RTEMS 6.1-rc2
Data Structures | Typedefs | Enumerations
struct  _XdmadChannel
struct  _Xdmad
struct  _XdmadCfg
struct  _LinkedListDescriporView0
 Structure for storing parameters for DMA view0 that can be performed by the DMA Master transfer. More...
struct  _LinkedListDescriporView1
 Structure for storing parameters for DMA view1 that can be performed by the DMA Master transfer. More...
struct  _LinkedListDescriporView2
 Structure for storing parameters for DMA view2 that can be performed by the DMA Master transfer. More...
struct  _LinkedListDescriporView3
 Structure for storing parameters for DMA view3 that can be performed by the DMA Master transfer. More...
typedef enum _XdmadStatus eXdmadStatus
typedef enum _XdmadStatus eXdmadRC
typedef enum _XdmadState eXdmadState
typedef enum _XdmadProgState eXdmadProgState
typedef void(* XdmadTransferCallback) (uint32_t Channel, void *pArg, uint32_t status)
typedef struct _XdmadChannel sXdmadChannel
typedef struct _Xdmad sXdmad
typedef struct _XdmadCfg sXdmadCfg
typedef struct _LinkedListDescriporView0 LinkedListDescriporView0
typedef struct _LinkedListDescriporView1 LinkedListDescriporView1
typedef struct _LinkedListDescriporView2 LinkedListDescriporView2
typedef struct _LinkedListDescriporView3 LinkedListDescriporView3
enum  _XdmadStatus {
  XDMAD_OK = 0 , XDMAD_PARTIAL_DONE , XDMAD_DONE , XDMAD_BUSY ,
  XDMAD_ERROR , XDMAD_CANCELED
enum  _XdmadState {
  XDMAD_STATE_FREE = 0 , XDMAD_STATE_ALLOCATED , XDMAD_STATE_START , XDMAD_STATE_IN_XFR ,
  XDMAD_STATE_DONE , XDMAD_STATE_HALTED
enum  _XdmadProgState { XDMAD_SINGLE = 0 , XDMAD_MULTI , XDMAD_LLI }
Typedef Documentation
◆ eXdmadProgState
DMA Programming state for channel
◆ eXdmadState
DMA state for channel
◆ eXdmadStatus
DMA status or return code
◆ sXdmad
DMA driver instance
◆ sXdmadChannel
DMA driver channel
◆ XdmadTransferCallback
DMA transfer callback
◆ _XdmadProgState
◆ _XdmadState
XDMAD_STATE_FREE
Free channel
Allocated to some peripheral
XDMAD_STATE_START
DMA started
XDMAD_STATE_IN_XFR
DMA in transferring
XDMAD_STATE_DONE
DMA transfer done
XDMAD_STATE_HALTED
DMA transfer stopped
◆ _XdmadStatus
XDMAD_OK
Operation is successful
XDMAD_BUSY
Channel occupied or transfer not finished
XDMAD_ERROR
Operation failed
XDMAD_CANCELED
Operation cancelled
