RTEMS 6.1-rc2
Functions | Variables
legacy-console.c File Reference
Extension of the generic libchip console driver shell. More...
#include <bsp.h>
#include <bsp/fatal.h>
#include <rtems/libio.h>
#include <rtems/console.h>
#include <assert.h>
#include <termios.h>
#include <rtems/termiostypes.h>
#include <libchip/serial.h>
#include "legacy-console.h"
console_tblconsole_find_console_entry (const char *match, size_t length, rtems_device_minor_number *match_minor)
void console_initialize_data (void)
void console_register_devices (console_tbl *new_ports, size_t number_of_ports)
rtems_device_driver console_open (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console open entry point.
rtems_device_driver console_close (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console close entry point.
rtems_device_driver console_initialize (rtems_device_major_number major, rtems_device_minor_number minor_arg, void *arg)
 Console initialization entry point.
rtems_device_driver console_read (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console read entry point.
rtems_device_driver console_write (rtems_device_major_number major, rtems_device_minor_number minor, void *arg)
 Console write entry point.
unsigned long Console_Port_Count = 0
console_tbl ** Console_Port_Tbl = NULL
console_dataConsole_Port_Data = NULL
rtems_device_minor_number Console_Port_Minor = 0
◆ console_close()
rtems_device_driver console_close ( rtems_device_major_number  major,
void *  arg
This method closes a specific device supported by the console device driver.
Parameters
[in]majoris the device driver major number
[in]minoris the device driver minor number
[in]argis the parameters to this call
Return values
RTEMS_SUCCESSFULThe device driver is successfully closed.
◆ console_find_console_entry()
console_tbl * console_find_console_entry ( const char *  match,
size_t  length,
rtems_device_minor_number match_minor
This method is used to search the console entries for a specific device entry and return it. If match is NULL the minor number provided is matched.
◆ console_initialize()
rtems_device_driver console_initialize ( rtems_device_major_number  major,
void *  arg
This method initializes the console device driver.
Parameters
[in]majoris the device driver major number.
[in]minoris the device driver minor number.
[in]argis the parameters to this call.
Return values
RTEMS_SUCCESSFULThe device driver is successfully initialized.
Initialize all serial drivers specified in driver_context_table
Parameters
[in]major
[in]minor
[in]arg
Return values
RTEMS_SUCCESSFULInitialization completed
This routine initializes the console IO driver.
Parameters
Parameters
majormajor number
minorminor number
Output parameters: NONE
Returns
void
◆ console_initialize_data()
void console_initialize_data ( void  )
This must be called before dynamic registration of devices can occur. It is normally called as a side-effect of console_initialize() but if a probe and dynamic registration occurs before that, then this method should be explicitly invoked.
◆ console_open()
rtems_device_driver console_open ( rtems_device_major_number  major,
void *  arg
This method opens a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device driver is successfully opened.
◆ console_read()
rtems_device_driver console_read ( rtems_device_major_number  major,
void *  arg
This method reads from a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device is successfully read from.
◆ console_register_devices()
void console_register_devices ( console_tbl new_ports,
This function expands the console table to include previous ports and the array of new ports specified.
Parameters
[in]new_portsspecifies an array of new ports to register
[in]number_of_portsspecifies the number of elements in the new_ports array
◆ console_write()
rtems_device_driver console_write ( rtems_device_major_number  major,
void *  arg
This method writes to a specific device supported by the console device driver.
Parameters
Return values
RTEMS_SUCCESSFULThe device is successfully written.
Variable Documentation
◆ Console_Port_Count
This is the number of serial ports defined in the Console_Port_Tbl.
◆ Console_Port_Data
console_data* Console_Port_Data = NULL
This is an array of per port information.
◆ Console_Port_Tbl
console_tbl** Console_Port_Tbl = NULL
This is a dynamically sized set of tables containing the serial port information.
