RTEMS 6.1-rc2
Files | Macros | Typedefs | Functions | Variables
LEON2 Board Support Package. More...
file  leon2_amba_bus.h
 This header file provides interfaces of the LEON2 Hardcoded bus driver.
file  btimer.c
 Implement a benchmark timer using timer 2.
file  ckinit.c
 Clock Tick Device Driver.
file  console.c
 TTY driver driver for the serial ports on the LEON console.
file  debugputs.c
 TTY driver for the serial ports on the LEON.
file  gnatsupp.c
 Support for gnat/rtems iterrupts and exception handling.
file  bsp.h
 Global BSP definitions.
file  irq.h
 Interrupts definitions.
file  irqimpl.h
 This header file provides interfaces used by the interrupt support implementation.
file  leon.h
file  tm27.h
 Implementations for interrupt mechanisms for Time Test 27.
file  bspdelay.c
 LEON2 BSP Delay Method.
file  bspidle.c
 LEON2 Idle Thread.
file  bspstart.c
 LEON2 Cache Snooping Support.
file  setvec.c
 Installs an interrupt vector on the SPARC simulator.
#define LEON2   1
#define BSP_FEATURE_IRQ_EXTENSION
#define BSP_IDLE_TASK_BODY   bsp_idle_thread
#define RTEMS_BSP_NETWORK_DRIVER_NAME   "open_eth1"
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_OPENETH    rtems_leon_open_eth_driver_attach
#define RTEMS_BSP_NETWORK_DRIVER_ATTACH_SMC91111    rtems_smc91111_driver_attach_leon2
#define HAS_SMC91111
#define GRETH_SUPPORTED
#define GRETH_MEM_LOAD(addr)   leon_r32_no_cache((uintptr_t) addr)
#define BSP_PCI_BIG_ENDIAN
#define AMBAPPBUS_INFO_AVAIL   /* AMBAPP Bus driver */
#define GPTIMER_INFO_AVAIL   /* GPTIMER Timer driver */
#define GRETH_INFO_AVAIL   /* GRETH Ethernet driver */
typedef void(* bsp_shared_isr) (void *arg)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
int rtems_leon_open_eth_driver_attach (struct rtems_bsdnet_ifconfig *config)
int rtems_smc91111_driver_attach_leon2 (struct rtems_bsdnet_ifconfig *config)
rtems_isr_entry set_vector (rtems_isr_entry handler, rtems_vector_number vector, int type)
 Install an interrupt handler.
void BSP_fatal_exit (uint32_t error)
void rtems_bsp_delay (int usecs)
int cchip1_register (void)
void console_outbyte_polled (int port, unsigned char ch)
int console_inbyte_nonblocking (int port)
int CPU_SPARC_HAS_SNOOPING
int RAM_START
int RAM_END
int RAM_SIZE
int PROM_START
int PROM_END
int PROM_SIZE
int CLOCK_SPEED
int end
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t  ignored)
This BSP provides its own IDLE thread to override the RTEMS one.
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
#include <bsp.h>
◆ console_inbyte_nonblocking()
int console_inbyte_nonblocking ( int  port)
This method polls the specified port for an input character. console port.
Parameters
[in]portis the input port
Returns
This method returns the character read of -1 if there is no data.
◆ set_vector()
rtems_isr_entry set_vector ( rtems_isr_entry  handler,
int  type
This method installs an interrupt handle.
Parameters
[in]handleris the isr routine
[in]vectoris the vector number
[in]typeindicates whether RTEMS or RAW intr
Returns
returns old vector
