This group contains the Chain Handler implementation.
More...
The Chain Handler is used to manage sets of entities. This handler provides two data structures. The Chain Node data structure is included as the first part of every data structure that will be placed on a chain. The second data structure is Chain Control which is used to manage a set of Chain Nodes.
◆ CHAIN_INITIALIZER_ONE_NODE
#define CHAIN_INITIALIZER_ONE_NODE |
node | ) |
{ { { (node), NULL }, (node) } } |
◆ CHAIN_ITERATOR_REGISTRY_INITIALIZER
Chain iterator registry initializer for static initialization.
- Parameters
name | The designator of the chain iterator registry. |
◆ CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN
#define CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN |
chain | ) |
{ &(chain)->Tail.Node, &(chain)->Head.Node } |
◆ Chain_Node
This structure represents a chain node.
This is used to manage each element (node) which is placed on a chain.
- Note
- Typically, a more complicated structure will use the chain package. The more complicated structure will include a chain node as the first element in its control structure. It will then call the chain package with a pointer to that node element. The node pointer and the higher level structure start at the same address so the user can cast the pointers back and forth.
◆ Chain_Node_order
Chain node order.
- Parameters
left | The left hand side. |
right | The right hand side. |
- Return values
true | According to the order the left node precedes the right node. |
false | Otherwise. |
◆ Chain_Iterator_direction
The chain iterator direction.
Enumerator |
CHAIN_ITERATOR_FORWARD | Iteration from head to tail.
CHAIN_ITERATOR_BACKWARD | Iteration from tail to head.
◆ _Chain_Initialize()
void _Chain_Initialize |
Chain_Control * |
the_chain, |
void * |
starting_address, |
size_t |
number_nodes, |
size_t |
node_size |
Initializes a chain header.
This routine initializes the_chain structure to manage the contiguous array of number_nodes nodes which starts at starting_address. Each node is of node_size bytes.
- Parameters
[out] | the_chain | Specifies the chain to initialize. |
| starting_address | The starting address of the array of elements. |
| number_nodes | The number of nodes that will be in the chain. |
| node_size | The size of each node. |
◆ _Chain_Node_count_unprotected()
size_t _Chain_Node_count_unprotected |
const Chain_Control * |
chain | ) |
Returns the node count of the chain.
- Parameters
chain | The chain to return the node count from. |
- Note
- It does NOT disable interrupts to ensure the atomicity of the operation.
- Returns
- The node count of the chain.
