RTEMS 6.1-rc1
src Directory Reference
file  __assert.c
 Evaluate Assertion.
file  __getpid.c
 Get Process Id.
file  __gettod.c
 Get the Date and Time.
file  __times.c
 Get Process Times.
file  __usrenv.c
 RTEMS File System Location Support.
file  _calloc_r.c
 Allocate Space for Array in Memory.
file  _free_r.c
 Allocate and Free Dynamic Memory.
file  _realloc_r.c
 _realloc_r Implementation
file  _rename_r.c
 Rename a File.
file  access.c
 access() - POSIX 1003.1b 5.6.3 - File Accessibility
file  assoclocalbyname.c
 RTEMS Associate Local by Name.
file  assoclocalbyremote.c
 RTEMS Associate Local by Remote.
file  assoclocalbyremotebitfield.c
 RTEMS Associate Local by Remote Bitfield.
file  assocnamebad.c
 RTEMS Associate Bad Name.
file  assocnamebylocal.c
 RTEMS Associate Name by Local.
file  assocnamebylocalbitfield.c
 RTEMS Associate Name by Local Bitfield.
file  assocnamebyremote.c
 RTEMS Associate Name by Remote.
file  assocnamebyremotebitfield.c
 RTEMS Associate Name by Remote Bitfield.
file  assocptrbylocal.c
 RTEMS Associate Pointer by Local.
file  assocptrbyname.c
 RTEMS Associate Pointer by Name.
file  assocptrbyremote.c
 RTEMS Associate Pointer by Remote.
file  assocremotebylocal.c
 RTEMS Associate Remote by Local.
file  assocremotebylocalbitfield.c
 RTEMS Assoc Routines.
file  assocremotebyname.c
 RTEMS Associate Remote by Name.
file  base_fs.c
 Base File System Initialization.
file  cachealignedalloc.c
 RTEMS Cache Aligned Malloc.
file  cachecoherentalloc.c
file  calloc.c
file  cfgetispeed.c
 Baud Rate Functions.
file  cfgetospeed.c
file  cfsetispeed.c
file  cfsetospeed.c
file  chdir.c
 POSIX 1003.1b - 5.2.1 - Change Current Working Directory.
file  chmod.c
 Change File Modes.
file  chown.c
 Change Owner and Group of a File.
file  chroot.c
 Change Root Directory.
file  clonenode.c
 Clones a Node.
file  close.c
 POSIX 1003.1b 6.3.1 - Close a File.
file  consolesimple.h [code]
file  ctermid.c
 Generate Terminal Pathname.
file  dup.c
 POSIX 1003.1b 6.2.1 Duplicate an Open File Descriptor.
file  dup2.c
file  error.c
file  fchdir.c
 Change Directory.
file  fchmod.c
 Change File Modes.
file  fchown.c
file  fcntl.c
 POSIX 1003.1b 6.5.2 - File Control.
file  fdatasync.c
 POSIX 1003.1b 6.6.2 - Synchronize the Data of a File.
file  flockfile.c
 Lock File for Stdio.
file  fpathconf.c
 Configurable Pathname Varables.
file  free.c
 calloc()
file  freenode.c
 Releases all Resources of a Location.
file  fsync.c
 Synchronize the State of a File.
file  ftruncate.c
 Truncate a File to the Specified Length.
file  funlockfile.c
 Unlock File for Stdio.
file  futimens.c
 Set file access and modification times based on file descriptor in nanoseconds.
file  gcovfork.c
 This source file contains functions required by GCC if code and branch coverage instrumentation (gcov) is enabled.
file  getchark.c
 This source file contains the implementation of getchark().
file  getdents.c
 Get Directory Entries.
file  getegid.c
 Get Real User, Effective User, Ral Group, and Effective Group IDs.
file  geteuid.c
file  getgid.c
file  getgrent.c
 User Database Access Routines.
file  getgrnam.c
file  getgroups.c
 Get Supplementary IDs.
file  getlogin.c
 Get User Name.
file  getpagesize.c
 Get System Page Size.
file  getpgrp.c
 Get process group IDs.
file  getpid.c
 Process and Parent Process IDs.
file  getppid.c
 Get Process and Parent Process IDs.
file  getpwent.c
file  getuid.c
file  ioctl.c
 ioctl() system call
file  isatty_r.c
 Test for a Terminal Device.
file  issetugid.c
 Dummy Version of BSD Routine.
file  kill_noposix.c
 Kill No POSIX.
file  libio.c
 File Descriptor Routines.
file  libio_exit.c
file  libio_init.c
 RTEMS LibIO Initialization.
file  libiozeroiops.c
 This source file provides rtems_libio_iops and rtems_libio_number_iops for a zero file descriptor application configuration.
file  link.c
file  lseek.c
 lseek() - POSIX 1003.1b 6.5.3 - Reposition Read/Write File Offset
file  lstat.c
 Get File Status.
file  malloc.c
 RTEMS Malloc Family Implementation.
file  malloc_deferred.c
 Malloc Deferred Support.
file  malloc_dirtier.c
 Dirty Memory Function.
file  malloc_p.h [code]
 This header file provides interfaces used by the memory allocator implementation.
file  malloc_walk.c
 Malloc Walk.
file  mallocfreespace.c
 RTEMS Malloc Get Free Information.
file  mallocgetheapptr.c
 RTEMS Malloc Get Heap Pointer.
file  mallocheap.c
 This source file provides the C Program Heap control along with the system initialization handler.
file  mallocinfo.c
 RTEMS Malloc Get Status Information.
file  mallocsetheapptr.c
 RTEMS Malloc Set Heap Pointer.
file  mkdir.c
 Make a Directory.
file  mkfifo.c
 Make a FIFO Special File.
file  mknod.c
 Create a Special or Ordinary File.
file  mount-mktgt.c
 mount_and_make_target_path() implementation.
file  mount.c
 Mounts a File System.
file  newlibc_reent.c
 Newlib Support.
file  open.c
 Open a File.
file  open_dev_console.c
 open_dev_console - open /dev/console
file  pathconf.c
file  posix_memalign.c
file  print_fprintf.c
 RTEMS Print Support.
file  print_printf.c
file  printf_plugin.c
 RTEMS Plugin Printf.
file  printk.c
 This source file contains the implementation of printk().
file  printk_plugin.c
 This source file contains the implementation of rtems_printk_printer() and rtems_print_printer_printk().
file  privateenv.c
 Instantiate a Private User Environment.
file  putk.c
 This source file contains the implementation of putk().
file  pwdgrp.c
file  pwdgrp.h [code]
file  read.c
 Read From a File.
file  readlink.c
file  readv.c
 Read a Vector.
file  realloc.c
 Reallocate Memory Block.
file  rmdir.c
 Remove a Directory.
file  rtems_heap_extend.c
 rtems_heap_extend() implementation.
file  rtems_heap_extend_via_sbrk.c
 RTEMS Extend Heap via Sbrk.
file  rtems_heap_greedy.c
 Greedy Allocate that Empties the Heap.
file  rtems_heap_sbrk_greedy.c
 Greedy Allocate that Empties the sbrk system call.
file  rtems_memalign.c
 RTEMS Variation on Aligned Memory Allocation.
file  rtems_mkdir.c
 rtems_mkdir() implementation.
file  rtems_put_char.c
 This source file contains the implementation of rtems_put_char().
file  rtems_putc.c
 This source file contains the implementation of rtems_putc().
file  rtemscalloc.c
 This source file contains the implementation of rtems_calloc().
file  setegid.c
file  seteuid.c
 Set Effective User Id.
file  setgid.c
 POSIX sets user and group ids.
file  setpgid.c
 Set Process Group ID for Job Control.
file  setsid.c
 Create Session and Set Process Group ID.
file  stat.c
 Get File Status.
file  sup_fs_check_permissions.c
 RTEMS File System Permissions Check Support.
file  sup_fs_deviceio.c
 RTEMS DeviceIO Support.
file  sup_fs_eval_path.c
 RTEMS File Sysyem Path Eval Support.
file  sup_fs_eval_path_generic.c
 RTEMS File System Eval Generic Path.
file  sup_fs_exist_in_same_instance.c
 Checks that the Locations Exist in the Same File System Instance.
file  sup_fs_location.c
file  sup_fs_mount_iterate.c
 Mount table entry visitor.
file  sup_fs_next_token.c
 RTEMS File System Eval Eat Delimiter Path.
file  symlink.c
file  sync.c
 This source file contains the implementation of sync().
file  tcdrain.c
 Line Control Functions.
file  tcflow.c
file  tcflush.c
 tcflush() - POSIX 1003.1b 7.2.2 - Line Control Functions
file  tcgetattr.c
 Get State.
file  tcgetpgrp.c
 Get Foreground Process Group ID.
file  tcsendbreak.c
file  tcsetattr.c
 Get and Set State.
file  tcsetpgrp.c
 Set Foreground Process Group ID.
file  termios.c
file  termios_baud2index.c
 Convert Bxxx Constant to Index.
file  termios_baud2num.c
 Convert Baud Part of Termios control flags to an integral Baud Value.
file  termios_baudtable.c
 RTEMS Termios Baud Table.
file  termios_num2baud.c
 Converts the Integral Baud to Termios Control Flag Representation.
file  termios_posix_isig_handler.c
file  termios_setinitialbaud.c
 Sets the Initial Baud in the Termios Context.
file  termiosinitialize.c
 This source file contains the implementation of rtems_termios_device_lock_acquire_default() and rtems_termios_device_lock_release_default().
file  truncate.c
file  umask.c
 Set File Creation Mask.
file  unlink.c
file  unmount.c
 Unmount a File System.
file  utime.c
 Set file access and modification times in seconds.
file  utimensat.c
 Set file access and modification times in nanoseconds.
file  utimes.c
 Set file access and modification times in milliseconds.
file  utsname.c
 Get System Name.
file  vprintk.c
 This source file contains the implementation of vprintk().
file  write.c
 Write to a File.
file  write_r.c
 POSIX 1003.1b 6.4.2 - Write to a File.
file  writev.c
 writev() - POSIX 1003.1 - Write a Vector
