RTEMS 6.1-rc2
NXP LPC176X Board Support Package. More...
Modules | |
DMA Support | |
Direct memory access (DMA) support. | |
System Clocks | |
System clocks. | |
Files | |
file | btimer.c |
Timer benchmark functions for the lpc176x bsp. | |
file | can.c |
CAN controller for the mbed lpc1768 board. | |
file | console-config.c |
Console configuration. | |
file | lpc-gpio.c |
GPIO library for the lpc176x bsp. | |
file | bsp.h |
Global BSP definitions. | |
file | adc-defs.h |
ADC library for the lpc176x bsp. | |
file | adc.h |
file | can-defs.h |
CAN controller for the lpc176x controller. | |
file | can.h |
file | common-types.h |
Definitions types used by some devices in common. | |
file | gpio-defs.h |
API definitions of the GPIO driver for the lpc176x bsp in RTEMS. | |
file | io-defs.h |
Input/output module definitions. | |
file | io.h |
Input/output module methods definitions. | |
file | lpc-clock-config.h |
Clock driver configuration. | |
file | lpc-gpio.h |
API of the GPIO driver for the lpc176x bsp in RTEMS. | |
file | lpc176x.h |
Specific register definitions according to lpc176x family boards. | |
file | mbed-pinmap.h |
Pins of the mbed lpc1768 See http://mbed.org/media/uploads/chris/mbed-005.1.pdf for references. | |
file | pwmout-defs.h |
PWM-Out controller for the mbed lpc1768 board. | |
file | pwmout.h |
file | timer-defs.h |
API definitions of the for the timer of the lpc176x bsp. | |
file | timer.h |
Timer API for the lpc176x bsp. | |
file | watchdog-defs.h |
API definitions of the Watchdog driver for the lpc176x bsp in RTEMS. | |
file | watchdog.h |
API of the Watchdog driver for the lpc176x bsp in RTEMS. | |
file | pwmout.c |
file | rtc-config.c |
RTC configuration. | |
file | adc.c |
file | bspidle.c |
Idle task. | |
file | bspstart.c |
Startup code. | |
file | bspstarthooks.c |
First configurations and initializations to the correct functionality of the board. | |
file | io.c |
Input/output module methods. | |
file | restart.c |
Restart implementation. | |
file | watchdog.c |
Watchdog controller for the mbed lpc176x family boards. | |
file | timer.c |
Timer controller for the mbed lpc1768 board. | |
void * | bsp_idle_thread (uintptr_t ignored) |
Optimized idle task. | |
void | bsp_restart (const void *addr) |
Restarts the bsp with "addr" address. | |
void * bsp_idle_thread | ( | uintptr_t | ignored | ) |
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
The MSR[POW] bit is set to put the CPU into the low power mode defined in HID0. HID0 is set during starup in start.S.
void bsp_restart | ( | const void * | addr | ) |
addr | Address used to restart the bsp |
