RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions | Variables
threadimpl.h File Reference
This header file provides interfaces of the Thread Handler which are only used by the implementation. More...
#include <rtems/score/interr.h>
#include <rtems/score/isr.h>
#include <rtems/score/schedulernodeimpl.h>
#include <rtems/score/status.h>
#include <rtems/score/sysstate.h>
#include <rtems/score/timestampimpl.h>
#include <rtems/config.h>
struct  Thread_Zombie_registry
 The thread zombie registry is used to register threads in the STATES_ZOMBIE state. More...
struct  Thread_Configuration
 The configuration of a new thread to initialize. More...
#define THREAD_WAIT_STATE_MASK   0xffU
 Mask to get the thread wait state flags.
#define THREAD_WAIT_STATE_READY   0x0U
 Indicates that the thread does not wait on something. More...
#define THREAD_WAIT_STATE_INTEND_TO_BLOCK   0x1U
 Indicates that the thread begins with the blocking operation. More...
#define THREAD_WAIT_STATE_BLOCKED   0x2U
 Indicates that the thread completed the blocking operation.
#define THREAD_WAIT_CLASS_MASK   0xff00U
 Mask to get the thread wait class flags.
#define THREAD_WAIT_CLASS_EVENT   0x100U
 Indicates that the thread waits for an event.
#define THREAD_WAIT_CLASS_SYSTEM_EVENT   0x200U
 Indicates that the thread waits for a system event.
#define THREAD_WAIT_CLASS_OBJECT   0x400U
 Indicates that the thread waits for an object.
#define THREAD_WAIT_CLASS_PERIOD   0x800U
 Indicates that the thread waits for a period.
typedef bool(* Thread_Visitor) (Thread_Control *the_thread, void *arg)
enum  Thread_Cancel_state { THREAD_CANCEL_DONE , THREAD_CANCEL_IN_PROGRESS }
 Indicates the resulting state of _Thread_Cancel(). More...
void _Thread_Iterate (Thread_Visitor visitor, void *arg)
 Calls the visitor with all threads and the given argument until it is done. More...
void _Thread_Initialize_information (Thread_Information *information)
 Initializes the thread information. More...
void _Thread_Handler_initialization (void)
 Initializes thread handler. More...
void _Thread_Create_idle (void)
 Creates idle thread. More...
RTEMS_NO_RETURN void _Thread_Start_multitasking (void)
 Starts thread multitasking. More...
Status_Control _Thread_Initialize (Thread_Information *information, Thread_Control *the_thread, const Thread_Configuration *config)
 Initializes thread. More...
void _Thread_Free (Thread_Information *information, Thread_Control *the_thread)
 Frees the thread. More...
Status_Control _Thread_Start (Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
 Starts the specified thread. More...
Status_Control _Thread_Restart (Thread_Control *the_thread, const Thread_Entry_information *entry, ISR_lock_Context *lock_context)
 Restarts the thread. More...
void _Thread_Yield (Thread_Control *executing)
 Yields the currently executing thread. More...
Thread_Life_state _Thread_Change_life (Thread_Life_state life_states_to_clear, Thread_Life_state life_states_to_set, Thread_Life_state ignored_life_states)
 Changes the life of currently executing thread. More...
Thread_Life_state _Thread_Set_life_protection (Thread_Life_state state)
 Set the thread to life protected. More...
void _Thread_Kill_zombies (void)
 Kills all zombie threads in the system. More...
RTEMS_NO_RETURN void _Thread_Exit (void *exit_value, Thread_Life_state life_states_to_set)
 Exits the currently executing thread. More...
Status_Control _Thread_Join (Thread_Control *the_thread, States_Control waiting_for_join, Thread_Control *executing, Thread_queue_Context *queue_context)
 Joins the currently executing thread with the thread. More...
Thread_Cancel_state _Thread_Cancel (Thread_Control *the_thread, Thread_Control *executing, Thread_Life_state life_states_to_clear)
 Cancels the thread. More...
Status_Control _Thread_Close (Thread_Control *the_thread, Thread_Control *executing, Thread_queue_Context *queue_context)
 Closes the thread. More...
States_Control _Thread_Clear_state_locked (Thread_Control *the_thread, States_Control state)
 Clears the specified thread state without locking the lock context. More...
States_Control _Thread_Clear_state (Thread_Control *the_thread, States_Control state)
 Clears the specified thread state. More...
States_Control _Thread_Set_state_locked (Thread_Control *the_thread, States_Control state)
 Sets the specified thread state without locking the lock context. More...
States_Control _Thread_Set_state (Thread_Control *the_thread, States_Control state)
 Sets the specified thread state. More...
void _Thread_Load_environment (Thread_Control *the_thread)
 Initializes enviroment for a thread. More...
void _Thread_Entry_adaptor_idle (Thread_Control *executing)
 Calls the start kinds idle entry of the thread. More...
void _Thread_Entry_adaptor_numeric (Thread_Control *executing)
 Calls the start kinds numeric entry of the thread. More...
void _Thread_Entry_adaptor_pointer (Thread_Control *executing)
 Calls the start kinds pointer entry of the thread. More...
void _Thread_Handler (void)
 Wrapper function for all threads. More...
void _Thread_Priority_perform_actions (Thread_Control *start_of_path, Thread_queue_Context *queue_context)
 Checks if the thread is owner of the lock of the join queue. More...
void _Thread_Priority_add (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Adds the specified thread priority node to the corresponding thread priority aggregation. More...
void _Thread_Priority_remove (Thread_Control *the_thread, Priority_Node *priority_node, Thread_queue_Context *queue_context)
 Removes the specified thread priority node from the corresponding thread priority aggregation. More...
void _Thread_Priority_changed (Thread_Control *the_thread, Priority_Node *priority_node, Priority_Group_order priority_group_order, Thread_queue_Context *queue_context)
 Propagates a thread priority value change in the specified thread priority node to the corresponding thread priority aggregation. More...
void _Thread_Priority_update (Thread_queue_Context *queue_context)
 Updates the priority of all threads in the set. More...
Thread_Control_Thread_Get (Objects_Id id, ISR_lock_Context *lock_context)
 Gets a thread by its identifier. More...
Objects_Id _Thread_Self_id (void)
 Gets the identifier of the calling thread. More...
Timestamp_Control _Thread_Get_CPU_time_used (Thread_Control *the_thread)
 Updates the used cpu time for the heir and dispatches a new heir. More...
Timestamp_Control _Thread_Get_CPU_time_used_locked (Thread_Control *the_thread)
 Gets the used processor time of the thread throughout its entire lifetime if the caller already acquired the thread state and home scheduler locks. More...
Timestamp_Control _Thread_Get_CPU_time_used_after_last_reset (Thread_Control *the_thread)
 Gets the used processor time of the thread after the last CPU usage reset. More...
Objects_Id _Thread_Wait_get_id (const Thread_Control *the_thread)
 Returns the object identifier of the object containing the current thread wait queue. More...
void _Thread_Continue (Thread_Control *the_thread, Status_Control status)
 Cancels a blocking operation so that the thread can continue its execution. More...
void _Thread_Timeout (Watchdog_Control *the_watchdog)
 General purpose thread wait timeout. More...
Status_Control _Thread_Set_name (Thread_Control *the_thread, const char *name)
 Sets the name of the thread. More...
size_t _Thread_Get_name (const Thread_Control *the_thread, char *buffer, size_t buffer_size)
 Gets the name of the thread. More...
Thread_Zombie_registry _Thread_Zombies
 This object is a registry for threads in the STATES_ZOMBIE state. More...
Objects_Id _Thread_Global_constructor
 Object identifier of the global constructor thread. More...
Thread_Control_Thread_Allocated_fp
