39#ifndef _RTEMS_RTEMS_LIBIO__H
40#define _RTEMS_RTEMS_LIBIO__H
67#define RTEMS_FILESYSTEM_SYMLOOP_MAX 32
80extern const uint32_t rtems_libio_number_iops;
82extern void *rtems_libio_iop_free_head;
83extern void **rtems_libio_iop_free_tail;
114static inline unsigned int rtems_libio_iop_flags_set(
119 return _Atomic_Fetch_or_uint( &iop->flags, set, ATOMIC_ORDER_RELAXED );
130static inline unsigned int rtems_libio_iop_flags_clear(
135 return _Atomic_Fetch_and_uint( &iop->flags, ~clear, ATOMIC_ORDER_RELAXED );
149 return &rtems_libio_iops[ fd ];
159static inline unsigned int rtems_libio_iop_hold(
rtems_libio_t *iop )
161 return _Atomic_Fetch_add_uint(
163 LIBIO_FLAGS_REFERENCE_INC,
175#if defined(RTEMS_DEBUG)
179 flags = _Atomic_Load_uint( &iop->flags, ATOMIC_ORDER_RELAXED );
182 unsigned int desired;
184 _Assert( flags >= LIBIO_FLAGS_REFERENCE_INC );
186 desired = flags - LIBIO_FLAGS_REFERENCE_INC;
187 success = _Atomic_Compare_exchange_uint(
191 ATOMIC_ORDER_RELEASE,
194 }
while ( !success );
196 _Atomic_Fetch_sub_uint(
198 LIBIO_FLAGS_REFERENCE_INC,
211#define rtems_libio_iop_to_descriptor(_iop) \
212 ((_iop) - &rtems_libio_iops[0])
220#define rtems_libio_check_is_open(_iop) \
222 if ((rtems_libio_iop_flags(_iop) & LIBIO_FLAGS_OPEN) == 0) { \
233#define LIBIO_GET_IOP( _fd, _iop ) \
235 unsigned int _flags; \
236 if ( (uint32_t) ( _fd ) >= rtems_libio_number_iops ) { \
237 rtems_set_errno_and_return_minus_one( EBADF ); \
239 _iop = rtems_libio_iop( _fd ); \
240 _flags = rtems_libio_iop_hold( _iop ); \
241 if ( ( _flags & LIBIO_FLAGS_OPEN ) == 0 ) { \
242 rtems_libio_iop_drop( _iop ); \
243 rtems_set_errno_and_return_minus_one( EBADF ); \
253#define LIBIO_GET_IOP_WITH_ACCESS( _fd, _iop, _access_flags, _access_error ) \
255 unsigned int _flags; \
256 unsigned int _mandatory; \
257 if ( (uint32_t) ( _fd ) >= rtems_libio_number_iops ) { \
258 rtems_set_errno_and_return_minus_one( EBADF ); \
260 _iop = rtems_libio_iop( _fd ); \
261 _flags = rtems_libio_iop_hold( _iop ); \
262 _mandatory = LIBIO_FLAGS_OPEN | ( _access_flags ); \
263 if ( ( _flags & _mandatory ) != _mandatory ) { \
265 rtems_libio_iop_drop( _iop ); \
266 if ( ( _flags & LIBIO_FLAGS_OPEN ) == 0 ) { \
269 _error = _access_error; \
271 rtems_set_errno_and_return_minus_one( _error ); \
281#define rtems_libio_check_buffer(_buffer) \
283 if ((_buffer) == 0) { \
295#define rtems_libio_check_count(_count) \
297 if ((_count) == 0) { \
336void rtems_libio_lock(
void );
338void rtems_libio_unlock(
void );
340static inline void rtems_filesystem_mt_lock(
void )
345static inline void rtems_filesystem_mt_unlock(
void )
347 rtems_libio_unlock();
352#define rtems_filesystem_mt_entry_declare_lock_context( ctx ) \
353 rtems_interrupt_lock_context ctx
355#define rtems_filesystem_mt_entry_lock( ctx ) \
356 rtems_interrupt_lock_acquire( &rtems_filesystem_mt_entry_lock_control, &ctx )
358#define rtems_filesystem_mt_entry_unlock( ctx ) \
359 rtems_interrupt_lock_release( &rtems_filesystem_mt_entry_lock_control, &ctx )
361static inline void rtems_filesystem_instance_lock(
367 (*mt_entry->ops->lock_h)( mt_entry );
370static inline void rtems_filesystem_instance_unlock(
376 (*mt_entry->ops->unlock_h)( mt_entry );
411 const struct timespec
times[2]
434 const struct timespec
times[2],
435 struct timespec new_times[2]
471rtems_filesystem_eval_path_start(
478rtems_filesystem_eval_path_start_with_parent(
483 int parent_eval_flags
487rtems_filesystem_eval_path_start_with_root_and_current(
496void rtems_filesystem_eval_path_continue(
500void rtems_filesystem_eval_path_cleanup(
504void rtems_filesystem_eval_path_recursive(
510void rtems_filesystem_eval_path_cleanup_with_parent(
534 RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_CONTINUE,
535 RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_DONE,
536 RTEMS_FILESYSTEM_EVAL_PATH_GENERIC_NO_ENTRY
537} rtems_filesystem_eval_path_generic_status;
567typedef rtems_filesystem_eval_path_generic_status
580void rtems_filesystem_eval_path_generic(
607rtems_filesystem_location_initialize_to_null(
618rtems_filesystem_location_transform_to_global(
679void rtems_filesystem_location_detach(
683void rtems_filesystem_location_copy_and_detach(
689rtems_filesystem_global_location_obtain_null(
void)
696static inline bool rtems_filesystem_location_is_null(
700 return loc->handlers == &rtems_filesystem_null_handlers;
703static inline bool rtems_filesystem_global_location_is_null(
707 return rtems_filesystem_location_is_null( &global_loc->location );
710static inline void rtems_filesystem_location_error(
715 if ( !rtems_filesystem_location_is_null( loc ) ) {
720int rtems_filesystem_mknod(
730int rtems_filesystem_chmod(
735int rtems_filesystem_chown(
741static inline bool rtems_filesystem_is_ready_for_unmount(
745 bool ready = !mt_entry->mounted
746 && rtems_chain_has_only_one_node( &mt_entry->location_chain )
747 && mt_entry->mt_fs_root->reference_count == 1;
750 rtems_chain_initialize_empty( &mt_entry->location_chain );
756static inline void rtems_filesystem_location_add_to_mt_entry(
760 rtems_filesystem_mt_entry_declare_lock_context( lock_context );
762 rtems_filesystem_mt_entry_lock( lock_context );
763 rtems_chain_append_unprotected(
764 &loc->mt_entry->location_chain,
767 rtems_filesystem_mt_entry_unlock( lock_context );
770void rtems_filesystem_location_remove_from_mt_entry(
774void rtems_filesystem_do_unmount(
778static inline bool rtems_filesystem_location_is_instance_root(
784 return (*mt_entry->ops->are_nodes_equal_h)(
786 &mt_entry->mt_fs_root->location
790static inline const char *rtems_filesystem_eval_path_get_path(
797static inline size_t rtems_filesystem_eval_path_get_pathlen(
804static inline void rtems_filesystem_eval_path_set_path(
814static inline void rtems_filesystem_eval_path_clear_path(
821static inline const char *rtems_filesystem_eval_path_get_token(
828static inline size_t rtems_filesystem_eval_path_get_tokenlen(
835static inline void rtems_filesystem_eval_path_set_token(
845static inline void rtems_filesystem_eval_path_clear_token(
852static inline void rtems_filesystem_eval_path_put_back_token(
858 ctx->
path -= tokenlen;
863void rtems_filesystem_eval_path_eat_delimiter(
867void rtems_filesystem_eval_path_next_token(
871static inline void rtems_filesystem_eval_path_get_next_token(
877 rtems_filesystem_eval_path_next_token(ctx);
883rtems_filesystem_eval_path_get_currentloc(
890static inline bool rtems_filesystem_eval_path_has_path(
897static inline bool rtems_filesystem_eval_path_has_token(
904static inline int rtems_filesystem_eval_path_get_flags(
911static inline void rtems_filesystem_eval_path_set_flags(
919static inline void rtems_filesystem_eval_path_clear_and_set_flags(
925 int flags = ctx->
flags;
933static inline void rtems_filesystem_eval_path_extract_currentloc(
938 rtems_filesystem_location_copy_and_detach(
944void rtems_filesystem_eval_path_error(
986bool rtems_filesystem_eval_path_check_access(
994static inline bool rtems_filesystem_is_delimiter(
char c)
996 return c ==
'/' || c ==
999static inline bool rtems_filesystem_is_current_directory(
1004 return tokenlen == 1 && token [0] ==
1007static inline bool rtems_filesystem_is_parent_directory(
1012 return tokenlen == 2 && token [0] ==
'.' && token [1] ==
1015typedef ssize_t ( *rtems_libio_iovec_adapter )(
1017 const struct iovec *iov,
1022static inline ssize_t rtems_libio_iovec_eval(
1024 const struct iovec *iov,
1027 rtems_libio_iovec_adapter adapter
1043 if ( iovcnt > IOV_MAX )
1052 for (
v = 0 ;
v < iovcnt ; ++
v ) {
1053 size_t len = iov[
v ].iov_len;
1055 if ( len > (
size_t ) ( SSIZE_MAX - total ) ) {
1059 total += ( ssize_t ) len;
1061 if ( iov[
v ].iov_base ==
NULL && len != 0 ) {
1069 total = ( *adapter )( iop, iov, iovcnt, total );
1072 rtems_libio_iop_drop( iop );
1084static inline mode_t rtems_filesystem_location_type(
1091 (void) ( *loc->handlers->fstat_h )( loc, &st );
clock_t times(struct tms *ptms)
Definition: __times.c:97
This header file provides the interfaces of the Assert Handler.
#define LIBIO_GET_IOP_WITH_ACCESS(_fd, _iop, _access_flags, _access_error)
Macro to get the iop for the specified file descriptor with access flags and error.
Definition: libio_.h:253
int rtems_filesystem_utime_check_permissions(const rtems_filesystem_location_info_t *currentloc, const struct timespec times[2])
Checks for errors and if the process has write permissions to the file.
Definition: utimensat.c:75
unsigned int rtems_libio_fcntl_flags(int fcntl_flags)
Definition: libio.c:80
bool(* rtems_filesystem_eval_path_is_directory)(rtems_filesystem_eval_path_context_t *ctx, void *arg)
Tests if the current location is a directory.
Definition: libio_.h:550
void rtems_filesystem_global_location_assign(rtems_filesystem_global_location_t **lhs_global_loc_ptr, rtems_filesystem_global_location_t *rhs_global_loc)
Assigns a global file system location.
Definition: sup_fs_location.c:108
rtems_filesystem_global_location_t rtems_filesystem_global_location_null
The global null location.
Definition: __usrenv.c:246
void rtems_filesystem_eval_path_restart(rtems_filesystem_eval_path_context_t *ctx, rtems_filesystem_global_location_t **newstartloc_ptr)
Requests a path evaluation restart.
Definition: sup_fs_eval_path.c:330
bool rtems_filesystem_utime_tv_nsec_valid(struct timespec time)
Checks the tv_nsec member of a timespec struct.
Definition: utimensat.c:53
bool rtems_filesystem_check_access(int flags, mode_t object_mode, uid_t object_uid, gid_t object_gid)
Checks if access to an object is allowed for the current user.
Definition: sup_fs_check_permissions.c:102
rtems_filesystem_global_location_t * rtems_filesystem_global_location_obtain(rtems_filesystem_global_location_t *const *global_loc_ptr)
Obtains a global file system location.
Definition: sup_fs_location.c:175
void rtems_filesystem_global_location_release(rtems_filesystem_global_location_t *global_loc, bool deferred)
Releases a global file system location.
Definition: sup_fs_location.c:198
int rtems_libio_to_fcntl_flags(unsigned int flags)
Definition: libio.c:105
rtems_libio_t * rtems_libio_allocate(void)
Definition: libio.c:128
void rtems_filesystem_location_free(rtems_filesystem_location_info_t *loc)
Releases all resources of a location.
Definition: freenode.c:44
void rtems_filesystem_location_clone(rtems_filesystem_location_info_t *clone, const rtems_filesystem_location_info_t *master)
Clones a node.
Definition: clonenode.c:41
void rtems_libio_free(rtems_libio_t *iop)
Definition: libio.c:152
int rtems_filesystem_utime_update(const struct timespec times[2], struct timespec new_times[2])
Checks times and fills new_times with the time to be written.
Definition: utimensat.c:120
int rtems_filesystem_location_exists_in_same_instance_as(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Checks that the locations exist in the same file system instance.
Definition: sup_fs_exist_in_same_instance.c:41
void rtems_filesystem_initialize(void)
Base File System Initialization.
Definition: base_fs.c:51
rtems_filesystem_location_info_t * rtems_filesystem_location_copy(rtems_filesystem_location_info_t *dst, const rtems_filesystem_location_info_t *src)
Copies a location.
rtems_filesystem_eval_path_generic_status(* rtems_filesystem_eval_path_eval_token)(rtems_filesystem_eval_path_context_t *ctx, void *arg, const char *token, size_t tokenlen)
Evaluates a token.
Definition: libio_.h:568
#define rtems_set_errno_and_return_minus_one(_error)
Definition: seterr.h:67
#define _Assert(_e)
Assertion similar to assert() controlled via RTEMS_DEBUG instead of NDEBUG and static analysis runs.
Definition: assert.h:96
#define NULL
Requests a GPIO pin group configuration.
Definition: xil_types.h:54
POSIX Threads Private Support.
This header file provides the interfaces of the Timespec Helpers.
This header file defines macros to set errno and return minus one.
ISR lock control.
Definition: isrlock.h:72
File system node operations table.
Definition: libio.h:1020
Definition: deflate.c:114
Path evaluation context.
rtems_filesystem_location_info_t currentloc
Definition: libio.h:153
const char * path
Definition: libio.h:106
size_t pathlen
Definition: libio.h:111
size_t tokenlen
Definition: libio.h:123
const char * token
Definition: libio.h:117
int flags
Definition: libio.h:137
Global file system location.
Definition: fs.h:100
File system location.
Definition: fs.h:72
Mount table entry.
Definition: libio.h:1621
An open file data structure.
Definition: libio.h:1337
unsigned v
Definition: tte.h:0
User Environment Support.
