RTEMS 6.1-rc2
Extension of the generic libchip console driver shell. More...
int | vt_ioctl (unsigned int cmd, unsigned long arg) |
This function is the ioctl() support for a VGA buffer driver. | |
console_tbl * | console_find_console_entry (const char *match, size_t length, rtems_device_minor_number *match_minor) |
console_find_console_entry | |
void | console_initialize_data (void) |
console_initialize_data | |
void | console_register_devices (console_tbl *new_ports, size_t number_of_ports) |
console_register_devices | |
rtems_device_minor_number | BSPPrintkPort |
console_tbl * console_find_console_entry | ( | const char * | match, |
size_t | length, | ||
rtems_device_minor_number * | match_minor | ||
This method is used to search the console entries for a specific device entry and return it. If match is NULL the minor number provided is matched.
void console_initialize_data | ( | void | ) |
This must be called before dynamic registration of devices can occur. It is normally called as a side-effect of console_initialize() but if a probe and dynamic registration occurs before that, then this method should be explicitly invoked.
void console_register_devices | ( | console_tbl * | new_ports, |
size_t | number_of_ports | ||
This function expands the console table to include previous ports and the array of new ports specified.
[in] | new_ports | specifies an array of new ports to register |
[in] | number_of_ports | specifies the number of elements in the new_ports array |
int vt_ioctl | ( | unsigned int | cmd, |
unsigned long | arg | ||
