RTEMS 6.1-rc2
Header file of UTILS LL module. More...
struct | LL_UTILS_PLLInitTypeDef |
UTILS PLL structure definition. More... | |
struct | LL_UTILS_ClkInitTypeDef |
UTILS System, AHB and APB buses clock configuration structure definition. More... | |
#define | LL_MAX_DELAY 0xFFFFFFFFU |
#define | UID_BASE_ADDRESS UID_BASE |
Unique device ID register base address. | |
#define | FLASHSIZE_BASE_ADDRESS FLASHSIZE_BASE |
Flash size data register base address. | |
#define | PACKAGE_BASE_ADDRESS PACKAGE_BASE |
Package data register base address. | |
#define | LL_UTILS_HSEBYPASS_OFF 0x00000000U |
#define | LL_UTILS_HSEBYPASS_ON 0x00000001U |
__STATIC_INLINE uint32_t | LL_GetUID_Word0 (void) |
Get Word0 of the unique device identifier (UID based on 96 bits) | |
__STATIC_INLINE uint32_t | LL_GetUID_Word1 (void) |
Get Word1 of the unique device identifier (UID based on 96 bits) | |
__STATIC_INLINE uint32_t | LL_GetUID_Word2 (void) |
Get Word2 of the unique device identifier (UID based on 96 bits) | |
__STATIC_INLINE uint32_t | LL_GetFlashSize (void) |
Get Flash memory size. | |
__STATIC_INLINE uint32_t | LL_GetPackageType (void) |
Get Package type. | |
__STATIC_INLINE void | LL_InitTick (uint32_t HCLKFrequency, uint32_t Ticks) |
This function configures the Cortex-M SysTick source of the time base. | |
void | LL_Init1msTick (uint32_t CPU_Frequency) |
This function configures the Cortex-M SysTick source to have 1ms time base. | |
void | LL_mDelay (uint32_t Delay) |
This function provides accurate delay (in milliseconds) based on SysTick counter flag. | |
void | LL_SetSystemCoreClock (uint32_t CPU_Frequency) |
This function sets directly SystemCoreClock CMSIS variable. | |
ErrorStatus | LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
This function configures system clock at maximum frequency with HSI as clock source of the PLL. | |
ErrorStatus | LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
This function configures system clock with HSE as clock source of the PLL. | |
ErrorStatus | LL_SetFlashLatency (uint32_t HCLK_Frequency) |
Update number of Flash wait states in line with new frequency and current voltage range. | |
============================================================================== ##### How to use this driver ##### ============================================================================== [..] The LL UTILS driver contains a set of generic APIs that can be used by user: (+) Device electronic signature (+) Timing functions (+) PLL configuration functions
