RTEMS 6.1-rc1
Files | Macros | Enumerations
Operation Status Support
This group contains the Operation Status Support implementation. More...
file  status.h
 This header file provides the interfaces of the Operation Status Support.
#define STATUS_BUILD(classic_status, posix_status)    ( ( ( posix_status ) * 256 ) | ( classic_status ) )
 Macro to build a status code from Classic and POSIX API parts. More...
#define STATUS_GET_CLASSIC(status)    ( ( status ) & 0xff )
 Macro to get the Classic API status code.
#define STATUS_GET_POSIX(status)    ( ( status ) / 256 )
 Macro to get the POSIX API status code. More...
enum  Status_Classic {
  STATUS_CLASSIC_INCORRECT_STATE = 14 , STATUS_CLASSIC_INTERNAL_ERROR = 25 , STATUS_CLASSIC_INVALID_ADDRESS = 9 , STATUS_CLASSIC_INVALID_ID = 4 ,
  STATUS_CLASSIC_INVALID_NAME = 3 , STATUS_CLASSIC_INVALID_NODE = 21 , STATUS_CLASSIC_INVALID_NUMBER = 10 , STATUS_CLASSIC_INVALID_PRIORITY = 19 ,
  STATUS_CLASSIC_INVALID_SIZE = 8 , STATUS_CLASSIC_NO_MEMORY = 26 , STATUS_CLASSIC_NOT_DEFINED = 11 , STATUS_CLASSIC_NOT_OWNER_OF_RESOURCE = 23 ,
  STATUS_CLASSIC_OBJECT_WAS_DELETED = 7 , STATUS_CLASSIC_PROXY_BLOCKING = 29 , STATUS_CLASSIC_RESOURCE_IN_USE = 12 , STATUS_CLASSIC_SUCCESSFUL = 0 ,
  STATUS_CLASSIC_TIMEOUT = 6 , STATUS_CLASSIC_TOO_MANY = 5 , STATUS_CLASSIC_UNSATISFIED = 13
 Status code parts for the Classic API. More...
enum  Status_Control {
  STATUS_BARRIER_AUTOMATICALLY_RELEASED , STATUS_DEADLOCK , STATUS_FLUSHED , STATUS_INCORRECT_STATE ,
  STATUS_INTERRUPTED , STATUS_INTERNAL_ERROR , STATUS_INVALID_ADDRESS , STATUS_INVALID_ID ,
  STATUS_INVALID_NODE , STATUS_INVALID_NAME , STATUS_INVALID_NUMBER , STATUS_INVALID_PRIORITY ,
  STATUS_INVALID_SIZE , STATUS_MAXIMUM_COUNT_EXCEEDED , STATUS_MESSAGE_INVALID_SIZE , STATUS_MESSAGE_QUEUE_INVALID_NUMBER ,
  STATUS_MESSAGE_QUEUE_INVALID_SIZE , STATUS_MESSAGE_QUEUE_NO_MEMORY , STATUS_MESSAGE_QUEUE_WAIT_IN_ISR , STATUS_MESSAGE_QUEUE_WAS_DELETED ,
  STATUS_MINUS_ONE , STATUS_MUTEX_CEILING_VIOLATED , STATUS_NESTING_NOT_ALLOWED , STATUS_NO_MEMORY ,
  STATUS_NOT_DEFINED , STATUS_NOT_OWNER , STATUS_OBJECT_WAS_DELETED , STATUS_PROXY_BLOCKING ,
  STATUS_RESOURCE_IN_USE , STATUS_RESULT_TOO_LARGE , STATUS_SUCCESSFUL , STATUS_TIMEOUT ,
  STATUS_TOO_MANY , STATUS_UNAVAILABLE , STATUS_UNSATISFIED =
 Status codes.
◆ STATUS_BUILD
#define STATUS_BUILD (   classic_status,
  posix_status
Uses a multiplication to preserve the signedness of the POSIX status.
◆ STATUS_GET_POSIX
#define STATUS_GET_POSIX (   status)     ( ( status ) / 256 )
Uses a division to preserve the signedness of the POSIX status.
◆ Status_Classic
Must be in synchronization with rtems_status_code.
