __attribute__::TEr |
Typical page read time for EZ NAND
u16 __attribute__::TMr |
Maximum multi-plane read time
u16 __attribute__::TProg |
Maximum page program time
u16 __attribute__::TR |
Maximum page read time
u16 __attribute__::VendorRevisionNum |
Vendor specific revision number
u8 __attribute__::VendorSpecific[88] |
Vendor specific
