RTEMS 6.1-rc1
Header file of SPI HAL module. More...
struct | SPI_InitTypeDef |
SPI Configuration Structure definition. More... | |
struct | __SPI_HandleTypeDef |
SPI handle Structure definition. More... | |
#define | SPI_LOWEND_FIFO_SIZE 8UL |
#define | SPI_HIGHEND_FIFO_SIZE 16UL |
#define | HAL_SPI_ERROR_NONE (0x00000000UL) |
#define | HAL_SPI_ERROR_MODF (0x00000001UL) |
#define | HAL_SPI_ERROR_CRC (0x00000002UL) |
#define | HAL_SPI_ERROR_OVR (0x00000004UL) |
#define | HAL_SPI_ERROR_FRE (0x00000008UL) |
#define | HAL_SPI_ERROR_DMA (0x00000010UL) |
#define | HAL_SPI_ERROR_FLAG (0x00000020UL) |
#define | HAL_SPI_ERROR_ABORT (0x00000040UL) |
#define | HAL_SPI_ERROR_UDR (0x00000080UL) |
#define | HAL_SPI_ERROR_TIMEOUT (0x00000100UL) |
#define | HAL_SPI_ERROR_UNKNOW (0x00000200UL) |
#define | HAL_SPI_ERROR_NOT_SUPPORTED (0x00000400UL) |
#define | HAL_SPI_ERROR_RELOAD (0x00000800UL) |
#define | SPI_MODE_SLAVE (0x00000000UL) |
#define | SPI_MODE_MASTER SPI_CFG2_MASTER |
#define | SPI_DIRECTION_2LINES (0x00000000UL) |
#define | SPI_DIRECTION_2LINES_TXONLY SPI_CFG2_COMM_0 |
#define | SPI_DIRECTION_2LINES_RXONLY SPI_CFG2_COMM_1 |
#define | SPI_DIRECTION_1LINE SPI_CFG2_COMM |
#define | SPI_DATASIZE_4BIT (0x00000003UL) |
#define | SPI_DATASIZE_5BIT (0x00000004UL) |
#define | SPI_DATASIZE_6BIT (0x00000005UL) |
#define | SPI_DATASIZE_7BIT (0x00000006UL) |
#define | SPI_DATASIZE_8BIT (0x00000007UL) |
#define | SPI_DATASIZE_9BIT (0x00000008UL) |
#define | SPI_DATASIZE_10BIT (0x00000009UL) |
#define | SPI_DATASIZE_11BIT (0x0000000AUL) |
#define | SPI_DATASIZE_12BIT (0x0000000BUL) |
#define | SPI_DATASIZE_13BIT (0x0000000CUL) |
#define | SPI_DATASIZE_14BIT (0x0000000DUL) |
#define | SPI_DATASIZE_15BIT (0x0000000EUL) |
#define | SPI_DATASIZE_16BIT (0x0000000FUL) |
#define | SPI_DATASIZE_17BIT (0x00000010UL) |
#define | SPI_DATASIZE_18BIT (0x00000011UL) |
#define | SPI_DATASIZE_19BIT (0x00000012UL) |
#define | SPI_DATASIZE_20BIT (0x00000013UL) |
#define | SPI_DATASIZE_21BIT (0x00000014UL) |
#define | SPI_DATASIZE_22BIT (0x00000015UL) |
#define | SPI_DATASIZE_23BIT (0x00000016UL) |
#define | SPI_DATASIZE_24BIT (0x00000017UL) |
#define | SPI_DATASIZE_25BIT (0x00000018UL) |
#define | SPI_DATASIZE_26BIT (0x00000019UL) |
#define | SPI_DATASIZE_27BIT (0x0000001AUL) |
#define | SPI_DATASIZE_28BIT (0x0000001BUL) |
#define | SPI_DATASIZE_29BIT (0x0000001CUL) |
#define | SPI_DATASIZE_30BIT (0x0000001DUL) |
#define | SPI_DATASIZE_31BIT (0x0000001EUL) |
#define | SPI_DATASIZE_32BIT (0x0000001FUL) |
#define | SPI_POLARITY_LOW (0x00000000UL) |
#define | SPI_POLARITY_HIGH SPI_CFG2_CPOL |
#define | SPI_PHASE_1EDGE (0x00000000UL) |
#define | SPI_PHASE_2EDGE SPI_CFG2_CPHA |
#define | SPI_NSS_SOFT SPI_CFG2_SSM |
#define | SPI_NSS_HARD_INPUT (0x00000000UL) |
#define | SPI_NSS_HARD_OUTPUT SPI_CFG2_SSOE |
#define | SPI_NSS_PULSE_DISABLE (0x00000000UL) |
#define | SPI_NSS_PULSE_ENABLE SPI_CFG2_SSOM |
#define | SPI_BAUDRATEPRESCALER_2 (0x00000000UL) |
#define | SPI_BAUDRATEPRESCALER_4 (0x10000000UL) |
#define | SPI_BAUDRATEPRESCALER_8 (0x20000000UL) |
#define | SPI_BAUDRATEPRESCALER_16 (0x30000000UL) |
#define | SPI_BAUDRATEPRESCALER_32 (0x40000000UL) |
#define | SPI_BAUDRATEPRESCALER_64 (0x50000000UL) |
#define | SPI_BAUDRATEPRESCALER_128 (0x60000000UL) |
#define | SPI_BAUDRATEPRESCALER_256 (0x70000000UL) |
#define | SPI_FIRSTBIT_MSB (0x00000000UL) |
#define | SPI_FIRSTBIT_LSB SPI_CFG2_LSBFRST |
#define | SPI_TIMODE_DISABLE (0x00000000UL) |
#define | SPI_TIMODE_ENABLE SPI_CFG2_SP_0 |
#define | SPI_CRCCALCULATION_DISABLE (0x00000000UL) |
#define | SPI_CRCCALCULATION_ENABLE SPI_CFG1_CRCEN |
#define | SPI_CRC_LENGTH_DATASIZE (0x00000000UL) |
#define | SPI_CRC_LENGTH_4BIT (0x00030000UL) |
#define | SPI_CRC_LENGTH_5BIT (0x00040000UL) |
#define | SPI_CRC_LENGTH_6BIT (0x00050000UL) |
#define | SPI_CRC_LENGTH_7BIT (0x00060000UL) |
#define | SPI_CRC_LENGTH_8BIT (0x00070000UL) |
#define | SPI_CRC_LENGTH_9BIT (0x00080000UL) |
#define | SPI_CRC_LENGTH_10BIT (0x00090000UL) |
#define | SPI_CRC_LENGTH_11BIT (0x000A0000UL) |
#define | SPI_CRC_LENGTH_12BIT (0x000B0000UL) |
#define | SPI_CRC_LENGTH_13BIT (0x000C0000UL) |
#define | SPI_CRC_LENGTH_14BIT (0x000D0000UL) |
#define | SPI_CRC_LENGTH_15BIT (0x000E0000UL) |
#define | SPI_CRC_LENGTH_16BIT (0x000F0000UL) |
#define | SPI_CRC_LENGTH_17BIT (0x00100000UL) |
#define | SPI_CRC_LENGTH_18BIT (0x00110000UL) |
#define | SPI_CRC_LENGTH_19BIT (0x00120000UL) |
#define | SPI_CRC_LENGTH_20BIT (0x00130000UL) |
#define | SPI_CRC_LENGTH_21BIT (0x00140000UL) |
#define | SPI_CRC_LENGTH_22BIT (0x00150000UL) |
#define | SPI_CRC_LENGTH_23BIT (0x00160000UL) |
#define | SPI_CRC_LENGTH_24BIT (0x00170000UL) |
#define | SPI_CRC_LENGTH_25BIT (0x00180000UL) |
#define | SPI_CRC_LENGTH_26BIT (0x00190000UL) |
#define | SPI_CRC_LENGTH_27BIT (0x001A0000UL) |
#define | SPI_CRC_LENGTH_28BIT (0x001B0000UL) |
#define | SPI_CRC_LENGTH_29BIT (0x001C0000UL) |
#define | SPI_CRC_LENGTH_30BIT (0x001D0000UL) |
#define | SPI_CRC_LENGTH_31BIT (0x001E0000UL) |
#define | SPI_CRC_LENGTH_32BIT (0x001F0000UL) |
#define | SPI_FIFO_THRESHOLD_01DATA (0x00000000UL) |
#define | SPI_FIFO_THRESHOLD_02DATA (0x00000020UL) |
#define | SPI_FIFO_THRESHOLD_03DATA (0x00000040UL) |
#define | SPI_FIFO_THRESHOLD_04DATA (0x00000060UL) |
#define | SPI_FIFO_THRESHOLD_05DATA (0x00000080UL) |
#define | SPI_FIFO_THRESHOLD_06DATA (0x000000A0UL) |
#define | SPI_FIFO_THRESHOLD_07DATA (0x000000C0UL) |
#define | SPI_FIFO_THRESHOLD_08DATA (0x000000E0UL) |
#define | SPI_FIFO_THRESHOLD_09DATA (0x00000100UL) |
#define | SPI_FIFO_THRESHOLD_10DATA (0x00000120UL) |
#define | SPI_FIFO_THRESHOLD_11DATA (0x00000140UL) |
#define | SPI_FIFO_THRESHOLD_12DATA (0x00000160UL) |
#define | SPI_FIFO_THRESHOLD_13DATA (0x00000180UL) |
#define | SPI_FIFO_THRESHOLD_14DATA (0x000001A0UL) |
#define | SPI_FIFO_THRESHOLD_15DATA (0x000001C0UL) |
#define | SPI_FIFO_THRESHOLD_16DATA (0x000001E0UL) |
#define | SPI_CRC_INITIALIZATION_ALL_ZERO_PATTERN (0x00000000UL) |
#define | SPI_CRC_INITIALIZATION_ALL_ONE_PATTERN (0x00000001UL) |
#define | SPI_NSS_POLARITY_LOW (0x00000000UL) |
#define | SPI_NSS_POLARITY_HIGH SPI_CFG2_SSIOP |
#define | SPI_MASTER_KEEP_IO_STATE_DISABLE (0x00000000UL) |
#define | SPI_MASTER_KEEP_IO_STATE_ENABLE SPI_CFG2_AFCNTR |
#define | SPI_IO_SWAP_DISABLE (0x00000000UL) |
#define | SPI_IO_SWAP_ENABLE SPI_CFG2_IOSWP |
#define | SPI_MASTER_SS_IDLENESS_00CYCLE (0x00000000UL) |
#define | SPI_MASTER_SS_IDLENESS_01CYCLE (0x00000001UL) |
#define | SPI_MASTER_SS_IDLENESS_02CYCLE (0x00000002UL) |
#define | SPI_MASTER_SS_IDLENESS_03CYCLE (0x00000003UL) |
#define | SPI_MASTER_SS_IDLENESS_04CYCLE (0x00000004UL) |
#define | SPI_MASTER_SS_IDLENESS_05CYCLE (0x00000005UL) |
#define | SPI_MASTER_SS_IDLENESS_06CYCLE (0x00000006UL) |
#define | SPI_MASTER_SS_IDLENESS_07CYCLE (0x00000007UL) |
#define | SPI_MASTER_SS_IDLENESS_08CYCLE (0x00000008UL) |
#define | SPI_MASTER_SS_IDLENESS_09CYCLE (0x00000009UL) |
#define | SPI_MASTER_SS_IDLENESS_10CYCLE (0x0000000AUL) |
#define | SPI_MASTER_SS_IDLENESS_11CYCLE (0x0000000BUL) |
#define | SPI_MASTER_SS_IDLENESS_12CYCLE (0x0000000CUL) |
#define | SPI_MASTER_SS_IDLENESS_13CYCLE (0x0000000DUL) |
#define | SPI_MASTER_SS_IDLENESS_14CYCLE (0x0000000EUL) |
#define | SPI_MASTER_SS_IDLENESS_15CYCLE (0x0000000FUL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_00CYCLE (0x00000000UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_01CYCLE (0x00000010UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_02CYCLE (0x00000020UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_03CYCLE (0x00000030UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_04CYCLE (0x00000040UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_05CYCLE (0x00000050UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_06CYCLE (0x00000060UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_07CYCLE (0x00000070UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_08CYCLE (0x00000080UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_09CYCLE (0x00000090UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_10CYCLE (0x000000A0UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_11CYCLE (0x000000B0UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_12CYCLE (0x000000C0UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_13CYCLE (0x000000D0UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_14CYCLE (0x000000E0UL) |
#define | SPI_MASTER_INTERDATA_IDLENESS_15CYCLE (0x000000F0UL) |
#define | SPI_MASTER_RX_AUTOSUSP_DISABLE (0x00000000UL) |
#define | SPI_MASTER_RX_AUTOSUSP_ENABLE SPI_CR1_MASRX |
#define | SPI_UNDERRUN_BEHAV_REGISTER_PATTERN (0x00000000UL) |
#define | SPI_UNDERRUN_BEHAV_LAST_RECEIVED SPI_CFG1_UDRCFG_0 |
#define | SPI_UNDERRUN_BEHAV_LAST_TRANSMITTED SPI_CFG1_UDRCFG_1 |
#define | SPI_UNDERRUN_DETECT_BEGIN_DATA_FRAME (0x00000000UL) |
#define | SPI_UNDERRUN_DETECT_END_DATA_FRAME SPI_CFG1_UDRDET_0 |
#define | SPI_UNDERRUN_DETECT_BEGIN_ACTIVE_NSS SPI_CFG1_UDRDET_1 |
#define | SPI_IT_RXP SPI_IER_RXPIE |
#define | SPI_IT_TXP SPI_IER_TXPIE |
#define | SPI_IT_DXP SPI_IER_DXPIE |
#define | SPI_IT_EOT SPI_IER_EOTIE |
#define | SPI_IT_TXTF SPI_IER_TXTFIE |
#define | SPI_IT_UDR SPI_IER_UDRIE |
#define | SPI_IT_OVR SPI_IER_OVRIE |
#define | SPI_IT_CRCERR SPI_IER_CRCEIE |
#define | SPI_IT_FRE SPI_IER_TIFREIE |
#define | SPI_IT_MODF SPI_IER_MODFIE |
#define | SPI_IT_TSERF SPI_IER_TSERFIE |
#define | SPI_IT_ERR (SPI_IT_UDR | SPI_IT_OVR | SPI_IT_FRE | SPI_IT_MODF | SPI_IT_CRCERR) |
#define | SPI_FLAG_RXP SPI_SR_RXP /* SPI status flag : Rx-Packet available flag */ |
#define | SPI_FLAG_TXP SPI_SR_TXP /* SPI status flag : Tx-Packet space available flag */ |
#define | SPI_FLAG_DXP SPI_SR_DXP /* SPI status flag : Duplex Packet flag */ |
#define | SPI_FLAG_EOT SPI_SR_EOT /* SPI status flag : End of transfer flag */ |
#define | SPI_FLAG_TXTF SPI_SR_TXTF /* SPI status flag : Transmission Transfer Filled flag */ |
#define | SPI_FLAG_UDR SPI_SR_UDR /* SPI Error flag : Underrun flag */ |
#define | SPI_FLAG_OVR SPI_SR_OVR /* SPI Error flag : Overrun flag */ |
#define | SPI_FLAG_CRCERR SPI_SR_CRCE /* SPI Error flag : CRC error flag */ |
#define | SPI_FLAG_FRE SPI_SR_TIFRE /* SPI Error flag : TI mode frame format error flag */ |
#define | SPI_FLAG_MODF SPI_SR_MODF /* SPI Error flag : Mode fault flag */ |
#define | SPI_FLAG_TSERF SPI_SR_TSERF /* SPI status flag : Additional number of data reloaded flag */ |
#define | SPI_FLAG_SUSP SPI_SR_SUSP /* SPI status flag : Transfer suspend complete flag */ |
#define | SPI_FLAG_TXC SPI_SR_TXC /* SPI status flag : TxFIFO transmission complete flag */ |
#define | SPI_FLAG_FRLVL SPI_SR_RXPLVL /* SPI status flag : Fifo reception level flag */ |
#define | SPI_FLAG_RXWNE SPI_SR_RXWNE /* SPI status flag : RxFIFO word not empty flag */ |
#define | SPI_RX_FIFO_0PACKET (0x00000000UL) /* 0 or multiple of 4 packets available in the RxFIFO */ |
#define | SPI_RX_FIFO_1PACKET (SPI_SR_RXPLVL_0) |
#define | SPI_RX_FIFO_2PACKET (SPI_SR_RXPLVL_1) |
#define | SPI_RX_FIFO_3PACKET (SPI_SR_RXPLVL_1 | SPI_SR_RXPLVL_0) |
#define | __HAL_SPI_RESET_HANDLE_STATE(__HANDLE__) ((__HANDLE__)->State = HAL_SPI_STATE_RESET) |
Reset SPI handle state. More... | |
#define | __HAL_SPI_ENABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->IER |= (__INTERRUPT__)) |
Enable the specified SPI interrupts. More... | |
#define | __HAL_SPI_DISABLE_IT(__HANDLE__, __INTERRUPT__) ((__HANDLE__)->Instance->IER &= (~(__INTERRUPT__))) |
Disable the specified SPI interrupts. More... | |
#define | __HAL_SPI_GET_IT_SOURCE(__HANDLE__, __INTERRUPT__) |
Check whether the specified SPI interrupt source is enabled or not. More... | |
#define | __HAL_SPI_GET_FLAG(__HANDLE__, __FLAG__) ((((__HANDLE__)->Instance->SR) & (__FLAG__)) == (__FLAG__)) |
Check whether the specified SPI flag is set or not. More... | |
#define | __HAL_SPI_CLEAR_CRCERRFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_CRCEC) |
Clear the SPI CRCERR pending flag. More... | |
#define | __HAL_SPI_CLEAR_MODFFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , (uint32_t)(SPI_IFCR_MODFC)); |
Clear the SPI MODF pending flag. More... | |
#define | __HAL_SPI_CLEAR_OVRFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_OVRC) |
Clear the SPI OVR pending flag. More... | |
#define | __HAL_SPI_CLEAR_FREFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TIFREC) |
Clear the SPI FRE pending flag. More... | |
#define | __HAL_SPI_CLEAR_UDRFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_UDRC) |
Clear the SPI UDR pending flag. More... | |
#define | __HAL_SPI_CLEAR_EOTFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_EOTC) |
Clear the SPI EOT pending flag. More... | |
#define | __HAL_SPI_CLEAR_TXTFFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TXTFC) |
#define | __HAL_SPI_CLEAR_SUSPFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_SUSPC) |
Clear the SPI SUSP pending flag. More... | |
#define | __HAL_SPI_CLEAR_TSERFFLAG(__HANDLE__) SET_BIT((__HANDLE__)->Instance->IFCR , SPI_IFCR_TSERFC) |
Clear the SPI TSERF pending flag. More... | |
#define | __HAL_SPI_ENABLE(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR1 , SPI_CR1_SPE) |
Enable the SPI peripheral. More... | |
#define | __HAL_SPI_DISABLE(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CR1 , SPI_CR1_SPE) |
Disable the SPI peripheral. More... | |
#define | SPI_1LINE_TX(__HANDLE__) SET_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_HDDIR) |
Set the SPI transmit-only mode in 1Line configuration. More... | |
#define | SPI_1LINE_RX(__HANDLE__) CLEAR_BIT((__HANDLE__)->Instance->CR1, SPI_CR1_HDDIR) |
Set the SPI receive-only mode in 1Line configuration. More... | |
#define | SPI_2LINES_TX(__HANDLE__) MODIFY_REG((__HANDLE__)->Instance->CFG2, SPI_CFG2_COMM, SPI_CFG2_COMM_0) |
Set the SPI transmit-only mode in 2Lines configuration. More... | |
#define | SPI_2LINES_RX(__HANDLE__) MODIFY_REG((__HANDLE__)->Instance->CFG2, SPI_CFG2_COMM, SPI_CFG2_COMM_1) |
Set the SPI receive-only mode in 2Lines configuration. More... | |
#define | SPI_2LINES(__HANDLE__) MODIFY_REG((__HANDLE__)->Instance->CFG2, SPI_CFG2_COMM, 0x00000000UL) |
Set the SPI Transmit-Receive mode in 2Lines configuration. More... | |
#define | IS_SPI_MODE(MODE) |
#define | IS_SPI_DIRECTION(MODE) |
#define | IS_SPI_DIRECTION_2LINES(MODE) ((MODE) == SPI_DIRECTION_2LINES) |
#define | IS_SPI_DIRECTION_2LINES_OR_1LINE_2LINES_TXONLY(MODE) |
#define | IS_SPI_DIRECTION_2LINES_OR_1LINE_2LINES_RXONLY(MODE) |
#define | IS_SPI_DATASIZE(DATASIZE) |
#define | IS_SPI_FIFOTHRESHOLD(THRESHOLD) |
#define | IS_SPI_CPOL(CPOL) |
#define | IS_SPI_CPHA(CPHA) |
#define | IS_SPI_NSS(NSS) |
#define | IS_SPI_NSSP(NSSP) |
#define | IS_SPI_BAUDRATE_PRESCALER(PRESCALER) |
#define | IS_SPI_FIRST_BIT(BIT) |
#define | IS_SPI_TIMODE(MODE) |
#define | IS_SPI_CRC_CALCULATION(CALCULATION) |
#define | IS_SPI_CRC_INITIALIZATION_PATTERN(PATTERN) |
#define | IS_SPI_CRC_LENGTH(LENGTH) |
#define | IS_SPI_CRC_POLYNOMIAL(POLYNOMIAL) ((POLYNOMIAL) > 0x0UL) |
#define | IS_SPI_UNDERRUN_DETECTION(MODE) |
#define | IS_SPI_UNDERRUN_BEHAVIOUR(MODE) |
#define | IS_SPI_MASTER_RX_AUTOSUSP(MODE) |
Typedefs | |
typedef struct __SPI_HandleTypeDef | SPI_HandleTypeDef |
SPI handle Structure definition. | |
Enumerations | |
enum | HAL_SPI_StateTypeDef { HAL_SPI_STATE_RESET = 0x00UL , HAL_SPI_STATE_READY = 0x01UL , HAL_SPI_STATE_BUSY = 0x02UL , HAL_SPI_STATE_BUSY_TX = 0x03UL , HAL_SPI_STATE_BUSY_RX = 0x04UL , HAL_SPI_STATE_BUSY_TX_RX = 0x05UL , HAL_SPI_STATE_ERROR = 0x06UL , HAL_SPI_STATE_ABORT = 0x07UL } |
HAL SPI State structure definition. More... | |
HAL_StatusTypeDef | HAL_SPI_Init (SPI_HandleTypeDef *hspi) |
HAL_StatusTypeDef | HAL_SPI_DeInit (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_MspInit (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_MspDeInit (SPI_HandleTypeDef *hspi) |
HAL_StatusTypeDef | HAL_SPI_Transmit (SPI_HandleTypeDef *hspi, const uint8_t *pData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_SPI_Receive (SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_SPI_TransmitReceive (SPI_HandleTypeDef *hspi, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size, uint32_t Timeout) |
HAL_StatusTypeDef | HAL_SPI_Transmit_IT (SPI_HandleTypeDef *hspi, const uint8_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_SPI_Receive_IT (SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_SPI_TransmitReceive_IT (SPI_HandleTypeDef *hspi, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_SPI_Transmit_DMA (SPI_HandleTypeDef *hspi, const uint8_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_SPI_Receive_DMA (SPI_HandleTypeDef *hspi, uint8_t *pData, uint16_t Size) |
HAL_StatusTypeDef | HAL_SPI_TransmitReceive_DMA (SPI_HandleTypeDef *hspi, const uint8_t *pTxData, uint8_t *pRxData, uint16_t Size) |
HAL_StatusTypeDef | HAL_SPI_DMAPause (SPI_HandleTypeDef *hspi) |
HAL_StatusTypeDef | HAL_SPI_DMAResume (SPI_HandleTypeDef *hspi) |
HAL_StatusTypeDef | HAL_SPI_DMAStop (SPI_HandleTypeDef *hspi) |
HAL_StatusTypeDef | HAL_SPI_Abort (SPI_HandleTypeDef *hspi) |
HAL_StatusTypeDef | HAL_SPI_Abort_IT (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_IRQHandler (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_TxCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_RxCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_TxRxCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_TxHalfCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_RxHalfCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_TxRxHalfCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_ErrorCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_AbortCpltCallback (SPI_HandleTypeDef *hspi) |
void | HAL_SPI_SuspendCallback (SPI_HandleTypeDef *hspi) |
HAL_SPI_StateTypeDef | HAL_SPI_GetState (const SPI_HandleTypeDef *hspi) |
uint32_t | HAL_SPI_GetError (const SPI_HandleTypeDef *hspi) |
