RTEMS 6.1-rc2
This source file contains the implementation of rtems_interrupt_get_attributes(), rtems_interrupt_vector_is_enabled(), rtems_interrupt_vector_enable() and rtems_interrupt_vector_disable(). More...
rtems_status_code | rtems_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes) |
Gets the attributes of the interrupt vector. | |
rtems_status_code | rtems_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled) |
Checks if the interrupt vector is enabled. | |
rtems_status_code | rtems_interrupt_vector_enable (rtems_vector_number vector) |
Enables the interrupt vector. | |
rtems_status_code | rtems_interrupt_vector_disable (rtems_vector_number vector) |
Disables the interrupt vector. | |
