RTEMS 6.1-rc2
MIPS Architecture Support. More...
Modules | |
CPU Related Definitions | |
RTEMS no cpu Build Information | |
Register Structure | |
struct | Context_Control |
Thread register context. More... | |
struct | Context_Control_fp |
SPARC basic context. More... | |
struct | CPU_Interrupt_frame |
Interrupt stack frame (ISF). More... | |
#define | CPU_SIMPLE_VECTORED_INTERRUPTS FALSE |
#define | CPU_ISR_PASSES_FRAME_POINTER TRUE |
#define | CPU_HARDWARE_FP FALSE |
#define | CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP |
#define | CPU_IDLE_TASK_IS_FP FALSE |
#define | CPU_USE_DEFERRED_FP_SWITCH TRUE |
#define | CPU_ENABLE_ROBUST_THREAD_DISPATCH FALSE |
#define | CPU_STACK_GROWS_UP FALSE |
#define | CPU_CACHE_LINE_BYTES 16 |
#define | CPU_STRUCTURE_ALIGNMENT RTEMS_ALIGNED( CPU_CACHE_LINE_BYTES ) |
#define | CPU_MODES_INTERRUPT_MASK 0x000000ff |
#define | CPU_SIZEOF_POINTER 4 |
#define | CPU_MAXIMUM_PROCESSORS 32 |
#define | _CPU_Context_Get_SP(_context) (uintptr_t) (_context)->sp |
#define | CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp ) |
#define | CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0 |
#define | CPU_STACK_MINIMUM_SIZE (8 * 1024) |
#define | CPU_ALIGNMENT 8 |
#define | CPU_HEAP_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_STACK_ALIGNMENT CPU_ALIGNMENT |
#define | CPU_INTERRUPT_STACK_ALIGNMENT CPU_CACHE_LINE_BYTES |
#define | _CPU_ISR_Disable(_level) |
#define | _CPU_ISR_Enable(_level) |
#define | _CPU_ISR_Flash(_xlevel) |
#define | _CPU_Context_Restart_self(_the_context) _CPU_Context_restore( (_the_context) ); |
#define | _CPU_Context_Initialize_fp(_destination) |
#define | CPU_USE_GENERIC_BITFIELD_CODE TRUE |
#define | CPU_USE_LIBC_INIT_FINI_ARRAY FALSE |
#define | CPU_swap_u16(value) (((value&0xff) << 8) | ((value >> 8)&0xff)) |
#define | CPU_PER_CPU_CONTROL_SIZE 0 |
#define | CPU_THREAD_LOCAL_STORAGE_VARIANT 10 |
Typedefs | |
typedef CPU_Interrupt_frame | CPU_Exception_frame |
typedef uint32_t | CPU_Counter_ticks |
typedef uintptr_t | CPU_Uint32ptr |
void | mips_vector_exceptions (CPU_Interrupt_frame *frame) |
uint32_t | mips_interrupt_mask (void) |
uint32_t | _CPU_ISR_Get_level (void) |
void | _CPU_ISR_Set_level (uint32_t) |
Sets the hardware interrupt level by the level value. | |
void | _CPU_Context_Initialize (Context_Control *the_context, uintptr_t *stack_base, uint32_t size, uint32_t new_level, void *entry_point, bool is_fp, void *tls_area) |
void | mips_break (int error) |
void | _CPU_Initialize (void) |
CPU initialization. | |
void * | _CPU_Thread_Idle_body (uintptr_t ignored) |
void | _CPU_Context_switch (Context_Control *run, Context_Control *heir) |
CPU switch context. | |
RTEMS_NO_RETURN void | _CPU_Context_restore (Context_Control *new_context) |
void | _CPU_Context_save_fp (Context_Control_fp **fp_context_ptr) |
void | _CPU_Context_restore_fp (Context_Control_fp **fp_context_ptr) |
void | _CPU_Exception_frame_print (const CPU_Exception_frame *frame) |
uint32_t | _CPU_Counter_frequency (void) |
CPU_Counter_ticks | _CPU_Counter_read (void) |
RTEMS_NO_RETURN void | _CPU_Fatal_halt (uint32_t source, CPU_Uint32ptr error) |
Context_Control_fp | _CPU_Null_fp_context |
#define _CPU_Context_Initialize_fp | ( | _destination | ) |
#define _CPU_ISR_Disable | ( | _level | ) |
#define _CPU_ISR_Enable | ( | _level | ) |
#define _CPU_ISR_Flash | ( | _xlevel | ) |
typedef uintptr_t CPU_Uint32ptr |
Type that can store a 32-bit integer or a pointer.
RTEMS_NO_RETURN void _CPU_Context_restore | ( | Context_Control * | new_context | ) |
This routine is generally used only to restart self in an efficient manner. It may simply be a label in _CPU_Context_switch.
[in] | new_context | points to the context to be restored. |
Port Specific Information:
XXX document implementation including references if appropriate
void _CPU_Context_switch | ( | Context_Control * | run, |
Context_Control * | heir | ||
CPU switch context.
This routine switches from the run context to the heir context.
[in] | run | points to the context of the currently executing task |
[in] | heir | points to the context of the heir task |
void _CPU_Exception_frame_print | ( | const CPU_Exception_frame * | frame | ) |
This method prints the CPU exception frame.
[in] | frame | points to the frame to be printed |
RTEMS_NO_RETURN void _CPU_Fatal_halt | ( | uint32_t | source, |
CPU_Uint32ptr | error | ||
COPYRIGHT (c) 2016. On-Line Applications Research Corporation (OAR).
Redistribution and use in source and binary forms, with or without modification, are permitted provided that the following conditions are met:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
void _CPU_Initialize | ( | void | ) |
CPU initialization.
CPU initialize. This routine performs CPU dependent initialization.
CPU initialization.
uint32_t _CPU_ISR_Get_level | ( | void | ) |
Return the current interrupt disable level for this task in the format used by the interrupt level portion of the task mode.
void _CPU_ISR_Set_level | ( | uint32_t | level | ) |
[in] | level | for or1k can only range over two values: 0 (enable interrupts) and 1 (disable interrupts). In future implementations if fast context switch is implemented, the level can range from 0 to 15. |
