RTEMS 6.1-rc1
schedulernodeimpl.h
2
13/*
14 * Copyright (C) 2014, 2017 embedded brains GmbH & Co. KG
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 * 1. Redistributions of source code must retain the above copyright
20 * notice, this list of conditions and the following disclaimer.
21 * 2. Redistributions in binary form must reproduce the above copyright
22 * notice, this list of conditions and the following disclaimer in the
23 * documentation and/or other materials provided with the distribution.
24 *
25 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
26 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
27 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
28 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
29 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
30 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
31 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
32 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
33 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
34 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
35 * POSSIBILITY OF SUCH DAMAGE.
36 */
37
38#ifndef _RTEMS_SCORE_SCHEDULERNODEIMPL_H
39#define _RTEMS_SCORE_SCHEDULERNODEIMPL_H
40
43
51
52#ifdef __cplusplus
53extern "C" {
54#endif /* __cplusplus */
55
56#define SCHEDULER_NODE_OF_WAIT_PRIORITY_NODE( node ) \
57 RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority.Node.Node.Chain )
58
59#define SCHEDULER_NODE_OF_WAIT_PRIORITY( node ) \
60 RTEMS_CONTAINER_OF( node, Scheduler_Node, Wait.Priority )
61
65#define SCHEDULER_PRIORITY_MAP( priority ) ( ( priority ) << 1 )
66
70#define SCHEDULER_PRIORITY_UNMAP( priority ) ( ( priority ) >> 1 )
71
75#define SCHEDULER_PRIORITY_PURIFY( priority ) \
76 ( ( priority ) & ~( (Priority_Control) PRIORITY_GROUP_LAST ) )
77
81#define SCHEDULER_PRIORITY_APPEND( priority ) \
82 ( ( priority ) | ( (Priority_Control) PRIORITY_GROUP_LAST ) )
83
89#define SCHEDULER_PRIORITY_IS_APPEND( priority ) \
90 ( ( ( priority ) & ( (Priority_Control) PRIORITY_GROUP_LAST ) ) != 0 )
91
103static inline void _Scheduler_Node_do_initialize(
104 const struct _Scheduler_Control *scheduler,
105 Scheduler_Node *node,
106 Thread_Control *the_thread,
107 Priority_Control priority
108)
109{
110 node->owner = the_thread;
111
112 node->Priority.value = priority;
113
114#if defined(RTEMS_SMP)
115 _Chain_Initialize_node( &node->Thread.Wait_node );
116 node->Wait.Priority.scheduler = scheduler;
117 node->user = the_thread;
118 node->idle = NULL;
119#if CPU_SIZEOF_POINTER != 8
120 _ISR_lock_Initialize( &node->Priority.Lock, "Scheduler Node Priority" );
121#endif
122#else
123 (void) scheduler;
124 (void) the_thread;
125#endif
126}
127
135static inline void _Scheduler_Node_do_destroy(
136 const struct _Scheduler_Control *scheduler,
137 Scheduler_Node *node
138)
139{
140 (void) scheduler;
141
142#if defined(RTEMS_SMP) && CPU_SIZEOF_POINTER != 8
143 _ISR_lock_Destroy( &node->Priority.Lock );
144#else
145 (void) node;
146#endif
147}
148
156static inline const Scheduler_Control *_Scheduler_Node_get_scheduler(
157 const Scheduler_Node *node
158)
159{
160 return _Priority_Get_scheduler( &node->Wait.Priority );
161}
162
170static inline Thread_Control *_Scheduler_Node_get_owner(
171 const Scheduler_Node *node
172)
173{
174 return node->owner;
175}
176
184static inline Priority_Control _Scheduler_Node_get_priority(
185 Scheduler_Node *node
186)
187{
188 Priority_Control priority;
189
190#if defined(RTEMS_SMP) && CPU_SIZEOF_POINTER == 8
191 priority = _Atomic_Fetch_add_ulong(
192 &node->Priority.value,
193 0,
194 ATOMIC_ORDER_RELAXED
195 );
196#else
197 ISR_lock_Context lock_context;
198
199 _ISR_lock_Acquire( &node->Priority.Lock, &lock_context );
200 priority = node->Priority.value;
201 _ISR_lock_Release( &node->Priority.Lock, &lock_context );
202#endif
203
204 return priority;
205}
206
217static inline void _Scheduler_Node_set_priority(
218 Scheduler_Node *node,
219 Priority_Control new_priority,
220 Priority_Group_order group_order
221)
222{
223#if defined(RTEMS_SMP) && CPU_SIZEOF_POINTER == 8
224 _Atomic_Store_ulong(
225 &node->Priority.value,
226 new_priority | (Priority_Control) group_order,
227 ATOMIC_ORDER_RELAXED
228 );
229#else
230 ISR_lock_Context lock_context;
231
232 _ISR_lock_Acquire( &node->Priority.Lock, &lock_context );
233 node->Priority.value = new_priority | ( (Priority_Control) group_order );
234 _ISR_lock_Release( &node->Priority.Lock, &lock_context );
235#endif
236}
237
238#if defined(RTEMS_SMP)
246static inline Thread_Control *_Scheduler_Node_get_user(
247 const Scheduler_Node *node
248)
249{
250 return node->user;
251}
252
259static inline void _Scheduler_Node_set_user(
260 Scheduler_Node *node,
261 Thread_Control *user
262)
263{
264 node->user = user;
265}
266
274static inline Thread_Control *_Scheduler_Node_get_idle(
275 const Scheduler_Node *node
276)
277{
278 return node->idle;
279}
280
288static inline void _Scheduler_Node_set_idle_user(
289 Scheduler_Node *node,
290 Thread_Control *idle
291)
292{
293 _Assert( _Scheduler_Node_get_idle( node ) == NULL );
294 _Assert(
295 _Scheduler_Node_get_owner( node ) == _Scheduler_Node_get_user( node )
296 );
297
298 _Scheduler_Node_set_user( node, idle );
299 node->idle = idle;
300}
301#endif
302
303#ifdef __cplusplus
304}
305#endif /* __cplusplus */
306
309#endif /* _RTEMS_SCORE_SCHEDULERNODEIMPL_H */
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition: assert.h:96
#define _ISR_lock_Release(_lock, _context)
Releases an ISR lock inside an ISR disabled section.
Definition: isrlock.h:332
#define _ISR_lock_Acquire(_lock, _context)
Acquires an ISR lock inside an ISR disabled section.
Definition: isrlock.h:309
#define _ISR_lock_Destroy(_lock)
Destroys an ISR lock.
Definition: isrlock.h:215
#define _ISR_lock_Initialize(_lock, _name)
Initializes an ISR lock.
Definition: isrlock.h:201
uint64_t Priority_Control
The thread priority control.
Definition: priority.h:91
The priority group order determines if a priority node is inserted as the first or last node into its...
Definition: priorityimpl.h:62
#define NULL
Requests a GPIO pin group configuration.
Definition: xil_types.h:54
This header file provides interfaces of the Scheduler Handler related to scheduler nodes which are us...
This header file provides interfaces of the Priority Handler which are only used by the implementatio...
Local ISR lock context for acquire and release pairs.
Definition: isrlock.h:81
Scheduler node for per-thread data.
Definition: schedulernode.h:94
Scheduler control.
Definition: scheduler.h:335
Definition: thread.h:812
