38#ifndef _RTEMS_SCORE_ISR_H
39#define _RTEMS_SCORE_ISR_H
74#if (CPU_SIMPLE_VECTORED_INTERRUPTS == FALSE)
76typedef void * ISR_Handler_entry;
82#if (CPU_ISR_PASSES_FRAME_POINTER == TRUE)
162#define _ISR_Install_vector( _vector, _new_handler, _old_handler ) \
163 _CPU_ISR_install_vector( _vector, _new_handler, _old_handler )
void ISR_Handler
Definition: isr.h:72
const char *const volatile _ISR_Stack_size_object
Provides the configured interrupt stack size through an object.
Definition: isr.c:47
void _ISR_Handler(void)
ISR interrupt dispatcher.
Definition: cpu_asm.c:145
const char _ISR_Stack_area_end[]
The interrupt stack area end.
void _ISR_Handler_initialization(void)
Initializes the ISR handler.
Definition: isr.c:49
char _ISR_Stack_area_begin[]
The interrupt stack area begin.
RTEMS_DECLARE_GLOBAL_SYMBOL(_ISR_Stack_size)
Provides the configured interrupt stack size through an address.
uint32_t ISR_Vector_number
Definition: isr.h:67
This header file provides the ISR_Level related interfaces of the ISR Handler.
#define CPU_INTERRUPT_NUMBER_OF_VECTORS
Definition: cpu.h:705
Interrupt stack frame (ISF).
Definition: cpuimpl.h:66
