RTEMS 6.1-rc1
Macros | Typedefs | Functions
config.h File Reference
This header file provides parts of the application configuration information API. More...
#include <stddef.h>
#include <stdint.h>
#include <rtems/rtems/config.h>
#include <rtems/score/cpu.h>
#include <rtems/score/isr.h>
#include <rtems/score/memory.h>
#include <rtems/score/smp.h>
#include <rtems/score/stack.h>
#include <rtems/score/threadidledata.h>
#include <rtems/score/userextdata.h>
#include <rtems/score/watchdogticks.h>
#include <rtems/score/wkspacedata.h>
#define RTEMS_UNLIMITED_OBJECTS   OBJECTS_UNLIMITED_OBJECTS
 This flag is used in augment a resource number so that it indicates an unlimited resource.
#define rtems_configuration_get_stack_allocator_avoids_work_space()    _Stack_Allocator_avoids_workspace
 Indicates if the task stack allocator is configured to avoid the RTEMS Workspace for this application. More...
#define RTEMS_HAS_HARDWARE_FP   CPU_HARDWARE_FP
 This constant evaluates to TRUE, if this processor variant has hardware floating point support, otherwise to FALSE.
#define rtems_configuration_get_do_zero_of_workspace()   _Memory_Zero_before_use
 Indicates if the RTEMS Workspace is configured to be zeroed during system initialization for this application. More...
#define rtems_configuration_get_idle_task_stack_size()   _Thread_Idle_stack_size
 Gets the IDLE task stack size in bytes of this application. More...
#define rtems_configuration_get_idle_task()   _Thread_Idle_body
 Gets the IDLE task body of this application. More...
#define rtems_configuration_get_interrupt_stack_size()    ((size_t) _ISR_Stack_size_object)
 Gets the interrupt stack size in bytes of this application. More...
#define rtems_configuration_get_maximum_processors()    _SMP_Processor_configured_maximum
 Gets the maximum number of processors configured for this application. More...
#define rtems_configuration_get_microseconds_per_tick()    _Watchdog_Microseconds_per_tick
 Gets the number of microseconds per clock tick configured for this application. More...
#define rtems_configuration_get_milliseconds_per_tick()    ( _Watchdog_Microseconds_per_tick / 1000 )
 Gets the number of milliseconds per clock tick configured for this application. More...
#define rtems_configuration_get_nanoseconds_per_tick()    _Watchdog_Nanoseconds_per_tick
#define rtems_configuration_get_number_of_initial_extensions()    ((uint32_t) _User_extensions_Initial_count)
 Gets the number of initial extensions configured for this application. More...
#define rtems_configuration_get_stack_allocate_for_idle_hook()    _Stack_Allocator_allocate_for_idle
 Gets the task stack allocator allocate hook used to allocate the stack of each IDLE task configured for this application. More...
#define rtems_configuration_get_stack_allocate_hook()   _Stack_Allocator_allocate
 Gets the task stack allocator allocate hook configured for this application. More...
#define rtems_configuration_get_stack_allocate_init_hook()    _Stack_Allocator_initialize
 Gets the task stack allocator initialization hook configured for this application. More...
#define rtems_configuration_get_stack_free_hook()   _Stack_Allocator_free
 Gets the task stack allocator free hook configured for this application. More...
#define rtems_configuration_get_ticks_per_timeslice()    _Watchdog_Ticks_per_timeslice
 Gets the clock ticks per timeslice configured for this application. More...
#define rtems_configuration_get_unified_work_area()   _Workspace_Is_unified
 Indicates if the RTEMS Workspace and C Program Heap are configured to be unified for this application. More...
#define rtems_configuration_get_user_extension_table()    _User_extensions_Initial_extensions
 Gets the initial extensions table configured for this application. More...
#define rtems_configuration_get_user_multiprocessing_table()   NULL
 Gets the MPCI configuration table configured for this application. More...
#define rtems_configuration_get_work_space_size()
 Gets the RTEMS Workspace size in bytes configured for this application. More...
#define rtems_resource_is_unlimited(_resource)    _Objects_Is_unlimited( _resource )
 Indicates if the resource is unlimited. More...
#define rtems_resource_maximum_per_allocation(_resource)    _Objects_Maximum_per_allocation( _resource )
 Gets the maximum number per allocation of a resource number. More...
#define rtems_resource_unlimited(_resource)    ( ( _resource ) | RTEMS_UNLIMITED_OBJECTS )
 Augments the resource number so that it indicates an unlimited resource. More...
typedef Stack_Allocator_allocate rtems_stack_allocate_hook
 A thread stack allocator allocate handler shall have this type.
typedef Stack_Allocator_initialize rtems_stack_allocate_init_hook
 A task stack allocator initialization handler shall have this type.
typedef Stack_Allocator_free rtems_stack_free_hook
 A task stack allocator free handler shall have this type.
uintptr_t rtems_configuration_get_stack_space_size (void)
 Gets the configured size in bytes of the memory space used to allocate thread stacks for this application. More...
const char * rtems_get_build_label (void)
 Gets the RTEMS build label. More...
const char * rtems_get_copyright_notice (void)
 Gets the RTEMS copyright notice. More...
const char * rtems_get_target_hash (void)
 Gets the RTEMS target hash. More...
const char * rtems_get_version_string (void)
 Gets the RTEMS version string. More...
uint32_t rtems_configuration_get_maximum_extensions (void)
 Gets the resource number of User Extensions Manager objects configured for this application. More...
