RTEMS 6.1-rc1
Create a Special or Ordinary File. More...
int | rtems_filesystem_mknod (const rtems_filesystem_location_info_t *parentloc, const char *name, size_t namelen, mode_t mode, dev_t dev) |
int | mknod (const char *path, mode_t mode, dev_t dev) |
int mknod | ( | const char * | path, |
mode_t | mode, | ||
dev_t | dev | ||
This routine is not defined in the POSIX 1003.1b standard but is commonly supported on most UNIX and POSIX systems. It is the foundation for creating file system objects.
