RTEMS 6.1-rc1
Macros | Enumerations
stm32h7xx_hal_def.h File Reference
This file contains HAL common defines, enumeration, macros and structures definitions. More...
#include "stm32h7xx.h"
#include "Legacy/stm32_hal_legacy.h"
#include <stddef.h>
#include <math.h>
#define HAL_MAX_DELAY   0xFFFFFFFFU
#define HAL_IS_BIT_SET(REG, BIT)   (((REG) & (BIT)) == (BIT))
#define HAL_IS_BIT_CLR(REG, BIT)   (((REG) & (BIT)) == 0U)
#define __HAL_LINKDMA(__HANDLE__, __PPP_DMA_FIELD__, __DMA_HANDLE__)
#define UNUSED(x)   ((void)(x)) /* To avoid gcc/g++ warnings */
#define __HAL_RESET_HANDLE_STATE(__HANDLE__)   ((__HANDLE__)->State = 0)
 Reset the Handle's State field. More...
#define __HAL_LOCK(__HANDLE__)
#define __HAL_UNLOCK(__HANDLE__)
#define __ALIGN_END
enum  HAL_StatusTypeDef { HAL_OK = 0x00 , HAL_ERROR = 0x01 , HAL_BUSY = 0x02 , HAL_TIMEOUT = 0x03 }
 HAL Status structures definition.
enum  HAL_LockTypeDef { HAL_UNLOCKED = 0x00 , HAL_LOCKED = 0x01 }
 HAL Lock structures definition.
Author
MCD Application Team
Attention
◆ __HAL_LINKDMA
#define __HAL_LINKDMA (   __HANDLE__,
  __PPP_DMA_FIELD__,
  __DMA_HANDLE__
Value:
do{ \
(__HANDLE__)->__PPP_DMA_FIELD__ = &(__DMA_HANDLE__); \
(__DMA_HANDLE__).Parent = (__HANDLE__); \
} while(0)
◆ __HAL_LOCK
#define __HAL_LOCK (   __HANDLE__)
Value:
do{ \
if((__HANDLE__)->Lock == HAL_LOCKED) \
return HAL_BUSY; \
else \
(__HANDLE__)->Lock = HAL_LOCKED; \
}while (0)
◆ __HAL_RESET_HANDLE_STATE
#define __HAL_RESET_HANDLE_STATE (   __HANDLE__)    ((__HANDLE__)->State = 0)
Parameters
__HANDLE__specifies the Peripheral Handle.
Note
This macro can be used for the following purpose:
  • When the Handle is declared as local variable; before passing it as parameter to HAL_PPP_Init() for the first time, it is mandatory to use this macro to set to 0 the Handle's "State" field. Otherwise, "State" field may have any random value and the first time the function HAL_PPP_Init() is called, the low level hardware initialization will be missed (i.e. HAL_PPP_MspInit() will not be executed).
  • When there is a need to reconfigure the low level hardware: instead of calling HAL_PPP_DeInit() then HAL_PPP_Init(), user can make a call to this macro then HAL_PPP_Init(). In this later function, when the Handle's "State" field is set to 0, it will execute the function HAL_PPP_MspInit() which will reconfigure the low level hardware.
Return values
None
◆ __HAL_UNLOCK
#define __HAL_UNLOCK (   __HANDLE__)
Value:
do{ \
(__HANDLE__)->Lock = HAL_UNLOCKED; \
}while (0)
