RTEMS
6.1-rc1
include
score
isrlock.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
12
13
* Copyright (C) 2013, 2019 embedded brains GmbH & Co. KG
14
15
16
* modification, are permitted provided that the following conditions
17
* are met:
18
* 1. Redistributions of source code must retain the above copyright
19
* notice, this list of conditions and the following disclaimer.
20
* 2. Redistributions in binary form must reproduce the above copyright
21
* notice, this list of conditions and the following disclaimer in the
22
* documentation and/or other materials provided with the distribution.
23
24
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
25
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
26
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
27
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
28
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
29
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
30
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
31
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
32
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
33
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
34
* POSSIBILITY OF SUCH DAMAGE.
35
36
37
#ifndef _RTEMS_SCORE_ISR_LOCK_H
38
#define _RTEMS_SCORE_ISR_LOCK_H
39
40
rtems/score/isrlevel.h
41
rtems/score/smplock.h
42
43
#ifdef __cplusplus
44
extern
"C"
45
#endif
46
72
typedef
struct
73
#if defined( RTEMS_SMP )
74
SMP_lock_Control Lock;
75
#endif
76
ISR_lock_Control
77
81
typedef
struct
82
83
SMP_lock_Context Lock_context;
84
#else
85
ISR_Level
isr_level;
86
#endif
87
#if defined( RTEMS_PROFILING )
91
CPU_Counter_ticks ISR_disable_instant;
92
#endif
93
ISR_lock_Context
94
102
103
#define ISR_LOCK_MEMBER( _designator ) ISR_lock_Control _designator;
104
#else
105
106
#endif
107
116
117
#define ISR_LOCK_DECLARE( _qualifier, _designator ) \
118
_qualifier ISR_lock_Control _designator;
119
#else
120
121
#endif
122
133
134
#define ISR_LOCK_DEFINE( _qualifier, _designator, _name ) \
135
_qualifier ISR_lock_Control _designator = { SMP_LOCK_INITIALIZER( _name ) };
136
#else
137
138
#endif
139
148
149
#define ISR_LOCK_REFERENCE( _designator, _target ) \
150
ISR_lock_Control *_designator = _target;
151
#else
152
153
#endif
154
161
162
#define ISR_LOCK_INITIALIZER( _name ) \
163
164
#else
165
166
167
#endif
168
175
static
inline
void
_ISR_lock_Context_set_level(
176
ISR_lock_Context
context
177
ISR_Level
level
178
179
180
181
context
->Lock_context.isr_level = level;
182
#else
183
context
->isr_level = level;
184
#endif
185
186
197
198
#define _ISR_lock_Initialize( _lock, _name ) \
199
_SMP_lock_Initialize( &( _lock )->Lock, _name )
200
#else
201
202
#endif
203
211
212
#define _ISR_lock_Destroy( _lock ) \
213
_SMP_lock_Destroy( &( _lock )->Lock )
214
#else
215
216
#endif
217
226
227
#define _ISR_lock_Set_name( _lock, _name ) \
228
_SMP_lock_Set_name( &( _lock )->Lock, _name )
229
#else
230
231
#endif
232
247
248
#define _ISR_lock_ISR_disable_and_acquire( _lock, _context ) \
249
_SMP_lock_ISR_disable_and_acquire( \
250
&( _lock )->Lock, \
251
&( _context )->Lock_context \
252
253
#else
254
255
_ISR_Local_disable( ( _context )->isr_level )
256
#endif
257
272
273
#define _ISR_lock_Release_and_ISR_enable( _lock, _context ) \
274
_SMP_lock_Release_and_ISR_enable( \
275
&( _lock )->Lock, \
276
277
278
#else
279
280
_ISR_Local_enable( ( _context )->isr_level )
281
#endif
282
299
300
#define _ISR_lock_Acquire( _lock, _context ) \
301
do { \
302
_Assert( _ISR_Get_level() != 0 ); \
303
_SMP_lock_Acquire( \
304
&( _lock )->Lock, \
305
306
307
} while ( 0 )
308
#else
309
310
do { (void) _context; } while ( 0 )
311
#endif
312
325
326
#define _ISR_lock_Release( _lock, _context ) \
327
_SMP_lock_Release( \
328
&( _lock )->Lock, \
329
330
331
#else
332
333
334
#endif
335
341
342
#define _ISR_lock_Acquire_inline( _lock, _context ) \
343
do { \
344
345
_SMP_lock_Acquire_inline( \
346
&( _lock )->Lock, \
347
348
349
} while ( 0 )
350
#else
351
352
353
#endif
354
360
361
#define _ISR_lock_Release_inline( _lock, _context ) \
362
_SMP_lock_Release_inline( \
363
&( _lock )->Lock, \
364
365
366
#else
367
368
369
#endif
370
371
#if defined( RTEMS_DEBUG )
381
382
#define _ISR_lock_Is_owner( _lock ) \
383
_SMP_lock_Is_owner( &( _lock )->Lock )
384
#else
385
386
387
#endif
388
#endif
389
390
391
#define _ISR_lock_ISR_disable_profile( _context ) \
392
( _context )->ISR_disable_instant = _CPU_Counter_read();
393
#else
394
395
#endif
396
407
408
#define _ISR_lock_ISR_disable( _context ) \
409
do { \
410
_ISR_Local_disable( ( _context )->Lock_context.isr_level ); \
411
412
} while ( 0 )
413
#else
414
415
do { \
416
_ISR_Local_disable( ( _context )->isr_level ); \
417
418
} while ( 0 )
419
#endif
420
431
432
#define _ISR_lock_ISR_enable( _context ) \
433
_ISR_Local_enable( ( _context )->Lock_context.isr_level )
434
#else
435
436
437
#endif
438
441
#ifdef __cplusplus
442
443
#endif
444
445
#endif
/* _RTEMS_SCORE_ISR_LOCK_H */
ISR_Level
uint32_t ISR_Level
Definition:
isrlevel.h:60
isrlevel.h
This header file provides the ISR_Level related interfaces of the ISR Handler.
context
rtems_termios_device_context * context
Definition:
console-config.c:62
smplock.h
This header file provides the main interfaces of the SMP Locks.
ISR_lock_Context
Local ISR lock context for acquire and release pairs.
Definition:
isrlock.h:81
ISR_lock_Control
ISR lock control.
Definition:
isrlock.h:72
