RTEMS 6.1-rc2
The CPU usage reporting directives can be used to report and reset the CPU usage of threads. More...
Files | |
file | cpuuse.h |
This header file provides the CPU usage reporting API. | |
int | rtems_cpu_info_report (const struct rtems_printer *printer) |
Reports the CPU information using the printer plugin. | |
void | rtems_cpu_usage_report (void) |
Reports the CPU usage of each thread using the printk() printer. | |
void | rtems_cpu_usage_report_with_plugin (const struct rtems_printer *printer) |
Reports the CPU usage of each thread using the printer plugin. | |
void | rtems_cpu_usage_reset (void) |
Resets the CPU usage of each thread. | |
void | rtems_cpu_usage_top (void) |
Starts an interactive CPU usage reporting using the printk() printer. | |
void | rtems_cpu_usage_top_with_plugin (const struct rtems_printer *printer) |
Starts an interactive CPU usage reporting using the printer plugin. | |
int rtems_cpu_info_report | ( | const struct rtems_printer * | printer | ) |
printer | is the printer plugin to output the report. |
The following constraints apply to this directive:
void rtems_cpu_usage_report | ( | void | ) |
void rtems_cpu_usage_report_with_plugin | ( | const struct rtems_printer * | printer | ) |
void rtems_cpu_usage_reset | ( | void | ) |
void rtems_cpu_usage_top | ( | void | ) |
void rtems_cpu_usage_top_with_plugin | ( | const struct rtems_printer * | printer | ) |
