RTEMS 6.1-rc1
This group contains the Application Programming Interfaces (APIs) of RTEMS. More...
Modules | |
Application Configuration Information | |
The application configuration information group provides an API to get the configuration of an application. | |
Application Configuration Options | |
Associativity Routines | |
BSD Compatibility Support | |
Base Definitions | |
This group contains basic macros and defines to give access to compiler-specific features. | |
CPU Usage Reporting | |
The CPU usage reporting directives can be used to report and reset the CPU usage of threads. | |
Classic | |
This group contains the Classic API managers. | |
Dynamic Memory Allocation | |
This group contains non-standard interfaces to use dynamic memory allocation. | |
Free-Running Counter and Busy Wait Delay | |
Free-running counter and busy wait delay functions. | |
Hash Algorithms | |
This group contains interfaces to hash algorithms. | |
IO | |
IO. | |
Linker Sets | |
This group contains the linker sets API. | |
Profiling Support | |
The profiling support offers functions to report profiling information available in the system. | |
RTEMS Application Loader | |
RTEMS Runtime Link Editor | |
RTEMS Test Framework | |
The RTEMS Test Framework helps you to write tests. | |
Red-Black Tree Heap | |
The red-black tree heap provides a memory allocator using a red-black tree to maintain blocks of memory. | |
Self-Contained Objects | |
This group contains the self-contained objects API. | |
Set Error Number Support | |
Status Checks | |
System Initialization Support | |
The system initialization support provides an ordered invocation of system initialization handlers registered in a linker set. | |
System Library | |
This group contains the system library APIs of RTEMS. | |
Test Support | |
Test support functions. | |
Tracing | |
Tracing. | |
Files | |
file | testrun.c |
Implementation of rtems_test_run_default(). | |
This group contains the RTEMS Application Programming Interface (API).
