RTEMS 6.1-rc2
Data Structures | Macros | Enumerations | Functions
qspi.h File Reference
struct  QspiMemCmd_t
 qspi command structure More...
struct  QspiBuffer_t
 qspi buffer structure More...
struct  QspiInstFrame_t
 qspi frame structure for QSPI mode More...
union  QspiInstFrame_t::_QspiInstFrame
struct  QspiInstFrame_t::_QspiInstFrame::_QspiInstFrameBM
struct  Qspid_t
 qspi driver structure More...
#define QSPI_SCBR(baudrate, masterClock)    ((uint32_t) (masterClock / baudrate) << 8)
#define QSPI_DLYBS(delay, masterClock)    ((uint32_t) (((masterClock / 1000000) * delay) / 1000) << 16)
#define QSPI_DLYBCT(delay, masterClock)    ((uint32_t) (((masterClock / 1000000) * delay) / 32000) << 24)
enum  Access_t { CmdAccess = 0 , ReadAccess , WriteAccess }
 qspi access modes
enum  QspiMode_t { SpiMode = QSPI_MR_SMM_SPI , QspiMemMode = QSPI_MR_SMM_MEMORY }
 qspi modes SPI or QSPI
enum  QspiClockMode_t { ClockMode_00 = 0 , ClockMode_10 , ClockMode_01 , ClockMode_11 }
 qspi clock modes , regarding clock phase and clock polarity
enum  QspidStatus_t {
  QSPI_SUCCESS = 0 , QSPI_BUSY , QSPI_BUSY_SENDING , QSPI_READ_ERROR ,
  QSPI_WRITE_ERROR , QSPI_UNKNOWN_ERROR , QSPI_INIT_ERROR , QSPI_INPUT_ERROR ,
  QSPI_TOTAL_ERROR
 qspi status codes
enum  QspiStatus_t {
  IsReceived = QSPI_SR_RDRF , IsTxSent = QSPI_SR_TDRE , IsTxEmpty = QSPI_SR_TXEMPTY , IsOverrun = QSPI_SR_OVRES ,
  IsCsRise = QSPI_SR_CSR , IsCsAsserted = QSPI_SR_CSS , IsEofInst = QSPI_SR_INSTRE , IsEnabled = QSPI_SR_QSPIENS
 qspi status regiter bits
void QSPI_SwReset (Qspi *pQspi)
 Resets a QSPI peripheral.
void QSPI_Disable (Qspi *pQspi)
 Disables a QSPI peripheral.
void QSPI_Enable (Qspi *pQspi)
 Enables a QSPI peripheral.
QspidStatus_t QSPI_EndTransfer (Qspi *pQspi)
 Ends ongoing transfer by releasing CS of QSPI peripheral.
uint32_t QSPI_GetStatus (Qspi *pQspi, const QspiStatus_t rStatus)
 Get the current status register of the given QSPI peripheral.
void QSPI_ConfigureClock (Qspi *pQspi, QspiClockMode_t ClockMode, uint32_t dwClockCfg)
 Configures peripheral clock of a QSPI/SPI peripheral.
QspidStatus_t QSPI_SingleReadSPI (Qspid_t *pQspid, uint16_t *const pData)
 Reads the data received by a SPI peripheral. This method must be called after a successful SPI_Write call.
QspidStatus_t QSPI_MultiReadSPI (Qspid_t *pQspid, uint16_t *const pData, uint32_t NumOfBytes)
 Reads multiple data received by a SPI peripheral. This method must be called after a successful SPI_Write call.
QspidStatus_t QSPI_SingleWriteSPI (Qspid_t *pQspid, uint16_t const *pData)
 Sends a single data through a SPI peripheral.
QspidStatus_t QSPI_MultiWriteSPI (Qspid_t *pQspid, uint16_t const *pData, uint32_t NumOfBytes)
 Sends multiple data through a SPI peripheral.
QspidStatus_t QSPI_EnableIt (Qspi *pQspi, uint32_t dwSources)
 Enables one or more interrupt sources of a QSPI peripheral.
QspidStatus_t QSPI_DisableIt (Qspi *pQspi, uint32_t dwSources)
 Disables one or more interrupt sources of a QSPI peripheral.
uint32_t QSPI_GetItMask (Qspi *pQspi)
 Return the interrupt mask register.
uint32_t QSPI_GetEnabledItStatus (Qspi *pQspi)
 Returns enabled interrupt status.
QspidStatus_t QSPI_ConfigureInterface (Qspid_t *pQspid, QspiMode_t Mode, uint32_t dwConfiguration)
 Configures QSPI/SPI.
QspidStatus_t QSPI_SendCommand (Qspid_t *pQspi, uint8_t const KeepCfg)
 Send an instruction over QSPI (oly a flash command no data)
QspidStatus_t QSPI_SendCommandWithData (Qspid_t *pQspi, uint8_t const KeepCfg)
 Send instruction over QSPI with data.
QspidStatus_t QSPI_ReadCommand (Qspid_t *pQspi, uint8_t const KeepCfg)
 Send instruction over QSPI to read data.
QspidStatus_t QSPI_EnableMemAccess (Qspid_t *pQspi, uint8_t const KeepCfg, uint8_t ScrambleFlag)
 Sends an instruction over QSPI and configures other related address like Addr , Frame and synchronise bus access before data read or write.
QspidStatus_t QSPI_ReadWriteMem (Qspid_t *pQspid, Access_t const ReadWrite)
 Writes or reads the QSPI memory (0x80000000) to transmit or receive data from Flash memory.
Interface for Serial Peripheral Interface (SPI) controller.
◆ QSPI_DLYBCT
#define QSPI_DLYBCT (   delay,
  masterClock
Calculates the value of the CSR DLYBCT field given the desired delay (in ns)
◆ QSPI_DLYBS
#define QSPI_DLYBS (   delay,
  masterClock
Calculates the value of the CSR DLYBS field given the desired delay (in ns)
◆ QSPI_SCBR
#define QSPI_SCBR (   baudrate,
  masterClock
Here are several macros which should be used when configuring a SPI peripheral.
SPI Configuration Macros
◆ QSPI_ConfigureClock()
void QSPI_ConfigureClock ( Qspi pQspi,
uint32_t  dwClockCfg
Parameters
pQspiPointer to an Qspi instance.
dwConfigurationDesired clock configuration.
◆ QSPI_ConfigureInterface()
QspidStatus_t QSPI_ConfigureInterface ( Qspid_t pQspid,
QspiMode_t  Mode,
Parameters
ModeMode for QSPI or SPI
dwConfigurationConfig of SPI or QSPI mode
◆ QSPI_Disable()
void QSPI_Disable ( Qspi pQspi)
Parameters
pQspiPointer to a Qspi instance.
◆ QSPI_DisableIt()
QspidStatus_t QSPI_DisableIt ( Qspi pQspi,
uint32_t  dwSources
Parameters
sourcesBitwise OR of selected interrupt sources.
◆ QSPI_Enable()
void QSPI_Enable ( Qspi pQspi)
Parameters
◆ QSPI_EnableIt()
QspidStatus_t QSPI_EnableIt ( Qspi pQspi,
uint32_t  dwSources
Parameters
◆ QSPI_EnableMemAccess()
QspidStatus_t QSPI_EnableMemAccess ( Qspid_t pQspid,
Parameters
KeepCfgTo keep Instruction from value or resets to zero
ScrambleFlagEnable or disable scramble on QSPI
Returns
Returns 1 if At least one instruction end has been detected since the last read of QSPI_SR.; otherwise returns 0.
◆ QSPI_EndTransfer()
QspidStatus_t QSPI_EndTransfer ( Qspi pQspi)
Parameters
◆ QSPI_GetEnabledItStatus()
uint32_t QSPI_GetEnabledItStatus ( Qspi pQspi)
Returns
Qspi interrupt mask register.
◆ QSPI_GetItMask()
uint32_t QSPI_GetItMask ( Qspi pQspi)
Returns
◆ QSPI_GetStatus()
uint32_t QSPI_GetStatus ( Qspi pQspi,
Note
This resets the internal value of the status register, so further read may yield different values.
Parameters
rStatusCompare status with given status bit
Returns
QSPI status register.
◆ QSPI_MultiReadSPI()
QspidStatus_t QSPI_MultiReadSPI ( Qspid_t pQspid,
uint32_t  NumOfBytes
Parameters
pQspidPointer to a Qspi instance.
pDataPointer to read buffer
NumOfBytesNum of bytes to read
Returns
Qspi status
◆ QSPI_MultiWriteSPI()
QspidStatus_t QSPI_MultiWriteSPI ( Qspid_t pQspid,
uint16_t const *  pData,
uint32_t  NumOfBytes
Parameters
pDataPointer to a Tx buffer
NumOfBytesNum of data to send.
◆ QSPI_ReadCommand()
QspidStatus_t QSPI_ReadCommand ( Qspid_t pQspid,
Parameters
Returns
◆ QSPI_ReadWriteMem()
QspidStatus_t QSPI_ReadWriteMem ( Qspid_t pQspid,
Parameters
ReadWriteFlag to indicate read/write QSPI memory access
Returns
◆ QSPI_SendCommand()
QspidStatus_t QSPI_SendCommand ( Qspid_t pQspid,
Parameters
KeepCfgTo keep Instruction fram value or restes to zero
Returns
◆ QSPI_SendCommandWithData()
QspidStatus_t QSPI_SendCommandWithData ( Qspid_t pQspid,
Parameters
Returns
◆ QSPI_SingleReadSPI()
QspidStatus_t QSPI_SingleReadSPI ( Qspid_t pQspid,
Parameters
pDataBuffer to put read value
Returns
Qspi status
◆ QSPI_SingleWriteSPI()
QspidStatus_t QSPI_SingleWriteSPI ( Qspid_t pQspid,
Parameters
pDataPointer to Tx data
Returns
Qspi status
◆ QSPI_SwReset()
void QSPI_SwReset ( Qspi pQspi)
Parameters
