RTEMS 6.1-rc2
RTEMS no cpu Build Information
#define MIPS_HAS_FPU   1
#define CPU_NAME   "MIPS"
#define MIPS_EXCEPTION_BASE   0
#define MIPS_EXCEPTION_INT   MIPS_EXCEPTION_BASE+0
#define MIPS_EXCEPTION_MOD   MIPS_EXCEPTION_BASE+1
#define MIPS_EXCEPTION_TLBL   MIPS_EXCEPTION_BASE+2
#define MIPS_EXCEPTION_TLBS   MIPS_EXCEPTION_BASE+3
#define MIPS_EXCEPTION_ADEL   MIPS_EXCEPTION_BASE+4
#define MIPS_EXCEPTION_ADES   MIPS_EXCEPTION_BASE+5
#define MIPS_EXCEPTION_IBE   MIPS_EXCEPTION_BASE+6
#define MIPS_EXCEPTION_DBE   MIPS_EXCEPTION_BASE+7
#define MIPS_EXCEPTION_SYSCALL   MIPS_EXCEPTION_BASE+8
#define MIPS_EXCEPTION_BREAK   MIPS_EXCEPTION_BASE+9
#define MIPS_EXCEPTION_RI   MIPS_EXCEPTION_BASE+10
#define MIPS_EXCEPTION_CPU   MIPS_EXCEPTION_BASE+11
#define MIPS_EXCEPTION_OVERFLOW   MIPS_EXCEPTION_BASE+12
#define MIPS_EXCEPTION_TRAP   MIPS_EXCEPTION_BASE+13
#define MIPS_EXCEPTION_VCEI   MIPS_EXCEPTION_BASE+14
#define MIPS_EXCEPTION_FPE   MIPS_EXCEPTION_BASE+15
#define MIPS_EXCEPTION_C2E   MIPS_EXCEPTION_BASE+16
#define MIPS_EXCEPTION_WATCH   MIPS_EXCEPTION_BASE+23
#define MIPS_EXCEPTION_VCED   MIPS_EXCEPTION_BASE+31
#define MIPS_INTERRUPT_BASE   MIPS_EXCEPTION_BASE+32
#define mips_get_sr(_x)
#define mips_set_sr(_x)
#define mips_get_cause(_x)
#define mips_set_cause(_x)
#define mips_get_dcic(_x)
#define mips_set_dcic(_x)
#define mips_get_bpcrm(_x, _y)
#define mips_set_bpcrm(_x, _y)
#define mips_get_bdarm(_x, _y)
#define mips_set_bdarm(_x, _y)
#define mips_get_fcr31(_x)
#define mips_set_fcr31(_x)
#define mips_enable_in_interrupt_mask(_mask)
#define mips_disable_in_interrupt_mask(_mask)
◆ mips_disable_in_interrupt_mask
#define mips_disable_in_interrupt_mask (   _mask)
Value:
do { \
unsigned int _sr; \
mips_get_sr( _sr ); \
_sr &= ~(_mask); \
mips_set_sr( _sr ); \
} while (0)
◆ mips_enable_in_interrupt_mask
#define mips_enable_in_interrupt_mask (   _mask)
Value:
do { \
unsigned int _sr; \
_sr |= (_mask); \
} while (0)
◆ mips_get_bdarm
#define mips_get_bdarm (   _x,
  _y
Value:
do { \
__asm__ volatile( "mfc0 %0, $5; nop" : "=r" (_x) : ); \
__asm__ volatile( "mfc0 %0, $9; nop" : "=r" (_y) : ); \
} while (0)
◆ mips_get_bpcrm
#define mips_get_bpcrm (   _x,
  _y
Value:
do { \
__asm__ volatile( "mfc0 %0, $3; nop" : "=r" (_x) : ); \
__asm__ volatile( "mfc0 %0, $11; nop" : "=r" (_y) : ); \
} while (0)
◆ mips_get_cause
#define mips_get_cause (   _x)
Value:
do { \
__asm__ volatile( "mfc0 %0, $13; nop" : "=r" (_x) : ); \
} while (0)
◆ mips_get_dcic
#define mips_get_dcic (   _x)
Value:
do { \
__asm__ volatile( "mfc0 %0, $7; nop" : "=r" (_x) : ); \
} while (0)
◆ mips_get_fcr31
#define mips_get_fcr31 (   _x)
Value:
do { \
__asm__ volatile( "cfc1 %0, $31; nop" : "=r" (_x) : ); \
} while(0)
◆ mips_get_sr
#define mips_get_sr (   _x)
Value:
do { \
__asm__ volatile( "mfc0 %0, $12; nop" : "=r" (_x) : ); \
} while (0)
◆ mips_set_bdarm
#define mips_set_bdarm (   _x,
  _y
Value:
do { \
unsigned int __x = (_x); \
unsigned int __y = (_y); \
__asm__ volatile( "mtc0 %0, $9; nop" : : "r" (__y) ); \
__asm__ volatile( "mtc0 %0, $5; nop" : : "r" (__x) ); \
} while (0)
◆ mips_set_bpcrm
#define mips_set_bpcrm (   _x,
  _y
Value:
do { \
__asm__ volatile( "mtc0 %0, $11; nop" : : "r" (__y) ); \
__asm__ volatile( "mtc0 %0, $3; nop" : : "r" (__x) ); \
} while (0)
◆ mips_set_cause
#define mips_set_cause (   _x)
Value:
do { \
__asm__ volatile( "mtc0 %0, $13; nop" : : "r" (__x) ); \
} while (0)
◆ mips_set_dcic
#define mips_set_dcic (   _x)
Value:
do { \
__asm__ volatile( "mtc0 %0, $7; nop" : : "r" (__x) ); \
} while (0)
◆ mips_set_fcr31
#define mips_set_fcr31 (   _x)
Value:
do { \
__asm__ volatile( "ctc1 %0, $31; nop" : : "r" (__x) ); \
} while(0)
◆ mips_set_sr
#define mips_set_sr (   _x)
Value:
do { \
__asm__ volatile( "mtc0 %0, $12; nop" : : "r" (__x) ); \
} while (0)
