RTEMS 6.1-rc2
_console_tbl Struct Reference
#include <serial.h>
const char * sDeviceName
console_devs deviceType
const console_fnspDeviceFns
bool(* deviceProbe )(int minor)
const console_flowpDeviceFlow
uint32_t ulMargin
uint32_t ulHysteresis
void * pDeviceParams
uint32_t ulCtrlPort1
uint32_t ulCtrlPort2
uint32_t ulDataPort
getRegister_f getRegister
setRegister_f setRegister
getData_f getData
setData_f setData
uint32_t ulClock
unsigned int ulIntVector
This type defination provides an structure that is used to uniquely identify a specific serial port.
Field Documentation
◆ deviceProbe
bool(* _console_tbl::deviceProbe) (int minor)
This value is passed to the serial device driver for use. In termios itself the number is ignored.
◆ deviceType
console_devs _console_tbl::deviceType
This indicates the chip type. It is especially important when multiple devices share the same interrupt vector and must be distinguished.
◆ getData
getData_f _console_tbl::getData
This is the routine used to read the data register (RX).
◆ getRegister
getRegister_f _console_tbl::getRegister
This is the routine used to read register values.
◆ pDeviceFlow
const console_flow* _console_tbl::pDeviceFlow
This is a pointer to the set of flow control routines to use. Serial device drivers will typically supply RTSCTS and DTRCTS handshake routines for DCE to DCE communication, however for DCE to DTE communication, no such routines should be necessary as RTS will be driven automatically when the transmitter is active.
◆ pDeviceFns
const console_fns* _console_tbl::pDeviceFns
pDeviceFns This is a pointer to the set of driver routines to use.
◆ pDeviceParams
void* _console_tbl::pDeviceParams
This contains either device specific data or a pointer to a device specific structure containing additional information not provided in this table.
◆ sDeviceName
const char* _console_tbl::sDeviceName
This is the name of the device.
◆ setRegister
setRegister_f _console_tbl::setRegister
This is the routine used to write register values.
◆ ulClock
uint32_t _console_tbl::ulClock
This is the baud rate clock speed.
◆ ulCtrlPort1
uint32_t _console_tbl::ulCtrlPort1
This is the primary control port number for the device. This may be used to specify different instances of the same device type.
◆ ulCtrlPort2
uint32_t _console_tbl::ulCtrlPort2
This is the secondary control port number, of use when a given device has more than one available channel.
◆ ulDataPort
uint32_t _console_tbl::ulDataPort
This is the port number for the data port of the device
◆ ulHysteresis
uint32_t _console_tbl::ulHysteresis
After the high water mark specified by ulMargin has been reached, the driver's routine to re-start the remote transmitter will be called once the level in the input buffer has fallen by ulHysteresis bytes.
Note
At the current time, this parameter is hard coded in termios.
◆ ulIntVector
unsigned int _console_tbl::ulIntVector
This encodes the interrupt vector of the device.
◆ ulMargin
uint32_t _console_tbl::ulMargin
The high water mark in the input buffer is set to the buffer size less ulMargin. Once this level is reached, the driver's flow control routine used to stop the remote transmitter will be called. This figure should be greater than or equal to the number of stages of FIFO between the transmitter and receiver.
Note
At the current time, this parameter is hard coded in termios and this number is ignored.
