RTEMS 6.1-rc2
Files | Data Structures | Macros | Typedefs | Enumerations | Functions
Message Queue Handler
This group contains the Message Queue Handler implementation. More...
file  coremsg.h
 This header file provides interfaces of the Message Queue Handler which are only used by the implementation.
file  coremsgbuffer.h
 This header file provides interfaces of the Message Queue Handler which are used by the implementation, the Application Configuration, and the API.
file  coremsgimpl.h
 This header file provides interfaces of the Message Queue Handler which are used by the implementation and the Application Configuration.
file  coremsg.c
 This source file contains the implementation of _CORE_message_queue_Initialize().
file  coremsgbroadcast.c
 This source file contains the implementation of _CORE_message_queue_Broadcast().
file  coremsgclose.c
 This source file contains the implementation of _CORE_message_queue_Close().
file  coremsgflush.c
 This source file contains the implementation of _CORE_message_queue_Flush().
file  coremsgflushwait.c
 This source file contains the implementation of _CORE_message_queue_Flush_waiting_threads().
file  coremsginsert.c
 This source file contains the implementation of _CORE_message_queue_Insert_message().
file  coremsgseize.c
 This source file contains the implementation of _CORE_message_queue_Seize().
file  coremsgsubmit.c
 This source file contains the implementation of _CORE_message_queue_Submit().
file  coremsgwkspace.c
 This source file contains the implementation of _CORE_message_queue_Workspace_allocate().
struct  CORE_message_queue_Control
 Control block used to manage each message queue. More...
struct  CORE_message_queue_Buffer
 The structure is used to organize message buffers of a message queue. More...
#define RTEMS_SCORE_COREMSG_ENABLE_BLOCKING_SEND
#define RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY
#define CORE_MESSAGE_QUEUE_SEND_REQUEST   INT_MAX
 Used when appending messages onto a message queue.
#define CORE_MESSAGE_QUEUE_URGENT_REQUEST   INT_MIN
 Used when prepending messages onto a message queue.
#define _CORE_message_queue_Set_notify(the_message_queue, the_handler)    do { } while ( 0 )
 Initializes notification information.
typedef struct CORE_message_queue_Control CORE_message_queue_Control
typedef int CORE_message_queue_Submit_types
 The modes in which a message may be submitted to a message queue.
typedef void *(* CORE_message_queue_Allocate_buffers) (CORE_message_queue_Control *the_message_queue, size_t size, const void *arg)
 This handler shall allocate the message buffer storage area for a message queue.
enum  CORE_message_queue_Disciplines { CORE_MESSAGE_QUEUE_DISCIPLINES_FIFO , CORE_MESSAGE_QUEUE_DISCIPLINES_PRIORITY }
 The possible blocking disciplines for a message queue. More...
void * _CORE_message_queue_Workspace_allocate (CORE_message_queue_Control *the_message_queue, size_t size, const void *arg)
 This handler allocates the message buffer storage area for a message queue from the RTEMS Workspace.
Status_Control _CORE_message_queue_Initialize (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Disciplines discipline, uint32_t maximum_pending_messages, size_t maximum_message_size, CORE_message_queue_Allocate_buffers allocate_buffers, const void *arg)
 Initializes a message queue.
void _CORE_message_queue_Close (CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
 Closes a message queue.
uint32_t _CORE_message_queue_Flush (CORE_message_queue_Control *the_message_queue, Thread_queue_Context *queue_context)
 Flushes pending messages.
Status_Control _CORE_message_queue_Broadcast (CORE_message_queue_Control *the_message_queue, const void *buffer, size_t size, uint32_t *count, Thread_queue_Context *queue_context)
 Broadcasts a message to the message queue.
Status_Control _CORE_message_queue_Submit (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, const void *buffer, size_t size, CORE_message_queue_Submit_types submit_type, bool wait, Thread_queue_Context *queue_context)
 Submits a message to the message queue.
Status_Control _CORE_message_queue_Seize (CORE_message_queue_Control *the_message_queue, Thread_Control *executing, void *buffer, size_t *size_p, bool wait, Thread_queue_Context *queue_context)
 Seizes a message from the message queue.
void _CORE_message_queue_Insert_message (CORE_message_queue_Control *the_message_queue, CORE_message_queue_Buffer *the_message, const void *content_source, size_t content_size, CORE_message_queue_Submit_types submit_type)
 Inserts a message into the message queue.
This handler encapsulates functionality which provides the foundation Message Queue services used in all of the APIs supported by RTEMS.
◆ _CORE_message_queue_Set_notify
#define _CORE_message_queue_Set_notify (   the_message_queue,
  the_handler
This routine initializes the notification information for the_message_queue.
Parameters
[out]the_message_queueThe message queue to initialize the notification information.
[out]the_handlerThe notification information for the message queue.
◆ CORE_MESSAGE_QUEUE_SEND_REQUEST
This is the priority constant used when appending messages onto a message queue.
◆ CORE_MESSAGE_QUEUE_URGENT_REQUEST
This is the priority constant used when prepending messages onto a message queue.
◆ RTEMS_SCORE_COREMSG_ENABLE_BLOCKING_SEND
This macro is defined when an API is enabled that requires the Message Queue Handler include support for blocking send operations.
◆ RTEMS_SCORE_COREMSG_ENABLE_MESSAGE_PRIORITY
This define enables the support for priority based enqueuing of messages in the Message Queue Handler.
Typedef Documentation
◆ CORE_message_queue_Allocate_buffers
The handler shall set the CORE_message_queue_Control::free_message_buffers member.
Parameters
[out]the_message_queueis the message queue control.
sizeis the message buffer storage area size to allocate.
argis the handler argument.
Return values
NULLThe allocation failed.
Returns
Otherwise the pointer to the allocated message buffer storage area begin shall be returned.
◆ CORE_message_queue_Submit_types
The following type details the modes in which a message may be submitted to a message queue. The message may be posted in a send or urgent fashion.
Note
All other values are message priorities. Numerically smaller priorities indicate higher priority messages.
◆ CORE_message_queue_Disciplines
This enumerated types defines the possible blocking disciplines for a message queue.
This value indicates that blocking tasks are in FIFO order.
This value indicates that blocking tasks are in priority order.
◆ _CORE_message_queue_Broadcast()
Status_Control _CORE_message_queue_Broadcast ( CORE_message_queue_Control the_message_queue,
const void *  buffer,
size_t  size,
uint32_t *  count,
Thread_queue_Context queue_context
This package is the implementation of the CORE Message Queue Handler. This core object provides task synchronization and communication functions via messages passed to queue objects.
This function sends a message for every thread waiting on the queue and returns the number of threads made ready by the message.
Parameters
[in,out]the_message_queueThe message queue to operate upon.
bufferThe starting address of the message to broadcast.
sizeThe size of the message being broadcast.
[out]countThe variable that will contain the number of tasks that are sent this message.
queue_contextThe thread queue context used for _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
Return values
STATUS_SUCCESSFULThe message was successfully broadcast.
STATUS_MESSAGE_INVALID_SIZEThe message size was too big.
◆ _CORE_message_queue_Close()
void _CORE_message_queue_Close ( CORE_message_queue_Control the_message_queue,
This function closes a message by returning all allocated space and flushing the_message_queue's task wait queue.
Parameters
[in,out]the_message_queueThe message queue to close.
[in,out]queue_contextThe thread queue context used for _CORE_message_queue_Acquire() or _CORE_message_queue_Acquire_critical().
◆ _CORE_message_queue_Flush()
uint32_t _CORE_message_queue_Flush ( CORE_message_queue_Control the_message_queue,
This function flushes the_message_queue's pending message queue. The number of messages flushed from the queue is returned.
Parameters
[in,out]the_message_queueThe message queue to flush.
queue_contextThe thread queue context with interrupts disabled.
Returns
This method returns the number of message pending messages flushed.
◆ _CORE_message_queue_Initialize()
Status_Control _CORE_message_queue_Initialize ( CORE_message_queue_Control the_message_queue,
const void *  arg
Parameters
[out]the_message_queueis the message queue to initialize.
disciplineis the blocking discipline for the message queue.
maximum_pending_messagesis the maximum number of messages that will be allowed to be pending at any given time.
maximum_message_sizeis the size of the largest message that may be sent to this message queue instance.
allocate_buffersis the message buffer storage area allocation handler.
argis the message buffer storage area allocation handler argument.
Return values
STATUS_SUCCESSFULThe message queue was initialized.
STATUS_MESSAGE_QUEUE_INVALID_SIZECalculations with the maximum pending messages or maximum message size produced an integer overflow.
STATUS_MESSAGE_QUEUE_NO_MEMORYThe message buffer storage area allocation failed.
◆ _CORE_message_queue_Insert_message()
void _CORE_message_queue_Insert_message ( CORE_message_queue_Control the_message_queue,
CORE_message_queue_Buffer the_message,
const void *  content_source,
Copies the specified content into the message storage space and then inserts the message into the message queue according to the submit type.
Parameters
[in,out]the_message_queueThe message queue to insert a message in.
[in,out]the_messageThe message to insert in the message queue.
content_sourceThe message content source.
content_sizeThe message content size in bytes.
submit_typeDetermines whether the message is prepended, appended, or enqueued in priority order.
◆ _CORE_message_queue_Seize()
Status_Control _CORE_message_queue_Seize ( CORE_message_queue_Control the_message_queue,
Thread_Control executing,
void *  buffer,
size_t *  size_p,
bool  wait,
This kernel routine dequeues a message, copies the message buffer to a given destination buffer, and frees the message buffer to the inactive message pool. The thread will be blocked if wait is true, otherwise an error will be given to the thread if no messages are available.
Parameters
[in,out]the_message_queueThe message queue to seize a message from.
executingThe executing thread.
[out]bufferThe starting address of the message buffer to to be filled in with a message.
[out]size_pThe size of the buffer, indicates the maximum size message that the caller can receive.
waitIndicates whether the calling thread is willing to block if the message queue is empty.
Return values
STATUS_SUCCESSFULThe message was successfully seized from the message queue.
STATUS_UNSATISFIEDWait was set to false and there is currently no pending message.
STATUS_TIMEOUTA timeout occurred.
Note
Returns message priority via return area in TCB.
  • INTERRUPT LATENCY:
    • available
    • wait
◆ _CORE_message_queue_Submit()
Status_Control _CORE_message_queue_Submit ( CORE_message_queue_Control the_message_queue,
size_t  size,
bool  wait,
This routine implements the send and urgent message functions. It processes a message that is to be submitted to the designated message queue. The message will either be processed as a send message which it will be inserted at the rear of the queue or it will be processed as an urgent message which will be inserted at the front of the queue.
Parameters
bufferThe starting address of the message to send.
sizeThe size of the message being send.
waitIndicates whether the calling thread is willing to block if the message queue is full.
Return values
STATUS_SUCCESSFULThe message was successfully submitted to the message queue.
STATUS_TOO_MANYNo message buffers were available.
STATUS_MESSAGE_QUEUE_WAIT_IN_ISRThe caller is in an ISR, do not block!
◆ _CORE_message_queue_Workspace_allocate()
void * _CORE_message_queue_Workspace_allocate ( CORE_message_queue_Control the_message_queue,
size_t  size,
const void *  arg
The handler sets the CORE_message_queue_Control::free_message_buffers to _Workspace_Free().
Parameters
argis the unused handler argument.
Return values
Returns
Otherwise the pointer to the allocated message buffer storage area begin is returned.
