RTEMS 6.1-rc1
userextdata.h
2
14/*
15 * COPYRIGHT (c) 1989-2009.
16 * On-Line Applications Research Corporation (OAR).
17 *
18 * Redistribution and use in source and binary forms, with or without
19 * modification, are permitted provided that the following conditions
20 * are met:
21 * 1. Redistributions of source code must retain the above copyright
22 * notice, this list of conditions and the following disclaimer.
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in the
25 * documentation and/or other materials provided with the distribution.
26 *
27 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
28 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
29 * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
30 * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
31 * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
32 * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
33 * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
34 * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
35 * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
36 * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
37 * POSSIBILITY OF SUCH DAMAGE.
38 */
39
40#ifndef _RTEMS_SCORE_USEREXTDATA_H
41#define _RTEMS_SCORE_USEREXTDATA_H
42
43#include <rtems/score/userext.h>
44#include <rtems/score/chain.h>
45
46#ifdef __cplusplus
47extern "C" {
48#endif
49
61typedef struct {
62 Chain_Node Node;
65
72typedef struct {
73 Chain_Node Node;
75 User_extensions_Table Callouts;
77
83extern const size_t _User_extensions_Initial_count;
84
91
99
102#ifdef __cplusplus
103}
104#endif
105
106#endif
107/* end of include file */
User_extensions_Switch_control _User_extensions_Initial_switch_controls[]
A spare switch control for each initial user extension.
void(* User_extensions_thread_switch_extension)(struct _Thread_Control *executing, struct _Thread_Control *heir)
Task switch extension.
Definition: userext.h:177
The count of initial user extensions.
const User_extensions_Table _User_extensions_Initial_extensions[]
The table of initial user extensions.
This header file provides interfaces of the Chain Handler which are used by the implementation and th...
This structure represents a chain node.
Definition: chain.h:78
Manages each user extension set.
Definition: userextdata.h:72
Manages the switch callouts.
Definition: userextdata.h:61
User extension table.
Definition: userext.h:253
This header file provides interfaces of the User Extensions Handler which are used by the implementat...
