RTEMS 6.1-rc2
libio.h
2
15/*
16 * COPYRIGHT (C) 1989, 2021 On-Line Applications Research Corporation (OAR).
17 *
18 * Modifications to support reference counting in the file system are
19 * Copyright (C) 2012 embedded brains GmbH & Co. KG
20 *
21 * Redistribution and use in source and binary forms, with or without
22 * modification, are permitted provided that the following conditions
23 * are met:
24 * 1. Redistributions of source code must retain the above copyright
25 * notice, this list of conditions and the following disclaimer.
26 * 2. Redistributions in binary form must reproduce the above copyright
27 * notice, this list of conditions and the following disclaimer in the
28 * documentation and/or other materials provided with the distribution.
29 *
30 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
31 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
32 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
33 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
34 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
35 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
36 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
37 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
38 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
39 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
40 * POSSIBILITY OF SUCH DAMAGE.
41 */
42
43#ifndef _RTEMS_RTEMS_LIBIO_H
44#define _RTEMS_RTEMS_LIBIO_H
45
46#include <sys/types.h>
47#include <sys/stat.h>
48#include <sys/ioccom.h>
49#include <sys/statvfs.h>
50#include <sys/uio.h>
51
52#include <unistd.h>
53#include <termios.h>
54
55#include <rtems.h>
56#include <rtems/fs.h>
57#include <rtems/chain.h>
58#include <rtems/score/atomic.h>
59#include <rtems/termiosdevice.h>
60
61#ifdef __cplusplus
62extern "C" {
63#endif
64
65struct knote;
66
87);
88
98);
99
103typedef struct {
107 const char *path;
108
112 size_t pathlen;
113
118 const char *token;
119
124 size_t tokenlen;
125
138 int flags;
139
146
155
161
168
178);
179
194 const rtems_filesystem_location_info_t *parentloc,
195 const rtems_filesystem_location_info_t *targetloc,
196 const char *name,
197 size_t namelen
198);
199
213 mode_t mode
214);
215
230 uid_t owner,
231 gid_t group
232);
233
251);
252
262);
263
282);
283
298 const void *data
299);
300
317);
318
332);
333
351);
352
370 const rtems_filesystem_location_info_t *parentloc,
371 const char *name,
372 size_t namelen,
373 mode_t mode,
374 dev_t dev
375);
376
389 const rtems_filesystem_location_info_t *parentloc,
391);
392
406 struct timespec times[2]
407);
408
424 const rtems_filesystem_location_info_t *parentloc,
425 const char *name,
426 size_t namelen,
427 const char *target
428);
429
444 char *buf,
445 size_t bufsize
446);
447
463 const rtems_filesystem_location_info_t *oldparentloc,
465 const rtems_filesystem_location_info_t *newparentloc,
466 const char *name,
467 size_t namelen
468);
469
483 struct statvfs *buf
484);
485
494 rtems_filesystem_are_nodes_equal_t are_nodes_equal_h;
503 rtems_filesystem_fsunmount_me_t fsunmount_me_h;
509};
510
516
524);
525
533);
534
543);
544
551 const rtems_filesystem_location_info_t *parentloc,
552 const rtems_filesystem_location_info_t *targetloc,
553 const char *name,
554 size_t namelen
555);
556
572);
573
580 const rtems_filesystem_location_info_t *parentloc,
581 const char *name,
582 size_t namelen,
583 mode_t mode,
584 dev_t dev
585);
586
593 const rtems_filesystem_location_info_t *parentloc,
595);
596
604 mode_t mode
605);
606
614 uid_t owner,
615 gid_t group
616);
617
625);
626
632);
633
640 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
641);
642
649 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
650);
651
658 rtems_filesystem_mount_table_entry_t *mt_entry /* IN */
659);
660
668 struct timespec times[2]
669);
670
677 const rtems_filesystem_location_info_t *parentloc,
678 const char *name,
679 size_t namelen,
680 const char *target
681);
682
690 char *buf,
691 size_t bufsize
692);
693
700 const rtems_filesystem_location_info_t *oldparentloc,
702 const rtems_filesystem_location_info_t *newparentloc,
703 const char *name,
704 size_t namelen
705);
706
714 struct statvfs *buf
715);
716
742 rtems_libio_t *iop,
743 const char *path,
744 int oflag,
745 mode_t mode
746);
747
759 rtems_libio_t *iop
760);
761
776typedef ssize_t (*rtems_filesystem_read_t)(
777 rtems_libio_t *iop,
778 void *buffer,
779 size_t count
780);
781
798typedef ssize_t (*rtems_filesystem_readv_t)(
799 rtems_libio_t *iop,
800 const struct iovec *iov,
801 int iovcnt,
802 ssize_t total
803);
804
819typedef ssize_t (*rtems_filesystem_write_t)(
820 rtems_libio_t *iop,
821 const void *buffer,
822 size_t count
823);
824
841typedef ssize_t (*rtems_filesystem_writev_t)(
842 rtems_libio_t *iop,
843 const struct iovec *iov,
844 int iovcnt,
845 ssize_t total
846);
847
861 rtems_libio_t *iop,
862 ioctl_command_t request,
863 void *buffer
864);
865
881 rtems_libio_t *iop,
882 off_t offset,
883 int whence
884);
885
899 struct stat *buf
900);
901
915 rtems_libio_t *iop,
916 off_t length
917);
918
931 rtems_libio_t *iop
932);
933
946 rtems_libio_t *iop
947);
948
961 rtems_libio_t *iop,
962 int cmd
963);
964
976 rtems_libio_t *iop,
977 int events
978);
979
992 rtems_libio_t *iop,
993 struct knote *kn
994);
995
1011 rtems_libio_t *iop,
1012 void **addr,
1013 size_t len,
1014 int prot,
1015 off_t off
1016);
1017
1029 rtems_filesystem_ftruncate_t ftruncate_h;
1031 rtems_filesystem_fdatasync_t fdatasync_h;
1034 rtems_filesystem_kqfilter_t kqfilter_h;
1038};
1039
1045
1052 rtems_libio_t *iop,
1053 const char *path,
1054 int oflag,
1055 mode_t mode
1056);
1057
1064 rtems_libio_t *iop
1065);
1066
1073 rtems_libio_t *iop,
1074 void *buffer,
1075 size_t count
1076);
1077
1084 rtems_libio_t *iop,
1085 const struct iovec *iov,
1086 int iovcnt,
1087 ssize_t total
1088);
1089
1096 rtems_libio_t *iop,
1097 const void *buffer,
1098 size_t count
1099);
1100
1107 rtems_libio_t *iop,
1108 const struct iovec *iov,
1109 int iovcnt,
1110 ssize_t total
1111);
1112
1119 rtems_libio_t *iop,
1120 ioctl_command_t request,
1121 void *buffer
1122);
1123
1130 rtems_libio_t *iop,
1131 off_t offset,
1132 int whence
1133);
1134
1147 rtems_libio_t *iop,
1148 off_t offset,
1149 int whence
1150);
1151
1170 rtems_libio_t *iop,
1171 off_t offset,
1172 int whence
1173);
1174
1184 struct stat *buf
1185);
1186
1193 rtems_libio_t *iop,
1194 off_t length
1195);
1196
1203 rtems_libio_t *iop,
1204 off_t length
1205);
1206
1213 rtems_libio_t *iop
1214);
1215
1222 rtems_libio_t *iop
1223);
1224
1231 rtems_libio_t *iop,
1232 int cmd
1233);
1234
1243 rtems_libio_t *iop,
1244 int events
1245);
1246
1255 rtems_libio_t *iop,
1256 struct knote *kn
1257);
1258
1267 rtems_libio_t *iop,
1268 void **addr,
1269 size_t len,
1270 int prot,
1271 off_t off
1272);
1273
1290typedef off_t rtems_off64_t __attribute__((deprecated));
1291
1300 const char *type
1301);
1302
1307typedef struct {
1308 int link_max; /* count */
1309 int max_canon; /* max formatted input line size */
1310 int max_input; /* max input line size */
1311 int name_max; /* max name length */
1312 int path_max; /* max path */
1313 int pipe_buf; /* pipe buffer size */
1314 int posix_async_io; /* async IO supported on fs, 0=no, 1=yes */
1315 int posix_chown_restrictions; /* can chown: 0=no, 1=yes */
1316 int posix_no_trunc; /* error on names > max name, 0=no, 1=yes */
1317 int posix_prio_io; /* priority IO, 0=no, 1=yes */
1318 int posix_sync_io; /* file can be sync'ed, 0=no, 1=yes */
1319 int posix_vdisable; /* special char processing, 0=no, 1=yes */
1321
1329
1339 Atomic_Uint flags;
1340 off_t offset; /* current offset into file */
1342 uint32_t data0; /* private to "driver" */
1343 void *data1; /* ... */
1344};
1345
1352typedef struct {
1353 rtems_libio_t *iop;
1354 off_t offset;
1355 char *buffer;
1356 uint32_t count;
1357 uint32_t flags;
1358 uint32_t bytes_moved;
1360
1365 rtems_libio_t *iop;
1366 uint32_t flags;
1367 uint32_t mode;
1369
1373typedef struct {
1374 rtems_libio_t *iop;
1375 ioctl_command_t command;
1376 void *buffer;
1377 int ioctl_return;
1379
1385#define LIBIO_FLAGS_NO_DELAY 0x0001U /* return immediately if no data */
1386#define LIBIO_FLAGS_READ 0x0002U /* reading */
1387#define LIBIO_FLAGS_WRITE 0x0004U /* writing */
1388#define LIBIO_FLAGS_OPEN 0x0100U /* device is open */
1389#define LIBIO_FLAGS_APPEND 0x0200U /* all writes append */
1390#define LIBIO_FLAGS_CLOSE_ON_EXEC 0x0800U /* close on process exec() */
1391#define LIBIO_FLAGS_READ_WRITE (LIBIO_FLAGS_READ | LIBIO_FLAGS_WRITE)
1392#define LIBIO_FLAGS_REFERENCE_INC 0x1000U
1393
1396static inline unsigned int rtems_libio_iop_flags( const rtems_libio_t *iop )
1397{
1398 return _Atomic_Load_uint( &iop->flags, ATOMIC_ORDER_RELAXED );
1399}
1400
1406static inline bool rtems_libio_iop_is_no_delay( const rtems_libio_t *iop )
1407{
1408 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_NO_DELAY ) != 0;
1409}
1410
1416static inline bool rtems_libio_iop_is_readable( const rtems_libio_t *iop )
1417{
1418 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_READ ) != 0;
1419}
1420
1426static inline bool rtems_libio_iop_is_writeable( const rtems_libio_t *iop )
1427{
1428 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_WRITE ) != 0;
1429}
1430
1436static inline bool rtems_libio_iop_is_append( const rtems_libio_t *iop )
1437{
1438 return ( rtems_libio_iop_flags( iop ) & LIBIO_FLAGS_APPEND ) != 0;
1439}
1440
1446typedef int (*rtems_libio_open_t)(
1447 const char *pathname,
1448 uint32_t flag,
1449 uint32_t mode
1450);
1451
1452typedef int (*rtems_libio_close_t)(
1453 int fd
1454);
1455
1456typedef ssize_t (*rtems_libio_read_t)(
1457 int fd,
1458 void *buffer,
1459 size_t count
1460);
1461
1462typedef ssize_t (*rtems_libio_write_t)(
1463 int fd,
1464 const void *buffer,
1465 size_t count
1466);
1467
1468typedef int (*rtems_libio_ioctl_t)(
1469 int fd,
1470 uint32_t command,
1471 void *buffer
1472);
1473
1474typedef off_t (*rtems_libio_lseek_t)(
1475 int fd,
1476 off_t offset,
1477 int whence
1478);
1479
1487/*
1488 * The following macros are used to build up the permissions sets
1489 * used to check permissions. These are similar in style to the
1490 * mode_t bits and should stay compatible with them.
1491 */
1492#define RTEMS_FS_PERMS_READ 0x4
1493#define RTEMS_FS_PERMS_WRITE 0x2
1494#define RTEMS_FS_PERMS_EXEC 0x1
1495#define RTEMS_FS_PERMS_RWX \
1496 (RTEMS_FS_PERMS_READ | RTEMS_FS_PERMS_WRITE | RTEMS_FS_PERMS_EXEC)
1497#define RTEMS_FS_FOLLOW_HARD_LINK 0x8
1498#define RTEMS_FS_FOLLOW_SYM_LINK 0x10
1499#define RTEMS_FS_FOLLOW_LINK \
1500 (RTEMS_FS_FOLLOW_HARD_LINK | RTEMS_FS_FOLLOW_SYM_LINK)
1501#define RTEMS_FS_MAKE 0x20
1502#define RTEMS_FS_EXCLUSIVE 0x40
1503#define RTEMS_FS_ACCEPT_RESIDUAL_DELIMITERS 0x80
1504#define RTEMS_FS_REJECT_TERMINAL_DOT 0x100
1505
1509 dev_t device;
1510 struct {
1513 } __overlay;
1514};
1515
1516static inline dev_t rtems_filesystem_make_dev_t(
1519)
1520{
1521 union __rtems_dev_t temp;
1522
1523 temp.__overlay.major = _major;
1524 temp.__overlay.minor = _minor;
1525 return temp.device;
1526}
1527
1528static inline dev_t rtems_filesystem_make_dev_t_from_pointer(
1529 const void *pointer
1530)
1531{
1532 uint64_t temp = (((uint64_t) 1) << 63) | (((uintptr_t) pointer) >> 1);
1533
1534 return rtems_filesystem_make_dev_t((uint32_t) (temp >> 32), (uint32_t) temp);
1535}
1536
1537static inline rtems_device_major_number rtems_filesystem_dev_major_t(
1538 dev_t device
1539)
1540{
1541 union __rtems_dev_t temp;
1542
1543 temp.device = device;
1544 return temp.__overlay.major;
1545}
1546
1547
1548static inline rtems_device_minor_number rtems_filesystem_dev_minor_t(
1549 dev_t device
1550)
1551{
1552 union __rtems_dev_t temp;
1553
1554 temp.device = device;
1555 return temp.__overlay.minor;
1556}
1557
1558#define rtems_filesystem_split_dev_t( _dev, _major, _minor ) \
1559 do { \
1560 (_major) = rtems_filesystem_dev_major_t ( _dev ); \
1561 (_minor) = rtems_filesystem_dev_minor_t( _dev ); \
1562 } while(0)
1563
1564/*
1565 * Prototypes for filesystem
1566 */
1567
1576void rtems_filesystem_initialize( void );
1577
1578void rtems_libio_post_driver(void);
1579
1580void rtems_libio_exit(void);
1581
1591extern int rtems_mkdir(const char *path, mode_t mode);
1592
1609#define RTEMS_FILESYSTEM_TYPE_IMFS "imfs"
1610#define RTEMS_FILESYSTEM_TYPE_FTPFS "ftpfs"
1611#define RTEMS_FILESYSTEM_TYPE_TFTPFS "tftpfs"
1612#define RTEMS_FILESYSTEM_TYPE_NFS "nfs"
1613#define RTEMS_FILESYSTEM_TYPE_DOSFS "dosfs"
1614#define RTEMS_FILESYSTEM_TYPE_RFS "rfs"
1615#define RTEMS_FILESYSTEM_TYPE_JFFS2 "jffs2"
1616
1623 rtems_chain_node mt_node;
1624 void *fs_info;
1626 const void *immutable_fs_info;
1627 rtems_chain_control location_chain;
1630 bool mounted;
1631 bool writeable;
1632 bool no_regular_file_mknod;
1633 const rtems_filesystem_limits_and_options_t *pathconf_limits_and_options;
1634
1635 /*
1636 * The target or mount point of the file system.
1637 */
1638 const char *target;
1639
1640 /*
1641 * The type of filesystem or the name of the filesystem.
1642 */
1643 const char *type;
1644
1645 /*
1646 * When someone adds a mounted filesystem on a real device,
1647 * this will need to be used.
1648 *
1649 * The lower layers can manage how this is managed. Leave as a
1650 * string.
1651 */
1652 char *dev;
1653
1661};
1662
1666typedef enum {
1667 RTEMS_FILESYSTEM_READ_ONLY,
1668 RTEMS_FILESYSTEM_READ_WRITE,
1669 RTEMS_FILESYSTEM_BAD_OPTIONS
1671
1676 const char *type;
1679
1686
1687extern rtems_chain_control rtems_filesystem_mount_table;
1688
1698 const char *type,
1700);
1701
1709 const char *type
1710);
1711
1734int unmount(
1735 const char *mount_path
1736);
1737
1785int mount(
1786 const char *source,
1787 const char *target,
1788 const char *filesystemtype,
1790 const void *data
1791);
1792
1805 const char *source,
1806 const char *target,
1807 const char *filesystemtype,
1809 const void *data
1810);
1811
1821 const rtems_filesystem_table_t *fs_entry,
1822 void *arg
1823);
1824
1840 void *routine_arg
1841);
1842
1853 void *arg
1854);
1855
1871 void *visitor_arg
1872);
1873
1874typedef struct {
1875 const char *source;
1876 const char *target;
1877 const char *filesystemtype;
1879 const void *data;
1881
1883 rtems_filesystem_root_configuration;
1884
1896struct rtems_termios_tty;
1897
1899 int (*firstOpen)(int major, int minor, void *arg);
1900 int (*lastClose)(int major, int minor, void *arg);
1901 int (*pollRead)(int minor);
1902 ssize_t (*write)(int minor, const char *buf, size_t len);
1903 int (*setAttributes)(int minor, const struct termios *t);
1904 int (*stopRemoteTx)(int minor);
1905 int (*startRemoteTx)(int minor);
1906 rtems_termios_device_mode outputUsesInterrupts;
1908
1909static inline void rtems_termios_initialize( void )
1910{
1911 /* Nothing to do, provided for backward compatibility */
1912}
1913
1914/*
1915 * CCJ: Change before opening a tty. Newer code from Eric is coming
1916 * so extra work to handle an open tty is not worth it. If the tty
1917 * is open, close then open it again.
1918 */
1919rtems_status_code rtems_termios_bufsize (
1920 size_t cbufsize, /* cooked buffer size */
1921 size_t raw_input, /* raw input buffer size */
1922 size_t raw_output /* raw output buffer size */
1923);
1924
1929typedef enum {
1937
1949
1957
1975 unsigned char c,
1976 struct rtems_termios_tty *tty
1977);
1978
1998 unsigned char c,
1999 struct rtems_termios_tty *tty
2000);
2001
2016 unsigned char c,
2017 struct rtems_termios_tty *tty
2018);
2019
2034);
2035
2036int rtems_termios_enqueue_raw_characters(
2037 void *ttyp,
2038 const char *buf,
2039 int len
2040);
2041
2042rtems_status_code rtems_termios_open (
2045 void *arg,
2046 const rtems_termios_callbacks *callbacks
2047);
2048
2049rtems_status_code rtems_termios_close(
2050 void *arg
2051);
2052
2053rtems_status_code rtems_termios_read(
2054 void *arg
2055);
2056
2057rtems_status_code rtems_termios_write(
2058 void *arg
2059);
2060
2061rtems_status_code rtems_termios_ioctl(
2062 void *arg
2063);
2064
2065int rtems_termios_dequeue_characters(
2066 void *ttyp,
2067 int len
2068);
2069
2075#define rtems_filesystem_pathconf(_mte) ((_mte)->pathconf_limits_and_options)
2076
2080#define rtems_filesystem_type(_mte) ((_mte)->type)
2081
2085#define rtems_filesystem_mount_point(_mte) ((_mte)->target)
2086
2090#define rtems_filesystem_mount_device(_mte) ((_mte)->dev)
2091
2092#ifdef __cplusplus
2093}
2094#endif
2095
2096#endif /* _RTEMS_LIBIO_H */
clock_t times(struct tms *ptms)
Definition: __times.c:97
This header file provides the Chains API.
bool rtems_filesystem_mount_iterate(rtems_filesystem_mt_entry_visitor visitor, void *visitor_arg)
Iterates over all file system mount entries.
Definition: sup_fs_mount_iterate.c:42
int mount_and_make_target_path(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system and makes the target path.
Definition: mount-mktgt.c:44
bool rtems_filesystem_iterate(rtems_per_filesystem_routine routine, void *routine_arg)
Iterates over all file system types.
Definition: mount-mgr.c:58
int unmount(const char *mount_path)
Unmounts the file system instance at the specified mount path.
Definition: unmount.c:62
int rtems_filesystem_unregister(const char *type)
Unregisters a file system type.
Definition: mount-mgr.c:160
const rtems_filesystem_table_t rtems_filesystem_table[]
Static table of file systems.
bool(* rtems_filesystem_mt_entry_visitor)(const rtems_filesystem_mount_table_entry_t *mt_entry, void *arg)
Mount table entry visitor.
Definition: libio.h:1851
bool(* rtems_per_filesystem_routine)(const rtems_filesystem_table_t *fs_entry, void *arg)
Per file system type routine.
Definition: libio.h:1820
int rtems_filesystem_register(const char *type, rtems_filesystem_fsmount_me_t mount_h)
Registers a file system type.
Definition: mount-mgr.c:126
File system options.
Definition: libio.h:1666
int mount(const char *source, const char *target, const char *filesystemtype, rtems_filesystem_options_t options, const void *data)
Mounts a file system instance at the specified target path.
Definition: mount.c:197
int(* rtems_filesystem_ioctl_t)(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
IO control of a node.
Definition: libio.h:860
int rtems_filesystem_default_fcntl(rtems_libio_t *iop, int cmd)
Definition: default_fcntl.c:41
int(* rtems_filesystem_poll_t)(rtems_libio_t *iop, int events)
Poll and select support.
Definition: libio.h:975
int rtems_filesystem_default_ftruncate(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate.c:44
int rtems_filesystem_default_ftruncate_directory(rtems_libio_t *iop, off_t length)
Definition: default_ftruncate_directory.c:43
off_t rtems_filesystem_default_lseek_directory(rtems_libio_t *iop, off_t offset, int whence)
An offset 0 with a whence of SEEK_SET will perform a directory rewind operation.
Definition: default_lseek_directory.c:42
ssize_t(* rtems_filesystem_read_t)(rtems_libio_t *iop, void *buffer, size_t count)
Reads from a node.
Definition: libio.h:776
int(* rtems_filesystem_fcntl_t)(rtems_libio_t *iop, int cmd)
File control.
Definition: libio.h:960
int rtems_filesystem_default_ioctl(rtems_libio_t *iop, ioctl_command_t request, void *buffer)
Definition: default_ioctl.c:43
int rtems_filesystem_default_poll(rtems_libio_t *iop, int events)
Default poll handler.
Definition: default_poll.c:44
int rtems_filesystem_default_fsync_or_fdatasync(rtems_libio_t *iop)
Definition: default_fsync.c:43
const rtems_filesystem_file_handlers_r rtems_filesystem_handlers_default
File system node handler table with default node handlers.
Definition: default_handlers.c:38
off_t rtems_filesystem_default_lseek_file(rtems_libio_t *iop, off_t offset, int whence)
Default lseek() handler for files.
Definition: default_lseek_file.c:42
int(* rtems_filesystem_kqfilter_t)(rtems_libio_t *iop, struct knote *kn)
Kernel event filter support.
Definition: libio.h:991
int rtems_filesystem_default_fstat(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Sets the mode to S_IRWXU | S_IRWXG | S_IRWXO.
Definition: default_fstat.c:43
int rtems_filesystem_default_fsync_or_fdatasync_success(rtems_libio_t *iop)
Definition: default_fsync_success.c:42
int rtems_filesystem_default_kqfilter(rtems_libio_t *iop, struct knote *kn)
Default kernel event filter handler.
Definition: default_kqfilter.c:42
ssize_t rtems_filesystem_default_writev(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the write handler for each IO vector entry.
Definition: default_writev.c:45
int(* rtems_filesystem_close_t)(rtems_libio_t *iop)
Closes a node.
Definition: libio.h:758
ssize_t rtems_filesystem_default_readv(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Calls the read handler for each IO vector entry.
Definition: default_readv.c:45
off_t(* rtems_filesystem_lseek_t)(rtems_libio_t *iop, off_t offset, int whence)
Moves the read/write file offset.
Definition: libio.h:880
off_t rtems_filesystem_default_lseek(rtems_libio_t *iop, off_t offset, int whence)
Definition: default_lseek.c:43
ssize_t(* rtems_filesystem_writev_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Writes an IO vector to a node.
Definition: libio.h:841
int(* rtems_filesystem_fstat_t)(const rtems_filesystem_location_info_t *loc, struct stat *buf)
Gets a node status.
Definition: libio.h:897
int rtems_filesystem_default_mmap(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
Default MMAP handler.
Definition: default_mmap.c:42
ssize_t(* rtems_filesystem_write_t)(rtems_libio_t *iop, const void *buffer, size_t count)
Writes to a node.
Definition: libio.h:819
int rtems_filesystem_default_close(rtems_libio_t *iop)
Definition: default_close.c:37
int(* rtems_filesystem_fsync_t)(rtems_libio_t *iop)
Synchronizes changes to a file.
Definition: libio.h:930
ssize_t rtems_filesystem_default_read(rtems_libio_t *iop, void *buffer, size_t count)
Definition: default_read.c:39
int(* rtems_filesystem_fdatasync_t)(rtems_libio_t *iop)
Synchronizes the data of a file.
Definition: libio.h:945
int rtems_filesystem_default_open(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Definition: default_open.c:43
int(* rtems_filesystem_mmap_t)(rtems_libio_t *iop, void **addr, size_t len, int prot, off_t off)
MMAP support.
Definition: libio.h:1010
ssize_t(* rtems_filesystem_readv_t)(rtems_libio_t *iop, const struct iovec *iov, int iovcnt, ssize_t total)
Reads an IO vector from a node.
Definition: libio.h:798
ssize_t rtems_filesystem_default_write(rtems_libio_t *iop, const void *buffer, size_t count)
Definition: default_write.c:41
int(* rtems_filesystem_ftruncate_t)(rtems_libio_t *iop, off_t length)
Truncates a file to a specified length.
Definition: libio.h:914
int(* rtems_filesystem_open_t)(rtems_libio_t *iop, const char *path, int oflag, mode_t mode)
Opens a node.
Definition: libio.h:741
int(* rtems_filesystem_statvfs_t)(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Gets file system information.
Definition: libio.h:481
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_unmount.c:41
int(* rtems_filesystem_link_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Creates a new link for the existing file.
Definition: libio.h:193
int(* rtems_filesystem_mount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Mounts a file system instance in a mount point (directory).
Definition: libio.h:280
int(* rtems_filesystem_fchmod_t)(const rtems_filesystem_location_info_t *loc, mode_t mode)
Changes the mode of a node.
Definition: libio.h:211
void rtems_filesystem_default_lock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Obtains the IO library mutex.
Definition: default_lock_and_unlock.c:42
int rtems_filesystem_default_rename(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Definition: default_rename.c:44
void(* rtems_filesystem_fsunmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Destroys a file system instance.
Definition: libio.h:330
int rtems_filesystem_default_mknod(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Definition: default_mknod.c:44
int rtems_filesystem_default_fchmod(const rtems_filesystem_location_info_t *loc, mode_t mode)
Definition: default_fchmod.c:42
void(* rtems_filesystem_eval_path_t)(rtems_filesystem_eval_path_context_t *ctx)
Path evaluation.
Definition: libio.h:176
int(* rtems_filesystem_unmount_t)(rtems_filesystem_mount_table_entry_t *mt_entry)
Unmounts a file system instance in a mount point (directory).
Definition: libio.h:315
int rtems_filesystem_default_clonenode(rtems_filesystem_location_info_t *loc)
Definition: default_clone.c:42
void rtems_filesystem_default_unlock(const rtems_filesystem_mount_table_entry_t *mt_entry)
Releases the IO library mutex.
Definition: default_lock_and_unlock.c:49
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition: default_are_nodes_equal.c:42
int(* rtems_filesystem_rmnod_t)(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Removes a node.
Definition: libio.h:388
int rtems_filesystem_default_rmnod(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *loc)
Definition: default_rmnod.c:44
int(* rtems_filesystem_rename_t)(const rtems_filesystem_location_info_t *oldparentloc, const rtems_filesystem_location_info_t *oldloc, const rtems_filesystem_location_info_t *newparentloc, const char *name, size_t namelen)
Renames a node.
Definition: libio.h:462
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_mount.c:41
int(* rtems_filesystem_clonenode_t)(rtems_filesystem_location_info_t *loc)
Clones a location.
Definition: libio.h:249
void rtems_filesystem_default_freenode(const rtems_filesystem_location_info_t *loc)
Definition: default_freenode.c:43
ssize_t(* rtems_filesystem_readlink_t)(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Reads the contents of a symbolic link.
Definition: libio.h:442
void rtems_filesystem_default_fsunmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition: default_fsunmount.c:39
int(* rtems_filesystem_mknod_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev)
Creates a new node.
Definition: libio.h:369
bool(* rtems_filesystem_are_nodes_equal_t)(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node of one location is equal to the node of the other location.
Definition: libio.h:348
void(* rtems_filesystem_mt_entry_unlock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Unlocks a file system instance.
void rtems_filesystem_default_eval_path(rtems_filesystem_eval_path_context_t *ctx)
Terminates the path evaluation and replaces the current location with the null location.
Definition: default_eval_path.c:42
int rtems_filesystem_default_symlink(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Definition: default_symlink.c:44
int rtems_filesystem_default_statvfs(const rtems_filesystem_location_info_t *loc, struct statvfs *buf)
Definition: default_statvfs.c:42
int(* rtems_filesystem_utimens_t)(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Set node access and modification times.
Definition: libio.h:404
int(* rtems_filesystem_fsmount_me_t)(rtems_filesystem_mount_table_entry_t *mt_entry, const void *data)
Initializes a file system instance.
Definition: libio.h:296
int(* rtems_filesystem_chown_t)(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Changes owner and group of a node.
Definition: libio.h:228
const rtems_filesystem_operations_table rtems_filesystem_operations_default
File system operations table with default operations.
Definition: default_ops.c:38
void(* rtems_filesystem_freenode_t)(const rtems_filesystem_location_info_t *loc)
Frees the location of a node.
Definition: libio.h:260
void(* rtems_filesystem_mt_entry_lock_t)(const rtems_filesystem_mount_table_entry_t *mt_entry)
Locks a file system instance.
Definition: libio.h:85
int rtems_filesystem_default_chown(const rtems_filesystem_location_info_t *loc, uid_t owner, gid_t group)
Definition: default_chown.c:42
ssize_t rtems_filesystem_default_readlink(const rtems_filesystem_location_info_t *loc, char *buf, size_t bufsize)
Definition: default_readlink.c:44
int(* rtems_filesystem_symlink_t)(const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, const char *target)
Makes a symbolic link to a node.
Definition: libio.h:423
int rtems_filesystem_default_link(const rtems_filesystem_location_info_t *parentloc, const rtems_filesystem_location_info_t *targetloc, const char *name, size_t namelen)
Definition: default_link.c:42
int rtems_filesystem_default_utimens(const rtems_filesystem_location_info_t *loc, struct timespec times[2])
Definition: default_utimens.c:43
struct rtems_libio_open_close_args rtems_libio_open_close_args_t
Parameter block for open/close.
rtems_filesystem_fsmount_me_t rtems_filesystem_get_mount_handler(const char *type)
Gets the mount handler for the file system type.
Definition: mount-mgr.c:109
Creates a directory and all its parent directories according to path.
Definition: rtems_mkdir.c:130
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:51
const rtems_filesystem_limits_and_options_t rtems_filesystem_default_pathconf
Default pathconf settings.
Definition: mount.c:49
uint32_t rtems_device_major_number
This integer type represents the major number of devices.
Definition: io.h:103
uint32_t rtems_device_minor_number
This integer type represents the minor number of devices.
Definition: io.h:115
rtems_status_code
Definition: status.h:85
Objects_Id rtems_id
This type represents RTEMS object identifiers.
Definition: types.h:94
rtems_termios_iproc_status_code rtems_termios_default_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
Default handler for ISIG (VINTR/VKILL)
Definition: termios.c:1312
rtems_termios_iproc_status_code(* rtems_termios_isig_handler)(unsigned char c, struct rtems_termios_tty *tty)
Type for ISIG (VINTR/VKILL) handler.
Definition: libio.h:1974
The status code returned by all Termios input processing (iproc) functions and input signal (isig) ha...
Definition: libio.h:1929
rtems_status_code rtems_termios_register_isig_handler(rtems_termios_isig_handler handler)
Register handler for ISIG (VINTR/VKILL)
Definition: termios.c:1324
rtems_termios_iproc_status_code rtems_termios_posix_isig_handler(unsigned char c, struct rtems_termios_tty *tty)
POSIX handler for ISIG (VINTR/VKILL)
Definition: termios_posix_isig_handler.c:23
@ RTEMS_TERMIOS_IPROC_DONE
This status indicates that the input processing is done.
Definition: libio.h:1955
@ RTEMS_TERMIOS_IPROC_CONTINUE
This status indicates that the input processing can continue.
Definition: libio.h:1936
@ RTEMS_TERMIOS_IPROC_INTERRUPT
This status indicates that the input processing should stop due to a signal.
Definition: libio.h:1948
rtems_termios_device_handler handler
The device handler.
Definition: termiostypes.h:166
Basic Filesystem Types.
This header file provides the interfaces of the Atomic Operations.
This header file provides the statvfs() and fstatvfs() interfaces.
This structure represents a chain node.
Definition: chain.h:78
Definition: xnandpsu_onfi.h:181
File system node operations table.
Definition: libio.h:1021
File system operations table.
Definition: libio.h:489
Definition: iterateoverthreads.c:44
Path evaluation context.
Definition: libio.h:103
int recursionlevel
Definition: libio.h:145
rtems_filesystem_location_info_t currentloc
Definition: libio.h:154
const char * path
Definition: libio.h:107
size_t pathlen
Definition: libio.h:112
rtems_filesystem_global_location_t * rootloc
Definition: libio.h:160
size_t tokenlen
Definition: libio.h:124
const char * token
Definition: libio.h:118
int flags
Definition: libio.h:138
rtems_filesystem_global_location_t * startloc
Global file system location.
Definition: fs.h:100
Contain file system specific information which is required to support fpathconf().
Definition: libio.h:1307
File system location.
Definition: fs.h:72
Definition: libio.h:1874
Mount table entry.
Definition: libio.h:1622
rtems_id unmount_task
Definition: libio.h:1660
File system table entry.
Definition: libio.h:1675
Parameter block for ioctl.
Definition: libio.h:1373
Definition: libio.h:1364
Paramameter block for read/write.
Definition: libio.h:1352
An open file data structure.
Definition: libio.h:1338
Definition: libio.h:1898
Definition: termiostypes.h:94
Definition: statvfs.h:56
This header file provides the interfaces of the RTEMS Termios Device Support.
This union represents a chain control block.
Definition: chain.h:96
Definition: libio.h:1508
