RTEMS 6.1-rc1
Data Structures | Macros | Typedefs | Enumerations | Functions
intr.h File Reference
This header file defines the Interrupt Manager API. More...
#include <stddef.h>
#include <stdint.h>
#include <sys/cpuset.h>
#include <rtems/rtems/attr.h>
#include <rtems/rtems/modes.h>
#include <rtems/rtems/options.h>
#include <rtems/score/cpu.h>
#include <rtems/score/isr.h>
#include <rtems/score/isrlevel.h>
#include <rtems/score/isrlock.h>
#include <rtems/score/smplock.h>
struct  rtems_interrupt_entry
 This structure represents an interrupt entry. More...
struct  rtems_interrupt_attributes
 This structure provides the attributes of an interrupt vector. More...
struct  rtems_interrupt_server_control
 This structure represents an interrupt server. More...
struct  rtems_interrupt_server_config
 This structure defines an interrupt server configuration. More...
struct  rtems_interrupt_server_action
 This structure represents an interrupt server action. More...
struct  rtems_interrupt_server_entry
 This structure represents an interrupt server entry. More...
struct  rtems_interrupt_server_request
 This structure represents an interrupt server request. More...
#define rtems_interrupt_disable(_isr_cookie)   _ISR_Local_disable( _isr_cookie )
 Disables the maskable interrupts on the current processor. More...
#define rtems_interrupt_enable(_isr_cookie)   _ISR_Local_enable( _isr_cookie )
 Restores the previous interrupt level on the current processor. More...
#define rtems_interrupt_flash(_isr_cookie)   _ISR_Local_flash( _isr_cookie )
 Flashes interrupts on the current processor. More...
#define rtems_interrupt_local_disable(_isr_cookie)    _ISR_Local_disable( _isr_cookie )
#define rtems_interrupt_local_enable(_isr_cookie)    _ISR_Local_enable( _isr_cookie )
#define rtems_interrupt_is_in_progress()   _ISR_Is_in_progress()
 Checks if an ISR is in progress on the current processor. More...
#define rtems_interrupt_lock_initialize(_lock, _name)    _ISR_lock_Initialize( _lock, _name )
 Initializes the ISR lock. More...
#define rtems_interrupt_lock_destroy(_lock)   _ISR_lock_Destroy( _lock )
 Destroys the ISR lock. More...
#define rtems_interrupt_lock_acquire(_lock, _lock_context)    _ISR_lock_ISR_disable_and_acquire( _lock, _lock_context )
 Acquires the ISR lock. More...
#define rtems_interrupt_lock_release(_lock, _lock_context)    _ISR_lock_Release_and_ISR_enable( _lock, _lock_context )
 Releases the ISR lock. More...
#define rtems_interrupt_lock_acquire_isr(_lock, _lock_context)    do { (void) _lock_context; } while ( 0 )
 Acquires the ISR lock from within an ISR. More...
#define rtems_interrupt_lock_release_isr(_lock, _lock_context)    do { (void) _lock_context; } while ( 0 )
 Releases the ISR lock from within an ISR. More...
#define rtems_interrupt_lock_interrupt_disable(_lock_context)    _ISR_lock_ISR_disable( _lock_context )
 Disables maskable interrupts on the current processor. More...
#define RTEMS_INTERRUPT_LOCK_DECLARE(_specifier, _designator)    ISR_LOCK_DECLARE( _specifier, _designator )
 Declares an ISR lock object. More...
#define RTEMS_INTERRUPT_LOCK_DEFINE(_specifier, _designator, _name)    ISR_LOCK_DEFINE( _specifier, _designator, _name )
 Defines an ISR lock object. More...
#define RTEMS_INTERRUPT_LOCK_INITIALIZER(_name)   ISR_LOCK_INITIALIZER( _name )
 Statically initializes an ISR lock object. More...
#define RTEMS_INTERRUPT_LOCK_MEMBER(_designator)    ISR_LOCK_MEMBER( _designator )
 Defines an ISR lock member. More...
#define RTEMS_INTERRUPT_LOCK_REFERENCE(_designator, _target)    ISR_LOCK_REFERENCE( _designator, _target )
 Defines an ISR lock object reference. More...
#define RTEMS_INTERRUPT_SHARED   ( (rtems_option) 0x00000000 )
 This interrupt handler install option allows that the interrupt handler may share the interrupt vector with other handler.
#define RTEMS_INTERRUPT_UNIQUE   ( (rtems_option) 0x00000001 )
 This interrupt handler install option ensures that the interrupt handler is unique. More...
#define RTEMS_INTERRUPT_REPLACE   ( (rtems_option) 0x00000002 )
 This interrupt handler install option requests that the interrupt handler replaces the first handler with the same argument.
#define RTEMS_INTERRUPT_IS_SHARED(_options)    ( ( _options ) & RTEMS_INTERRUPT_SHARED )
 Checks if the interrupt handler shared option is set. More...
#define RTEMS_INTERRUPT_IS_UNIQUE(_options)    ( ( _options ) & RTEMS_INTERRUPT_UNIQUE )
 Checks if the interrupt handler unique option is set. More...
#define RTEMS_INTERRUPT_IS_REPLACE(_options)    ( ( _options ) & RTEMS_INTERRUPT_REPLACE )
 Checks if the interrupt handler replace option is set. More...
#define RTEMS_INTERRUPT_ENTRY_INITIALIZER(_routine, _arg, _info)    { _routine, _arg, NULL, _info }
 Statically initializes an interrupt entry object. More...
#define RTEMS_INTERRUPT_SERVER_DEFAULT   0
 The constant represents the index of the default interrupt server.
typedef ISR_Vector_number rtems_vector_number
 This integer type represents interrupt vector numbers.
typedef ISR_Level rtems_interrupt_level
 This integer type represents interrupt levels.
typedef ISR_Handler rtems_isr
 This type defines the return type of interrupt service routines. More...
typedef ISR_Handler_entry rtems_isr_entry
 Interrupt service routines installed by rtems_interrupt_catch() shall have this type.
typedef ISR_lock_Control rtems_interrupt_lock
 This structure represents an ISR lock.
typedef ISR_lock_Context rtems_interrupt_lock_context
 This structure provides an ISR lock context for acquire and release pairs.
typedef void(* rtems_interrupt_handler) (void *)
 Interrupt handler routines shall have this type.
typedef void(* rtems_interrupt_per_handler_routine) (void *, const char *, rtems_option, rtems_interrupt_handler, void *)
 Visitor routines invoked by rtems_interrupt_handler_iterate() shall have this type.
typedef struct rtems_interrupt_entry rtems_interrupt_entry
typedef struct rtems_interrupt_server_control rtems_interrupt_server_control
typedef struct rtems_interrupt_server_action rtems_interrupt_server_action
enum  rtems_interrupt_signal_variant {
  RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL , RTEMS_INTERRUPT_NO_SIGNAL , RTEMS_INTERRUPT_SIGNAL_LEVEL_LOW , RTEMS_INTERRUPT_SIGNAL_LEVEL_HIGH ,
  RTEMS_INTERRUPT_SIGNAL_EDGE_FALLING , RTEMS_INTERRUPT_SIGNAL_EDGE_RAISING
 This enumeration provides interrupt trigger signal variants. More...
rtems_status_code rtems_interrupt_catch (rtems_isr_entry new_isr_handler, rtems_vector_number vector, rtems_isr_entry *old_isr_handler)
 Establishes an interrupt service routine. More...
rtems_status_code rtems_interrupt_entry_install (rtems_vector_number vector, rtems_option options, rtems_interrupt_entry *entry)
 Installs the interrupt entry at the interrupt vector. More...
rtems_status_code rtems_interrupt_entry_remove (rtems_vector_number vector, rtems_interrupt_entry *entry)
 Removes the interrupt entry from the interrupt vector. More...
rtems_status_code rtems_interrupt_handler_install (rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler routine, void *arg)
 Installs the interrupt handler routine and argument at the interrupt vector. More...
rtems_status_code rtems_interrupt_handler_remove (rtems_vector_number vector, rtems_interrupt_handler routine, void *arg)
 Removes the interrupt handler routine and argument from the interrupt vector. More...
rtems_status_code rtems_interrupt_vector_is_enabled (rtems_vector_number vector, bool *enabled)
 Checks if the interrupt vector is enabled. More...
rtems_status_code rtems_interrupt_vector_enable (rtems_vector_number vector)
 Enables the interrupt vector. More...
rtems_status_code rtems_interrupt_vector_disable (rtems_vector_number vector)
 Disables the interrupt vector. More...
rtems_status_code rtems_interrupt_is_pending (rtems_vector_number vector, bool *pending)
 Checks if the interrupt is pending. More...
rtems_status_code rtems_interrupt_raise (rtems_vector_number vector)
 Raises the interrupt vector. More...
rtems_status_code rtems_interrupt_raise_on (rtems_vector_number vector, uint32_t cpu_index)
 Raises the interrupt vector on the processor. More...
rtems_status_code rtems_interrupt_clear (rtems_vector_number vector)
 Clears the interrupt vector. More...
rtems_status_code rtems_interrupt_get_affinity (rtems_vector_number vector, size_t affinity_size, cpu_set_t *affinity)
 Gets the processor affinity set of the interrupt vector. More...
rtems_status_code rtems_interrupt_set_affinity (rtems_vector_number vector, size_t affinity_size, const cpu_set_t *affinity)
 Sets the processor affinity set of the interrupt vector. More...
rtems_status_code rtems_interrupt_get_attributes (rtems_vector_number vector, rtems_interrupt_attributes *attributes)
 Gets the attributes of the interrupt vector. More...
rtems_status_code rtems_interrupt_handler_iterate (rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg)
 Iterates over all interrupt handler installed at the interrupt vector. More...
rtems_status_code rtems_interrupt_server_initialize (rtems_task_priority priority, size_t stack_size, rtems_mode modes, rtems_attribute attributes, uint32_t *server_count)
 Initializes the interrupt server tasks. More...
rtems_status_code rtems_interrupt_server_create (rtems_interrupt_server_control *control, const rtems_interrupt_server_config *config, uint32_t *server_index)
 Creates an interrupt server. More...
rtems_status_code rtems_interrupt_server_handler_install (uint32_t server_index, rtems_vector_number vector, const char *info, rtems_option options, rtems_interrupt_handler routine, void *arg)
 Installs the interrupt handler routine and argument at the interrupt vector on the interrupt server. More...
rtems_status_code rtems_interrupt_server_handler_remove (uint32_t server_index, rtems_vector_number vector, rtems_interrupt_handler routine, void *arg)
 Removes the interrupt handler routine and argument from the interrupt vector and the interrupt server. More...
rtems_status_code rtems_interrupt_server_set_affinity (uint32_t server_index, size_t affinity_size, const cpu_set_t *affinity, rtems_task_priority priority)
 Sets the processor affinity of the interrupt server. More...
rtems_status_code rtems_interrupt_server_delete (uint32_t server_index)
 Deletes the interrupt server. More...
rtems_status_code rtems_interrupt_server_suspend (uint32_t server_index)
 Suspends the interrupt server. More...
rtems_status_code rtems_interrupt_server_resume (uint32_t server_index)
 Resumes the interrupt server. More...
rtems_status_code rtems_interrupt_server_move (uint32_t source_server_index, rtems_vector_number vector, uint32_t destination_server_index)
 Moves the interrupt handlers installed at the interrupt vector and the source interrupt server to the destination interrupt server. More...
rtems_status_code rtems_interrupt_server_handler_iterate (uint32_t server_index, rtems_vector_number vector, rtems_interrupt_per_handler_routine routine, void *arg)
 Iterates over all interrupt handler installed at the interrupt vector and interrupt server. More...
rtems_status_code rtems_interrupt_server_entry_initialize (uint32_t server_index, rtems_interrupt_server_entry *entry)
 Initializes the interrupt server entry. More...
void rtems_interrupt_server_action_prepend (rtems_interrupt_server_entry *entry, rtems_interrupt_server_action *action, rtems_interrupt_handler routine, void *arg)
 Prepends the interrupt server action to the list of actions of the interrupt server entry. More...
void rtems_interrupt_server_entry_destroy (rtems_interrupt_server_entry *entry)
 Destroys the interrupt server entry. More...
void rtems_interrupt_server_entry_submit (rtems_interrupt_server_entry *entry)
 Submits the interrupt server entry to be serviced by the interrupt server. More...
rtems_status_code rtems_interrupt_server_entry_move (rtems_interrupt_server_entry *entry, uint32_t server_index)
 Moves the interrupt server entry to the interrupt server. More...
rtems_status_code rtems_interrupt_server_request_initialize (uint32_t server_index, rtems_interrupt_server_request *request, rtems_interrupt_handler routine, void *arg)
 Initializes the interrupt server request. More...
◆ RTEMS_INTERRUPT_IS_REPLACE
#define RTEMS_INTERRUPT_IS_REPLACE (   _options)     ( ( _options ) & RTEMS_INTERRUPT_REPLACE )
Parameters
_optionsis the interrupt handler option set to check.
Returns
Returns true, if the interrupt handler replace option RTEMS_INTERRUPT_REPLACE is set, otherwise false.
◆ RTEMS_INTERRUPT_IS_SHARED
#define RTEMS_INTERRUPT_IS_SHARED (   _options)     ( ( _options ) & RTEMS_INTERRUPT_SHARED )
Parameters
Returns
Returns true, if the interrupt handler shared option RTEMS_INTERRUPT_SHARED is set, otherwise false.
◆ RTEMS_INTERRUPT_IS_UNIQUE
#define RTEMS_INTERRUPT_IS_UNIQUE (   _options)     ( ( _options ) & RTEMS_INTERRUPT_UNIQUE )
Parameters
Returns
Returns true, if the interrupt handler unique option RTEMS_INTERRUPT_UNIQUE is set, otherwise false.
