RTEMS 6.1-rc2
qspi_dma.h File Reference
#include "chip.h"
#include "../../../../utils/utility.h"
struct  _Qspid
#define QSPID_ERROR   1
#define QSPID_ERROR_LOCK   2
#define QSPID_CH_NOT_ENABLED   0xFF
typedef void(* QspidCallback) (uint8_t, void *)
typedef struct _Qspid QspiDma_t
uint32_t QSPID_Configure (QspiDma_t *pQspidma, QspiMode_t Mode, uint32_t dwConfiguration, sXdmad *pXdmad)
 Initializes the pQspidma structure and the corresponding QSPI & DMA . hardware select value.
uint32_t QSPID_EnableQspiRxChannel (QspiDma_t *pQspidma)
 Enables a QSPI Rx channel. This function will allocate a dma Rx channel for QSPI.
uint32_t QSPID_EnableQspiTxChannel (QspiDma_t *pQspidma)
 Enables a QSPI Tx channel. This function will allocate a dma Tx channel for QSPI.
uint32_t QSPID_DisableQspiRxChannel (QspiDma_t *pQspidma)
 Disables a QSPI Rx channel. This function will de-allocate previous allocated dma Rx channel for QSPI.
uint32_t QSPID_DisableQspiTxChannel (QspiDma_t *pQspidma)
 Disables a QSPI Tx channel. This function will de-allocate previous allocated dma Tx channel for QSPI.
uint32_t QSPID_DisableSpiChannel (QspiDma_t *pQspidma)
 Disables a QSPI SPI Rx and Tx channels. This function will de-allocate privious allocated dma Rx, Txchannel for QSPI in SPI mode.
uint32_t QSPID_EnableSpiChannel (QspiDma_t *pQspidma)
 Enables a QSPI SPI Rx channel. This function will allocate a dma Rx channel for QSPI SPI mode.
uint32_t QSPID_ReadWriteQSPI (QspiDma_t *pQspidma, Access_t const ReadWrite)
 Starts a QSPI read or write operation.
uint32_t QSPID_ReadWriteSPI (QspiDma_t *pQspidma, Access_t const ReadWrite)
 Starts a SPI master transfer. This is a non blocking function. It will return as soon as the transfer is started.
uint32_t QSPID_IsBusy (volatile uint8_t *QspiSemaphore)
 Check if the QSPI driver is busy.
Implementation of SPI driver, transfer data through DMA.
◆ QSPID_ERROR
An unspecified error has occurred.
◆ QSPID_ERROR_LOCK
SPI driver is currently in use.
Typedef Documentation
◆ QspidCallback
SPI transfer complete callback.
◆ QspiDma_t
Constant structure associated with SPI port. This structure prevents client applications to have access in the same time.
◆ QSPID_Configure()
uint32_t QSPID_Configure ( QspiDma_t pQspidma,
QspiMode_t  Mode,
uint32_t  dwConf,
sXdmad pXdmad
Parameters
pQspidmaPointer to a QspiDma_t instance.
ModeAssociated SPI peripheral.
dwConfQSPI peripheral configuration.
pXdmadPointer to a Xdmad instance.
◆ QSPID_DisableQspiRxChannel()
uint32_t QSPID_DisableQspiRxChannel ( QspiDma_t pQspidma)
Parameters
pQspidmaPointer to a Spid instance.
Returns
0 if the transfer has been started successfully; otherwise returns QSPID_ERROR_LOCK is the driver is in use, or QSPID_ERROR if the command is not valid.
◆ QSPID_DisableQspiTxChannel()
uint32_t QSPID_DisableQspiTxChannel ( QspiDma_t pQspidma)
Parameters
Returns
◆ QSPID_DisableSpiChannel()
uint32_t QSPID_DisableSpiChannel ( QspiDma_t pQspidma)
Parameters
Returns
◆ QSPID_EnableQspiRxChannel()
uint32_t QSPID_EnableQspiRxChannel ( QspiDma_t pQspidma)
Parameters
Returns
◆ QSPID_EnableQspiTxChannel()
uint32_t QSPID_EnableQspiTxChannel ( QspiDma_t pQspidma)
Parameters
Returns
◆ QSPID_EnableSpiChannel()
uint32_t QSPID_EnableSpiChannel ( QspiDma_t pQspidma)
Parameters
Returns
◆ QSPID_IsBusy()
uint32_t QSPID_IsBusy ( volatile uint8_t *  QspiSemaphore)
Parameters
pSpidPointer to a Spid instance.
Returns
1 if the SPI driver is currently busy executing a command; otherwise
◆ QSPID_ReadWriteQSPI()
uint32_t QSPID_ReadWriteQSPI ( QspiDma_t pQspidma,
Parameters
pQspidmaPointer to a Qspid instance.
ReadWriteDefines the memory access type
Returns
◆ QSPID_ReadWriteSPI()
uint32_t QSPID_ReadWriteSPI ( QspiDma_t pQspidma,
Parameters
pCommandPointer to the SPI command to execute.
Returns
0 if the transfer has been started successfully; otherwise returns SPID_ERROR_LOCK is the driver is in use, or SPID_ERROR if the command is not valid.
