RTEMS 6.1-rc2
mpc55xx Directory Reference
file  dspi.h [code]
 Header file for the LibI2C bus driver for the Deserial Serial Peripheral Interface (DSPI).
file  edma.h [code]
 Enhanced Direct Memory Access (eDMA).
file  emios.h [code]
 Enhanced Modular Input Output Subsystem (eMIOS).
file  fsl-mpc551x.h [code]
file  fsl-mpc555x.h [code]
file  fsl-mpc556x.h [code]
file  fsl-mpc564xL.h [code]
file  fsl-mpc5668.h [code]
file  fsl-mpc567x.h [code]
file  mpc55xx.h [code]
 Documentation for this file.
file  reg-defs.h [code]
 Register definitions.
file  regs-edma.h [code]
file  regs-mmu.h [code]
file  regs.h [code]
 Register definitions for the MPC55xx and MPC56xx microcontroller family.
file  siu.h [code]
 System Integration Unit Access (SIU).
file  watchdog.h [code]
 Header file for the watchdog timer.
