uint32_t | CLOCK_GetFreq (clock_name_t name) |
| Gets the clock frequency for a specific clock name. More...
void | CLOCK_OSC_EnableOsc24M (void) |
| Enable OSC 24Mhz. More...
void | CLOCK_OSC_SetOsc24MWorkMode (clock_24MOsc_mode_t workMode) |
| Set the work mode of 24MHz crystal oscillator, the available modes are high gian mode, low power mode, and bypass mode. More...
void | CLOCK_OSC_EnableOscRc400M (void) |
| Enable OSC RC 400Mhz. More...
void | CLOCK_OSC_TrimOscRc400M (bool enable, bool bypass, uint16_t trim) |
| Trims OSC RC 400MHz. More...
void | CLOCK_OSC_SetOscRc400MRefClkDiv (uint8_t divValue) |
| Set the divide value for ref_clk to generate slow clock. More...
void | CLOCK_OSC_SetOscRc400MFastClkCount (uint16_t targetCount) |
| Set the target count for the fast clock. More...
void | CLOCK_OSC_SetOscRc400MHysteresisValue (uint8_t negHysteresis, uint8_t posHysteresis) |
| Set the negative and positive hysteresis value for the tuned clock. More...
void | CLOCK_OSC_BypassOscRc400MTuneLogic (bool enableBypass) |
| Bypass/un-bypass the tune logic. More...
void | CLOCK_OSC_EnableOscRc400MTuneLogic (bool enable) |
| Start/Stop the tune logic. More...
void | CLOCK_OSC_FreezeOscRc400MTuneValue (bool enableFreeze) |
| Freeze/Unfreeze the tuning value. More...
void | CLOCK_OSC_SetOscRc400MTuneValue (uint8_t tuneValue) |
| Set the 400MHz RC oscillator tune value when the tune logic is disabled. More...
void | CLOCK_OSC_Set1MHzOutputBehavior (clock_1MHzOut_behavior_t behavior) |
| Set the behavior of the 1MHz output clock, such as disable the 1MHz clock output, enable the free-running 1MHz clock output, enable the locked 1MHz clock output. More...
void | CLOCK_OSC_SetLocked1MHzCount (uint16_t count) |
| Set the count for the locked 1MHz clock out. More...
bool | CLOCK_OSC_CheckLocked1MHzErrorFlag (void) |
| Check the error flag for locked 1MHz clock out. More...
void | CLOCK_OSC_ClearLocked1MHzErrorFlag (void) |
| Clear the error flag for locked 1MHz clock out. More...
uint16_t | CLOCK_OSC_GetCurrentOscRc400MFastClockCount (void) |
| Get current count for the fast clock during the tune process. More...
uint8_t | CLOCK_OSC_GetCurrentOscRc400MTuneValue (void) |
| Get current tune value used by oscillator during tune process. More...
void | CLOCK_OSC_SetOsc16MConfig (clock_16MOsc_source_t source, bool enablePowerSave, bool enableClockOut) |
| Configure the 16MHz oscillator. More...
status_t | CLOCK_CalcArmPllFreq (clock_arm_pll_config_t *config, uint32_t freqInMhz) |
| Calculate corresponding config values per given frequency. More...
status_t | CLOCK_InitArmPllWithFreq (uint32_t freqInMhz) |
| Initializes the Arm PLL with Specific Frequency (in Mhz). More...
void | CLOCK_CalcPllSpreadSpectrum (uint32_t factor, uint32_t range, uint32_t mod, clock_pll_ss_config_t *ss) |
| Calculate spread spectrum step and stop. More...
void | CLOCK_InitSysPll1 (const clock_sys_pll1_config_t *config) |
| Initialize the System PLL1. More...
void | CLOCK_DeinitSysPll1 (void) |
| De-initialize the System PLL1.
void | CLOCK_GPC_SetSysPll1OutputFreq (const clock_sys_pll1_gpc_config_t *config) |
| Set System PLL1 output frequency in GPC mode. More...
void | CLOCK_InitSysPll2 (const clock_sys_pll2_config_t *config) |
| Initialize the System PLL2. More...
void | CLOCK_DeinitSysPll2 (void) |
| De-initialize the System PLL2.
bool | CLOCK_IsSysPll2PfdEnabled (clock_pfd_t pfd) |
| Check if Sys PLL2 PFD is enabled. More...
void | CLOCK_InitSysPll3 (void) |
| Initialize the System PLL3. More...
void | CLOCK_DeinitSysPll3 (void) |
| De-initialize the System PLL3.
bool | CLOCK_IsSysPll3PfdEnabled (clock_pfd_t pfd) |
| Check if Sys PLL3 PFD is enabled. More...
void | CLOCK_InitArmPll (const clock_arm_pll_config_t *config) |
| Initialize the ARM PLL. More...
void | CLOCK_DeinitArmPll (void) |
| De-initialize the ARM PLL. More...
void | CLOCK_InitAudioPll (const clock_audio_pll_config_t *config) |
| Initializes the Audio PLL. More...
void | CLOCK_DeinitAudioPll (void) |
| De-initialize the Audio PLL. More...
void | CLOCK_InitVideoPll (const clock_video_pll_config_t *config) |
| Initialize the video PLL. More...
void | CLOCK_DeinitVideoPll (void) |
| De-initialize the Video PLL. More...
uint32_t | CLOCK_GetPllFreq (clock_pll_t pll) |
| Get current PLL output frequency. More...
bool | CLOCK_EnableUsbhs0PhyPllClock (clock_usb_phy_src_t src, uint32_t freq) |
| Enable USB HS PHY PLL clock. More...
void | CLOCK_DisableUsbhs0PhyPllClock (void) |
| Disable USB HS PHY PLL clock. More...
bool | CLOCK_EnableUsbhs1PhyPllClock (clock_usb_phy_src_t src, uint32_t freq) |
void | CLOCK_DisableUsbhs1PhyPllClock (void) |
void | CLOCK_SetPllBypass (clock_pll_t pll, bool bypass) |
| PLL bypass setting. More...
status_t | CLOCK_CalcAvPllFreq (clock_av_pll_config_t *config, uint32_t freqInMhz) |
status_t | CLOCK_InitAudioPllWithFreq (uint32_t freqInMhz, bool ssEnable, uint32_t ssRange, uint32_t ssMod) |
| Initializes the Audio PLL with Specific Frequency (in Mhz). More...
void | CLOCK_GPC_SetAudioPllOutputFreq (const clock_audio_pll_gpc_config_t *config) |
| Set Audio PLL output frequency in GPC mode. More...
status_t | CLOCK_InitVideoPllWithFreq (uint32_t freqInMhz, bool ssEnable, uint32_t ssRange, uint32_t ssMod) |
| Initializes the Video PLL with Specific Frequency (in Mhz). More...
void | CLOCK_GPC_SetVideoPllOutputFreq (const clock_video_pll_gpc_config_t *config) |
| Set Video PLL output frequency in GPC mode. More...
void | CLOCK_InitPfd (clock_pll_t pll, clock_pfd_t pfd, uint8_t frac) |
| Initialize PLL PFD. More...
void | CLOCK_DeinitPfd (clock_pll_t pll, clock_pfd_t pfd) |
| De-initialize selected PLL PFD. More...
uint32_t | CLOCK_GetPfdFreq (clock_pll_t pll, clock_pfd_t pfd) |
| Get current PFD output frequency. More...
uint32_t | CLOCK_GetFreqFromObs (uint32_t obsSigIndex, uint32_t obsIndex) |
void | CLOCK_OSCPLL_ControlBySetPointMode (clock_name_t name, uint16_t spValue, uint16_t stbyValue) |
| Set this clock works in SetPoint control Mode. More...
void | CLOCK_OSCPLL_ControlByCpuLowPowerMode (clock_name_t name, uint8_t domainId, clock_level_t level0, clock_level_t level1) |
| Set this clock works in CPU Low Power Mode. More...
void | CLOCK_ROOT_ControlBySetPointMode (clock_root_t name, const clock_root_setpoint_config_t *spTable) |
| Set this clock works in SetPoint controlled Mode. More...
void | CLOCK_LPCG_ControlBySetPointMode (clock_lpcg_t name, uint16_t spValue, uint16_t stbyValue) |
void | CLOCK_LPCG_ControlByCpuLowPowerMode (clock_lpcg_t name, uint8_t domainId, clock_level_t level0, clock_level_t level1) |
bool | CLOCK_EnableUsbhs0Clock (clock_usb_src_t src, uint32_t freq) |
| Enable USB HS clock. More...
bool | CLOCK_EnableUsbhs1Clock (clock_usb_src_t src, uint32_t freq) |
#define | FSL_CLOCK_DRIVER_VERSION (MAKE_VERSION(2, 1, 2)) |
| CLOCK driver version.
#define | SDK_DEVICE_MAXIMUM_CPU_CLOCK_FREQUENCY (240000000UL) |
#define | CCSR_OFFSET 0x0C |
| CCM registers offset.
#define | CBCDR_OFFSET 0x14 |
#define | CBCMR_OFFSET 0x18 |
#define | CSCMR1_OFFSET 0x1C |
#define | CSCMR2_OFFSET 0x20 |
#define | CSCDR1_OFFSET 0x24 |
#define | CDCDR_OFFSET 0x30 |
#define | CSCDR2_OFFSET 0x38 |
#define | CSCDR3_OFFSET 0x3C |
#define | CACRR_OFFSET 0x10 |
#define | CS1CDR_OFFSET 0x28 |
#define | CS2CDR_OFFSET 0x2C |
#define | ARM_PLL_OFFSET 0x00 |
| CCM Analog registers offset.
#define | PLL_SYS_OFFSET 0x30 |
#define | PLL_USB1_OFFSET 0x10 |
#define | PLL_AUDIO_OFFSET 0x70 |
#define | PLL_VIDEO_OFFSET 0xA0 |
#define | PLL_ENET_OFFSET 0xE0 |
#define | PLL_USB2_OFFSET 0x20 |
#define | CCM_TUPLE(reg, shift, mask, busyShift) (int)((reg & 0xFFU) | ((shift) << 8U) | ((((mask) >> (shift)) & 0x1FFFU) << 13U) | ((busyShift) << 26U)) |
#define | CCM_TUPLE_REG(base, tuple) (*((volatile uint32_t *)(((uint32_t)(base)) + ((tuple)&0xFFU)))) |
#define | CCM_TUPLE_SHIFT(tuple) (((tuple) >> 8U) & 0x1FU) |
#define | CCM_TUPLE_MASK(tuple) ((uint32_t)((((tuple) >> 13U) & 0x1FFFU) << ((((tuple) >> 8U) & 0x1FU)))) |
#define | CCM_TUPLE_BUSY_SHIFT(tuple) (((tuple) >> 26U) & 0x3FU) |
#define | CCM_BUSY_WAIT (0x20U) |
#define | CCM_ANALOG_TUPLE(reg, shift) (((reg & 0xFFFU) << 16U) | (shift)) |
| CCM ANALOG tuple macros to map corresponding registers and bit fields.
#define | CCM_ANALOG_TUPLE_SHIFT(tuple) (((uint32_t)tuple) & 0x1FU) |
#define | CCM_ANALOG_TUPLE_REG_OFF(base, tuple, off) (*((volatile uint32_t *)((uint32_t)base + (((uint32_t)tuple >> 16U) & 0xFFFU) + off))) |
#define | CCM_ANALOG_TUPLE_REG(base, tuple) CCM_ANALOG_TUPLE_REG_OFF(base, tuple, 0U) |
#define | SYS_PLL1_FREQ (1000000000UL) |
| SYS_PLL_FREQ frequency in Hz.
#define | SYS_PLL2_MFI (22UL) |
#define | SYS_PLL2_FREQ (XTAL_FREQ * SYS_PLL2_MFI) |
#define | SYS_PLL3_MFI (20UL) |
#define | SYS_PLL3_FREQ (XTAL_FREQ * SYS_PLL3_MFI) |
#define | XTAL_FREQ (24000000UL) |
#define | LPADC_CLOCKS |
| Clock gate name array for ADC. More...
#define | ADC_ETC_CLOCKS |
#define | AOI_CLOCKS |
| Clock gate name array for AOI. More...
#define | DCDC_CLOCKS |
| Clock gate name array for DCDC. More...
#define | SRC_CLOCKS |
| Clock gate name array for SRC. More...
#define | GPC_CLOCKS |
| Clock gate name array for GPC. More...
#define | SSARC_CLOCKS |
| Clock gate name array for SSARC. More...
#define | WDOG_CLOCKS |
| Clock gate name array for WDOG. More...
#define | EWM_CLOCKS |
| Clock gate name array for EWM. More...
#define | SEMA_CLOCKS |
| Clock gate name array for Sema. More...
#define | MU_CLOCKS |
| Clock gate name array for MU. More...
#define | EDMA_CLOCKS |
| Clock gate name array for EDMA. More...
#define | FLEXRAM_CLOCKS |
| Clock gate name array for FLEXRAM. More...
#define | LMEM_CLOCKS |
| Clock gate name array for LMEM. More...
#define | FLEXSPI_CLOCKS |
| Clock gate name array for FLEXSPI. More...
#define | RDC_CLOCKS |
| Clock gate name array for RDC. More...
#define | SEMC_CLOCKS |
| Clock ip name array for SEMC. More...
#define | XECC_CLOCKS |
| Clock ip name array for XECC. More...
#define | IEE_CLOCKS |
| Clock ip name array for IEE. More...
#define | KEYMANAGER_CLOCKS |
| Clock ip name array for KEY_MANAGER. More...
#define | PUF_CLOCKS |
| Clock ip name array for PUF. More...
#define | OCOTP_CLOCKS |
| Clock ip name array for OCOTP. More...
#define | CAAM_CLOCKS |
| Clock ip name array for CAAM. More...
#define | XBAR_CLOCKS |
| Clock ip name array for XBAR. More...
#define | IOMUXC_CLOCKS |
| Clock ip name array for IOMUXC. More...
#define | GPIO_CLOCKS |
| Clock ip name array for GPIO. More...
#define | KPP_CLOCKS |
| Clock ip name array for KPP. More...
#define | FLEXIO_CLOCKS |
| Clock ip name array for FLEXIO. More...
#define | DAC_CLOCKS |
| Clock ip name array for DAC. More...
#define | CMP_CLOCKS |
| Clock ip name array for CMP. More...
#define | PIT_CLOCKS |
| Clock ip name array for PIT. More...
#define | GPT_CLOCKS |
| Clock ip name array for GPT. More...
#define | TMR_CLOCKS |
| Clock ip name array for QTIMER. More...
#define | ENC_CLOCKS |
| Clock ip name array for ENC. More...
#define | PWM_CLOCKS |
| Clock ip name array for PWM. More...
#define | FLEXCAN_CLOCKS |
| Clock ip name array for FLEXCAN. More...
#define | LPUART_CLOCKS |
| Clock ip name array for LPUART. More...
#define | LPI2C_CLOCKS |
| Clock ip name array for LPI2C. More...
#define | LPSPI_CLOCKS |
| Clock ip name array for LPSPI. More...
#define | EMVSIM_CLOCKS |
| Clock ip name array for EMVSIM. More...
#define | ENET_CLOCKS |
| Clock ip name array for ENET. More...
#define | USB_CLOCKS |
| Clock ip name array for USB. More...
#define | CDOG_CLOCKS |
| Clock ip name array for CDOG. More...
#define | USDHC_CLOCKS |
| Clock ip name array for USDHC. More...
#define | ASRC_CLOCKS |
| Clock ip name array for ASRC. More...
#define | MQS_CLOCKS |
| Clock ip name array for MQS. More...
#define | PDM_CLOCKS |
| Clock ip name array for PDM. More...
#define | SPDIF_CLOCKS |
| Clock ip name array for SPDIF. More...
#define | SAI_CLOCKS |
| Clock ip name array for SAI. More...
#define | PXP_CLOCKS |
| Clock ip name array for PXP. More...
#define | GPU2D_CLOCKS |
| Clock ip name array for GPU2d. More...
#define | LCDIF_CLOCKS |
| Clock ip name array for LCDIF. More...
#define | LCDIFV2_CLOCKS |
| Clock ip name array for LCDIFV2. More...
#define | MIPI_DSI_HOST_CLOCKS |
| Clock ip name array for MIPI_DSI. More...
#define | MIPI_CSI2RX_CLOCKS |
| Clock ip name array for MIPI_CSI. More...
#define | CSI_CLOCKS |
| Clock ip name array for CSI. More...
#define | DCIC_CLOCKS |
| Clock ip name array for DCIC. More...
#define | DMAMUX_CLOCKS |
| Clock ip name array for DMAMUX_CLOCKS. More...
#define | XBARA_CLOCKS |
| Clock ip name array for XBARA. More...
#define | XBARB_CLOCKS |
| Clock ip name array for XBARB. More...
#define | CCM_OBS_M7_CLK_ROOT 128, 4 |
#define | CCM_OBS_M4_CLK_ROOT 129, 0 |
#define | CCM_OBS_BUS_CLK_ROOT 130, 2 |
#define | CCM_OBS_BUS_LPSR_CLK_ROOT 131, 0 |
#define | CCM_OBS_SEMC_CLK_ROOT 132, 2 |
#define | CCM_OBS_CSSYS_CLK_ROOT 133, 2 |
#define | CCM_OBS_CSTRACE_CLK_ROOT 134, 2 |
#define | CCM_OBS_M4_SYSTICK_CLK_ROOT 135, 0 |
#define | CCM_OBS_M7_SYSTICK_CLK_ROOT 136, 2 |
#define | CCM_OBS_ADC1_CLK_ROOT 137, 2 |
#define | CCM_OBS_ADC2_CLK_ROOT 138, 2 |
#define | CCM_OBS_ACMP_CLK_ROOT 139, 2 |
#define | CCM_OBS_FLEXIO1_CLK_ROOT 140, 2 |
#define | CCM_OBS_FLEXIO2_CLK_ROOT 141, 2 |
#define | CCM_OBS_GPT1_CLK_ROOT 142, 2 |
#define | CCM_OBS_GPT2_CLK_ROOT 143, 2 |
#define | CCM_OBS_GPT3_CLK_ROOT 144, 2 |
#define | CCM_OBS_GPT4_CLK_ROOT 145, 2 |
#define | CCM_OBS_GPT5_CLK_ROOT 146, 2 |
#define | CCM_OBS_GPT6_CLK_ROOT 147, 2 |
#define | CCM_OBS_FLEXSPI1_CLK_ROOT 148, 2 |
#define | CCM_OBS_FLEXSPI2_CLK_ROOT 149, 2 |
#define | CCM_OBS_CAN1_CLK_ROOT 150, 2 |
#define | CCM_OBS_CAN2_CLK_ROOT 151, 2 |
#define | CCM_OBS_CAN3_CLK_ROOT 152, 0 |
#define | CCM_OBS_LPUART1_CLK_ROOT 153, 2 |
#define | CCM_OBS_LPUART2_CLK_ROOT 154, 2 |
#define | CCM_OBS_LPUART3_CLK_ROOT 155, 2 |
#define | CCM_OBS_LPUART4_CLK_ROOT 156, 2 |
#define | CCM_OBS_LPUART5_CLK_ROOT 157, 2 |
#define | CCM_OBS_LPUART6_CLK_ROOT 158, 2 |
#define | CCM_OBS_LPUART7_CLK_ROOT 159, 2 |
#define | CCM_OBS_LPUART8_CLK_ROOT 160, 2 |
#define | CCM_OBS_LPUART9_CLK_ROOT 161, 2 |
#define | CCM_OBS_LPUART10_CLK_ROOT 162, 2 |
#define | CCM_OBS_LPUART11_CLK_ROOT 163, 0 |
#define | CCM_OBS_LPUART12_CLK_ROOT 164, 0 |
#define | CCM_OBS_LPI2C1_CLK_ROOT 165, 2 |
#define | CCM_OBS_LPI2C2_CLK_ROOT 166, 2 |
#define | CCM_OBS_LPI2C3_CLK_ROOT 167, 2 |
#define | CCM_OBS_LPI2C4_CLK_ROOT 168, 2 |
#define | CCM_OBS_LPI2C5_CLK_ROOT 169, 0 |
#define | CCM_OBS_LPI2C6_CLK_ROOT 170, 0 |
#define | CCM_OBS_LPSPI1_CLK_ROOT 171, 2 |
#define | CCM_OBS_LPSPI2_CLK_ROOT 172, 2 |
#define | CCM_OBS_LPSPI3_CLK_ROOT 173, 2 |
#define | CCM_OBS_LPSPI4_CLK_ROOT 174, 2 |
#define | CCM_OBS_LPSPI5_CLK_ROOT 175, 0 |
#define | CCM_OBS_LPSPI6_CLK_ROOT 176, 0 |
#define | CCM_OBS_EMV1_CLK_ROOT 177, 2 |
#define | CCM_OBS_EMV2_CLK_ROOT 178, 2 |
#define | CCM_OBS_ENET1_CLK_ROOT 179, 2 |
#define | CCM_OBS_ENET2_CLK_ROOT 180, 2 |
#define | CCM_OBS_ENET_25M_CLK_ROOT 182, 2 |
#define | CCM_OBS_ENET_TIMER1_CLK_ROOT 183, 2 |
#define | CCM_OBS_ENET_TIMER2_CLK_ROOT 184, 2 |
#define | CCM_OBS_USDHC1_CLK_ROOT 186, 2 |
#define | CCM_OBS_USDHC2_CLK_ROOT 187, 2 |
#define | CCM_OBS_ASRC_CLK_ROOT 188, 2 |
#define | CCM_OBS_MQS_CLK_ROOT 189, 2 |
#define | CCM_OBS_MIC_CLK_ROOT 190, 0 |
#define | CCM_OBS_SPDIF_CLK_ROOT 191, 2 |
#define | CCM_OBS_SAI1_CLK_ROOT 192, 2 |
#define | CCM_OBS_SAI2_CLK_ROOT 193, 2 |
#define | CCM_OBS_SAI3_CLK_ROOT 194, 2 |
#define | CCM_OBS_SAI4_CLK_ROOT 195, 0 |
#define | CCM_OBS_GC355_CLK_ROOT 196, 2 |
#define | CCM_OBS_LCDIF_CLK_ROOT 197, 2 |
#define | CCM_OBS_LCDIFV2_CLK_ROOT 198, 2 |
#define | CCM_OBS_MIPI_REF_CLK_ROOT 199, 2 |
#define | CCM_OBS_MIPI_ESC_CLK_ROOT 200, 2 |
#define | CCM_OBS_CSI2_CLK_ROOT 201, 2 |
#define | CCM_OBS_CSI2_ESC_CLK_ROOT 202, 2 |
#define | CCM_OBS_CSI2_UI_CLK_ROOT 203, 2 |
#define | CCM_OBS_CSI_CLK_ROOT 204, 2 |
#define | CCM_OBS_CCM_CKO1_CLK_ROOT 205, 0 |
#define | CCM_OBS_CCM_CKO2_CLK_ROOT 206, 2 |
#define | CCM_OBS_CM7_CORE_STCLKEN 207, 4 |
#define | CCM_OBS_CCM_FLEXRAM_CLK_ROOT 208, 4 |
#define | CCM_OBS_MIPI_DSI_TXESC 209, 2 |
#define | CCM_OBS_MIPI_DSI_RXESC 210, 2 |
#define | CCM_OBS_OSC_RC_16M 224, 0 |
#define | CCM_OBS_OSC_RC_48M 225, 0 |
#define | CCM_OBS_OSC_RC_48M_DIV2 226, 0 |
#define | CCM_OBS_OSC_RC_400M 227, 0 |
#define | CCM_OBS_OSC_24M_OUT 229, 0 |
#define | CCM_OBS_ARM_PLL_OUT 231, 2 |
#define | CCM_OBS_SYS_PLL2_OUT 233, 2 |
#define | CCM_OBS_SYS_PLL2_PFD0 234, 2 |
#define | CCM_OBS_SYS_PLL2_PFD1 235, 2 |
#define | CCM_OBS_SYS_PLL2_PFD2 236, 2 |
#define | CCM_OBS_SYS_PLL2_PFD3 237, 2 |
#define | CCM_OBS_SYS_PLL3_OUT 239, 2 |
#define | CCM_OBS_SYS_PLL3_DIV2 240, 2 |
#define | CCM_OBS_SYS_PLL3_PFD0 241, 2 |
#define | CCM_OBS_SYS_PLL3_PFD1 242, 2 |
#define | CCM_OBS_SYS_PLL3_PFD2 243, 2 |
#define | CCM_OBS_SYS_PLL3_PFD3 244, 2 |
#define | CCM_OBS_SYS_PLL1_OUT 246, 2 |
#define | CCM_OBS_SYS_PLL1_DIV2 247, 2 |
#define | CCM_OBS_SYS_PLL1_DIV5 248, 2 |
#define | CCM_OBS_PLL_AUDIO_OUT 250, 2 |
#define | CCM_OBS_PLL_VIDEO_OUT 252, 2 |
#define | CCM_OBS_DIV 3 |
#define | clock_ip_name_t clock_lpcg_t |
#define | CLOCK_GetCpuClkFreq CLOCK_GetM4Freq |
#define | CLOCK_GetCoreSysClkFreq CLOCK_GetCpuClkFreq |
#define | PLL_PFD_COUNT 4 |
enum | _clock_lpcg {
kCLOCK_M7 = 0
, kCLOCK_M4 = 1
, kCLOCK_Sim_M7 = 2
, kCLOCK_Sim_M = 3
kCLOCK_Sim_Disp = 4
, kCLOCK_Sim_Per = 5
, kCLOCK_Sim_Lpsr = 6
, kCLOCK_Anadig = 7
kCLOCK_Dcdc = 8
, kCLOCK_Src = 9
, kCLOCK_Ccm = 10
, kCLOCK_Gpc = 11
kCLOCK_Ssarc = 12
, kCLOCK_Sim_R = 13
, kCLOCK_Wdog1 = 14
, kCLOCK_Wdog2 = 15
kCLOCK_Wdog3 = 16
, kCLOCK_Wdog4 = 17
, kCLOCK_Ewm0 = 18
, kCLOCK_Sema = 19
kCLOCK_Mu_A = 20
, kCLOCK_Mu_B = 21
, kCLOCK_Edma = 22
, kCLOCK_Edma_Lpsr = 23
kCLOCK_Romcp = 24
, kCLOCK_Ocram = 25
, kCLOCK_Flexram = 26
, kCLOCK_Lmem = 27
kCLOCK_Flexspi1 = 28
, kCLOCK_Flexspi2 = 29
, kCLOCK_Rdc = 30
, kCLOCK_M7_Xrdc = 31
kCLOCK_M4_Xrdc = 32
, kCLOCK_Semc = 33
, kCLOCK_Xecc = 34
, kCLOCK_Iee = 35
kCLOCK_Key_Manager = 36
, kCLOCK_Puf = 36
, kCLOCK_Ocotp = 37
, kCLOCK_Snvs_Hp = 38
kCLOCK_Snvs = 39
, kCLOCK_Caam = 40
, kCLOCK_Jtag_Mux = 41
, kCLOCK_Cstrace = 42
kCLOCK_Xbar1 = 43
, kCLOCK_Xbar2 = 44
, kCLOCK_Xbar3 = 45
, kCLOCK_Aoi1 = 46
kCLOCK_Aoi2 = 47
, kCLOCK_Adc_Etc = 48
, kCLOCK_Iomuxc = 49
, kCLOCK_Iomuxc_Lpsr = 50
kCLOCK_Gpio = 51
, kCLOCK_Kpp = 52
, kCLOCK_Flexio1 = 53
, kCLOCK_Flexio2 = 54
kCLOCK_Lpadc1 = 55
, kCLOCK_Lpadc2 = 56
, kCLOCK_Dac = 57
, kCLOCK_Acmp1 = 58
kCLOCK_Acmp2 = 59
, kCLOCK_Acmp3 = 60
, kCLOCK_Acmp4 = 61
, kCLOCK_Pit1 = 62
kCLOCK_Pit2 = 63
, kCLOCK_Gpt1 = 64
, kCLOCK_Gpt2 = 65
, kCLOCK_Gpt3 = 66
kCLOCK_Gpt4 = 67
, kCLOCK_Gpt5 = 68
, kCLOCK_Gpt6 = 69
, kCLOCK_Qtimer1 = 70
kCLOCK_Qtimer2 = 71
, kCLOCK_Qtimer3 = 72
, kCLOCK_Qtimer4 = 73
, kCLOCK_Enc1 = 74
kCLOCK_Enc2 = 75
, kCLOCK_Enc3 = 76
, kCLOCK_Enc4 = 77
, kCLOCK_Hrtimer = 78
kCLOCK_Pwm1 = 79
, kCLOCK_Pwm2 = 80
, kCLOCK_Pwm3 = 81
, kCLOCK_Pwm4 = 82
kCLOCK_Can1 = 83
, kCLOCK_Can2 = 84
, kCLOCK_Can3 = 85
, kCLOCK_Lpuart1 = 86
kCLOCK_Lpuart2 = 87
, kCLOCK_Lpuart3 = 88
, kCLOCK_Lpuart4 = 89
, kCLOCK_Lpuart5 = 90
kCLOCK_Lpuart6 = 91
, kCLOCK_Lpuart7 = 92
, kCLOCK_Lpuart8 = 93
, kCLOCK_Lpuart9 = 94
kCLOCK_Lpuart10 = 95
, kCLOCK_Lpuart11 = 96
, kCLOCK_Lpuart12 = 97
, kCLOCK_Lpi2c1 = 98
kCLOCK_Lpi2c2 = 99
, kCLOCK_Lpi2c3 = 100
, kCLOCK_Lpi2c4 = 101
, kCLOCK_Lpi2c5 = 102
kCLOCK_Lpi2c6 = 103
, kCLOCK_Lpspi1 = 104
, kCLOCK_Lpspi2 = 105
, kCLOCK_Lpspi3 = 106
kCLOCK_Lpspi4 = 107
, kCLOCK_Lpspi5 = 108
, kCLOCK_Lpspi6 = 109
, kCLOCK_Sim1 = 110
kCLOCK_Sim2 = 111
, kCLOCK_Enet = 112
, kCLOCK_Enet_1g = 113
, kCLOCK_Usb = 115
kCLOCK_Cdog = 116
, kCLOCK_Usdhc1 = 117
, kCLOCK_Usdhc2 = 118
, kCLOCK_Asrc = 119
kCLOCK_Mqs = 120
, kCLOCK_Pdm = 121
, kCLOCK_Spdif = 122
, kCLOCK_Sai1 = 123
kCLOCK_Sai2 = 124
, kCLOCK_Sai3 = 125
, kCLOCK_Sai4 = 126
, kCLOCK_Pxp = 127
kCLOCK_Gpu2d = 128
, kCLOCK_Lcdif = 129
, kCLOCK_Lcdifv2 = 130
, kCLOCK_Mipi_Dsi = 131
kCLOCK_Mipi_Csi = 132
, kCLOCK_Csi = 133
, kCLOCK_Dcic_Mipi = 134
, kCLOCK_Dcic_Lcd = 135
kCLOCK_Video_Mux = 136
, kCLOCK_Uniq_Edt_I = 137
, kCLOCK_IpInvalid
| Clock LPCG index. More...
enum | _clock_name {
kCLOCK_CpuClk = 0x0U
, kCLOCK_AhbClk = 0x1U
, kCLOCK_SemcClk = 0x2U
, kCLOCK_IpgClk = 0x3U
kCLOCK_PerClk = 0x4U
, kCLOCK_OscClk = 0x5U
, kCLOCK_RtcClk = 0x6U
, kCLOCK_ArmPllClk = 0x7U
kCLOCK_Usb1PllClk = 0x8U
, kCLOCK_Usb1PllPfd0Clk = 0x9U
, kCLOCK_Usb1PllPfd1Clk = 0xAU
, kCLOCK_Usb1PllPfd2Clk = 0xBU
kCLOCK_Usb1PllPfd3Clk = 0xCU
, kCLOCK_Usb1SwClk = 0x17U
, kCLOCK_Usb1Sw120MClk = 0x18U
, kCLOCK_Usb1Sw60MClk = 0x19U
kCLOCK_Usb1Sw80MClk = 0x1AU
, kCLOCK_Usb2PllClk = 0xDU
, kCLOCK_SysPllClk = 0xEU
, kCLOCK_SysPllPfd0Clk = 0xFU
kCLOCK_SysPllPfd1Clk = 0x10U
, kCLOCK_SysPllPfd2Clk = 0x11U
, kCLOCK_SysPllPfd3Clk = 0x12U
, kCLOCK_EnetPll0Clk = 0x13U
kCLOCK_EnetPll1Clk = 0x14U
, kCLOCK_AudioPllClk = 0x15U
, kCLOCK_VideoPllClk = 0x16U
, kCLOCK_NoneName = CLOCK_SOURCE_NONE
kCLOCK_OscRc16M = 0
, kCLOCK_OscRc48M = 1
, kCLOCK_OscRc48MDiv2 = 2
, kCLOCK_OscRc400M = 3
kCLOCK_Osc24M = 4
, kCLOCK_Osc24MOut = 5
, kCLOCK_ArmPll = 6
, kCLOCK_ArmPllOut = 7
kCLOCK_SysPll2 = 8
, kCLOCK_SysPll2Out = 9
, kCLOCK_SysPll2Pfd0 = 10
, kCLOCK_SysPll2Pfd1 = 11
kCLOCK_SysPll2Pfd2 = 12
, kCLOCK_SysPll2Pfd3 = 13
, kCLOCK_SysPll3 = 14
, kCLOCK_SysPll3Out = 15
kCLOCK_SysPll3Div2 = 16
, kCLOCK_SysPll3Pfd0 = 17
, kCLOCK_SysPll3Pfd1 = 18
, kCLOCK_SysPll3Pfd2 = 19
kCLOCK_SysPll3Pfd3 = 20
, kCLOCK_SysPll1 = 21
, kCLOCK_SysPll1Out = 22
, kCLOCK_SysPll1Div2 = 23
kCLOCK_SysPll1Div5 = 24
, kCLOCK_AudioPll = 25
, kCLOCK_AudioPllOut = 26
, kCLOCK_VideoPll = 27
kCLOCK_VideoPllOut = 28
, kCLOCK_CpuClk
, kCLOCK_CoreSysClk
, kCLOCK_Reserved = 0xFFU
| Clock name. More...
enum | _clock_root {
kCLOCK_Usdhc1ClkRoot = 0U
, kCLOCK_Usdhc2ClkRoot
, kCLOCK_FlexspiClkRoot
, kCLOCK_CsiClkRoot
kCLOCK_LpspiClkRoot
, kCLOCK_TraceClkRoot
, kCLOCK_Sai1ClkRoot
, kCLOCK_Sai2ClkRoot
kCLOCK_Sai3ClkRoot
, kCLOCK_Lpi2cClkRoot
, kCLOCK_CanClkRoot
, kCLOCK_UartClkRoot
kCLOCK_LcdifClkRoot
, kCLOCK_SpdifClkRoot
, kCLOCK_Flexio1ClkRoot
, kCLOCK_Flexio2ClkRoot
kCLOCK_Root_M7 = 0
, kCLOCK_Root_M4 = 1
, kCLOCK_Root_Bus = 2
, kCLOCK_Root_Bus_Lpsr = 3
kCLOCK_Root_Semc = 4
, kCLOCK_Root_Cssys = 5
, kCLOCK_Root_Cstrace = 6
, kCLOCK_Root_M4_Systick = 7
kCLOCK_Root_M7_Systick = 8
, kCLOCK_Root_Adc1 = 9
, kCLOCK_Root_Adc2 = 10
, kCLOCK_Root_Acmp = 11
kCLOCK_Root_Flexio1 = 12
, kCLOCK_Root_Flexio2 = 13
, kCLOCK_Root_Gpt1 = 14
, kCLOCK_Root_Gpt2 = 15
kCLOCK_Root_Gpt3 = 16
, kCLOCK_Root_Gpt4 = 17
, kCLOCK_Root_Gpt5 = 18
, kCLOCK_Root_Gpt6 = 19
kCLOCK_Root_Flexspi1 = 20
, kCLOCK_Root_Flexspi2 = 21
, kCLOCK_Root_Can1 = 22
, kCLOCK_Root_Can2 = 23
kCLOCK_Root_Can3 = 24
, kCLOCK_Root_Lpuart1 = 25
, kCLOCK_Root_Lpuart2 = 26
, kCLOCK_Root_Lpuart3 = 27
kCLOCK_Root_Lpuart4 = 28
, kCLOCK_Root_Lpuart5 = 29
, kCLOCK_Root_Lpuart6 = 30
, kCLOCK_Root_Lpuart7 = 31
kCLOCK_Root_Lpuart8 = 32
, kCLOCK_Root_Lpuart9 = 33
, kCLOCK_Root_Lpuart10 = 34
, kCLOCK_Root_Lpuart11 = 35
kCLOCK_Root_Lpuart12 = 36
, kCLOCK_Root_Lpi2c1 = 37
, kCLOCK_Root_Lpi2c2 = 38
, kCLOCK_Root_Lpi2c3 = 39
kCLOCK_Root_Lpi2c4 = 40
, kCLOCK_Root_Lpi2c5 = 41
, kCLOCK_Root_Lpi2c6 = 42
, kCLOCK_Root_Lpspi1 = 43
kCLOCK_Root_Lpspi2 = 44
, kCLOCK_Root_Lpspi3 = 45
, kCLOCK_Root_Lpspi4 = 46
, kCLOCK_Root_Lpspi5 = 47
kCLOCK_Root_Lpspi6 = 48
, kCLOCK_Root_Emv1 = 49
, kCLOCK_Root_Emv2 = 50
, kCLOCK_Root_Enet1 = 51
kCLOCK_Root_Enet2 = 52
, kCLOCK_Root_Enet_25m = 54
, kCLOCK_Root_Enet_Timer1 = 55
, kCLOCK_Root_Enet_Timer2 = 56
kCLOCK_Root_Usdhc1 = 58
, kCLOCK_Root_Usdhc2 = 59
, kCLOCK_Root_Asrc = 60
, kCLOCK_Root_Mqs = 61
kCLOCK_Root_Mic = 62
, kCLOCK_Root_Spdif = 63
, kCLOCK_Root_Sai1 = 64
, kCLOCK_Root_Sai2 = 65
kCLOCK_Root_Sai3 = 66
, kCLOCK_Root_Sai4 = 67
, kCLOCK_Root_Gc355 = 68
, kCLOCK_Root_Lcdif = 69
kCLOCK_Root_Lcdifv2 = 70
, kCLOCK_Root_Mipi_Ref = 71
, kCLOCK_Root_Mipi_Esc = 72
, kCLOCK_Root_Csi2 = 73
kCLOCK_Root_Csi2_Esc = 74
, kCLOCK_Root_Csi2_Ui = 75
, kCLOCK_Root_Csi = 76
, kCLOCK_Root_Cko1 = 77
kCLOCK_Root_Cko2 = 78
| Root clock index. More...
enum | _clock_root_mux_source {
kCLOCK_M7_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_M7_ClockRoot_MuxOsc24MOut = 1U
, kCLOCK_M7_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_M7_ClockRoot_MuxOscRc16M = 3U
kCLOCK_M7_ClockRoot_MuxArmPllOut = 4U
, kCLOCK_M7_ClockRoot_MuxSysPll3Out = 6U
, kCLOCK_M4_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_M4_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_M4_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_M4_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_M4_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_M4_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_M4_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_M4_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_BUS_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_BUS_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_BUS_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_BUS_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_BUS_ClockRoot_MuxSysPll3Out = 4U
, kCLOCK_BUS_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_BUS_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_BUS_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_BUS_LPSR_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_BUS_LPSR_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_BUS_LPSR_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_SEMC_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_SEMC_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_SEMC_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_SEMC_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_SEMC_ClockRoot_MuxSysPll1Div5 = 4U
, kCLOCK_SEMC_ClockRoot_MuxSysPll2Out = 5U
kCLOCK_SEMC_ClockRoot_MuxSysPll2Pfd1 = 6U
, kCLOCK_SEMC_ClockRoot_MuxSysPll3Pfd0 = 7U
, kCLOCK_CSSYS_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CSSYS_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CSSYS_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CSSYS_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CSSYS_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_CSSYS_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_CSSYS_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_CSSYS_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_CSTRACE_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CSTRACE_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CSTRACE_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CSTRACE_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CSTRACE_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_CSTRACE_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_CSTRACE_ClockRoot_MuxSysPll2Pfd1 = 6U
, kCLOCK_CSTRACE_ClockRoot_MuxSysPll2Out = 7U
, kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_M4_SYSTICK_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_M4_SYSTICK_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll2Pfd0 = 6U
, kCLOCK_M4_SYSTICK_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_M7_SYSTICK_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_M7_SYSTICK_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll2Out = 4U
, kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll3Div2 = 5U
kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_M7_SYSTICK_ClockRoot_MuxSysPll2Pfd0 = 7U
, kCLOCK_ADC1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ADC1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ADC1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ADC1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ADC1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_ADC1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_ADC1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_ADC1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_ADC2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ADC2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ADC2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ADC2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ADC2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_ADC2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_ADC2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_ADC2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_ACMP_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ACMP_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ACMP_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ACMP_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ACMP_ClockRoot_MuxSysPll3Out = 4U
, kCLOCK_ACMP_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_ACMP_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_ACMP_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_FLEXIO1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_FLEXIO1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_FLEXIO1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_FLEXIO1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_FLEXIO1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_FLEXIO1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_FLEXIO1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_FLEXIO1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_FLEXIO2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_FLEXIO2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_FLEXIO2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_FLEXIO2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_FLEXIO2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_FLEXIO2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_FLEXIO2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_FLEXIO2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_GPT1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GPT1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GPT1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GPT1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GPT1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_GPT1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_GPT1_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_GPT1_ClockRoot_MuxSysPll3Pfd3 = 7U
, kCLOCK_GPT2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GPT2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GPT2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GPT2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GPT2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_GPT2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_GPT2_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_GPT2_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_GPT3_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GPT3_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GPT3_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GPT3_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GPT3_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_GPT3_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_GPT3_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_GPT3_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_GPT4_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GPT4_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GPT4_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GPT4_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GPT4_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_GPT4_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_GPT4_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_GPT4_ClockRoot_MuxSysPll3Pfd3 = 7U
, kCLOCK_GPT5_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GPT5_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GPT5_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GPT5_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GPT5_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_GPT5_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_GPT5_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_GPT5_ClockRoot_MuxSysPll3Pfd3 = 7U
, kCLOCK_GPT6_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GPT6_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GPT6_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GPT6_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GPT6_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_GPT6_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_GPT6_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_GPT6_ClockRoot_MuxSysPll3Pfd3 = 7U
, kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_FLEXSPI1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_FLEXSPI1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll3Pfd0 = 4U
, kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll2Out = 5U
kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll2Pfd2 = 6U
, kCLOCK_FLEXSPI1_ClockRoot_MuxSysPll3Out = 7U
, kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_FLEXSPI2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_FLEXSPI2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll3Pfd0 = 4U
, kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll2Out = 5U
kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll2Pfd2 = 6U
, kCLOCK_FLEXSPI2_ClockRoot_MuxSysPll3Out = 7U
, kCLOCK_CAN1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CAN1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CAN1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CAN1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CAN1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_CAN1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_CAN1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_CAN1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_CAN2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CAN2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CAN2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CAN2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CAN2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_CAN2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_CAN2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_CAN2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_CAN3_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CAN3_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CAN3_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CAN3_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CAN3_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_CAN3_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_CAN3_ClockRoot_MuxSysPll2Pfd3 = 6U
, kCLOCK_CAN3_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_LPUART1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART3_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART3_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART3_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART3_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART3_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART3_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART3_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART3_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART4_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART4_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART4_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART4_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART4_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART4_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART4_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART4_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART5_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART5_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART5_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART5_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART5_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART5_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART5_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART5_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART6_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART6_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART6_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART6_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART6_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART6_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART6_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART6_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART7_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART7_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART7_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART7_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART7_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART7_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART7_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART7_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART8_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART8_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART8_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART8_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART8_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART8_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART8_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART8_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART9_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART9_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART9_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART9_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART9_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART9_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART9_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART9_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART10_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART10_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART10_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART10_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART10_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPUART10_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPUART10_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPUART10_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPUART11_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART11_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART11_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART11_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART11_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_LPUART11_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_LPUART11_ClockRoot_MuxSysPll2Pfd3 = 6U
, kCLOCK_LPUART11_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_LPUART12_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPUART12_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPUART12_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPUART12_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPUART12_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_LPUART12_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_LPUART12_ClockRoot_MuxSysPll2Pfd3 = 6U
, kCLOCK_LPUART12_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_LPI2C1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPI2C1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPI2C1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPI2C1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPI2C1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPI2C1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPI2C1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPI2C1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPI2C2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPI2C2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPI2C2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPI2C2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPI2C2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPI2C2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPI2C2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPI2C2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPI2C3_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPI2C3_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPI2C3_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPI2C3_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPI2C3_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPI2C3_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPI2C3_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPI2C3_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPI2C4_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPI2C4_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPI2C4_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPI2C4_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPI2C4_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_LPI2C4_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPI2C4_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPI2C4_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPI2C5_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPI2C5_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPI2C5_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPI2C5_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPI2C5_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_LPI2C5_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_LPI2C5_ClockRoot_MuxSysPll2Pfd3 = 6U
, kCLOCK_LPI2C5_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_LPI2C6_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPI2C6_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPI2C6_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPI2C6_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPI2C6_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_LPI2C6_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_LPI2C6_ClockRoot_MuxSysPll2Pfd3 = 6U
, kCLOCK_LPI2C6_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_LPSPI1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPSPI1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPSPI1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPSPI1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPSPI1_ClockRoot_MuxSysPll3Pfd2 = 4U
, kCLOCK_LPSPI1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPSPI1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPSPI1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPSPI2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPSPI2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPSPI2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPSPI2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPSPI2_ClockRoot_MuxSysPll3Pfd2 = 4U
, kCLOCK_LPSPI2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPSPI2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPSPI2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPSPI3_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPSPI3_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPSPI3_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPSPI3_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPSPI3_ClockRoot_MuxSysPll3Pfd2 = 4U
, kCLOCK_LPSPI3_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPSPI3_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPSPI3_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPSPI4_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPSPI4_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPSPI4_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPSPI4_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPSPI4_ClockRoot_MuxSysPll3Pfd2 = 4U
, kCLOCK_LPSPI4_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_LPSPI4_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_LPSPI4_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_LPSPI5_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPSPI5_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPSPI5_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPSPI5_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_LPSPI5_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_LPSPI5_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_LPSPI6_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LPSPI6_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LPSPI6_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LPSPI6_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_LPSPI6_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_LPSPI6_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_EMV1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_EMV1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_EMV1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_EMV1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_EMV1_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_EMV1_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_EMV1_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_EMV1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_EMV2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_EMV2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_EMV2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_EMV2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_EMV2_ClockRoot_MuxSysPll3Div2 = 4U
, kCLOCK_EMV2_ClockRoot_MuxSysPll1Div5 = 5U
kCLOCK_EMV2_ClockRoot_MuxSysPll2Out = 6U
, kCLOCK_EMV2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_ENET1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ENET1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ENET1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ENET1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ENET1_ClockRoot_MuxSysPll1Div2 = 4U
, kCLOCK_ENET1_ClockRoot_MuxAudioPllOut = 5U
kCLOCK_ENET1_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_ENET1_ClockRoot_MuxSysPll2Pfd1 = 7U
, kCLOCK_ENET2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ENET2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ENET2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ENET2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ENET2_ClockRoot_MuxSysPll1Div2 = 4U
, kCLOCK_ENET2_ClockRoot_MuxAudioPllOut = 5U
kCLOCK_ENET2_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_ENET2_ClockRoot_MuxSysPll2Pfd1 = 7U
, kCLOCK_ENET_25M_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ENET_25M_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ENET_25M_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ENET_25M_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ENET_25M_ClockRoot_MuxSysPll1Div2 = 4U
, kCLOCK_ENET_25M_ClockRoot_MuxAudioPllOut = 5U
kCLOCK_ENET_25M_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_ENET_25M_ClockRoot_MuxSysPll2Pfd1 = 7U
, kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ENET_TIMER1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ENET_TIMER1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll1Div2 = 4U
, kCLOCK_ENET_TIMER1_ClockRoot_MuxAudioPllOut = 5U
kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_ENET_TIMER1_ClockRoot_MuxSysPll2Pfd1 = 7U
, kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ENET_TIMER2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ENET_TIMER2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll1Div2 = 4U
, kCLOCK_ENET_TIMER2_ClockRoot_MuxAudioPllOut = 5U
kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_ENET_TIMER2_ClockRoot_MuxSysPll2Pfd1 = 7U
, kCLOCK_USDHC1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_USDHC1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_USDHC1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_USDHC1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_USDHC1_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_USDHC1_ClockRoot_MuxSysPll2Pfd0 = 5U
kCLOCK_USDHC1_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_USDHC1_ClockRoot_MuxArmPllOut = 7U
, kCLOCK_USDHC2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_USDHC2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_USDHC2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_USDHC2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_USDHC2_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_USDHC2_ClockRoot_MuxSysPll2Pfd0 = 5U
kCLOCK_USDHC2_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_USDHC2_ClockRoot_MuxArmPllOut = 7U
, kCLOCK_ASRC_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_ASRC_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_ASRC_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_ASRC_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_ASRC_ClockRoot_MuxSysPll1Div5 = 4U
, kCLOCK_ASRC_ClockRoot_MuxSysPll3Div2 = 5U
kCLOCK_ASRC_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_ASRC_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_MQS_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_MQS_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_MQS_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_MQS_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_MQS_ClockRoot_MuxSysPll1Div5 = 4U
, kCLOCK_MQS_ClockRoot_MuxSysPll3Div2 = 5U
kCLOCK_MQS_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_MQS_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_MIC_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_MIC_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_MIC_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_MIC_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_MIC_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_MIC_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_MIC_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_MIC_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_SPDIF_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_SPDIF_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_SPDIF_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_SPDIF_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_SPDIF_ClockRoot_MuxAudioPllOut = 4U
, kCLOCK_SPDIF_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_SPDIF_ClockRoot_MuxSysPll3Pfd2 = 6U
, kCLOCK_SPDIF_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_SAI1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_SAI1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_SAI1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_SAI1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_SAI1_ClockRoot_MuxAudioPllOut = 4U
, kCLOCK_SAI1_ClockRoot_MuxSysPll3Pfd2 = 5U
kCLOCK_SAI1_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_SAI1_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_SAI2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_SAI2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_SAI2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_SAI2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_SAI2_ClockRoot_MuxAudioPllOut = 4U
, kCLOCK_SAI2_ClockRoot_MuxSysPll3Pfd2 = 5U
kCLOCK_SAI2_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_SAI2_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_SAI3_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_SAI3_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_SAI3_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_SAI3_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_SAI3_ClockRoot_MuxAudioPllOut = 4U
, kCLOCK_SAI3_ClockRoot_MuxSysPll3Pfd2 = 5U
kCLOCK_SAI3_ClockRoot_MuxSysPll1Div5 = 6U
, kCLOCK_SAI3_ClockRoot_MuxSysPll2Pfd3 = 7U
, kCLOCK_SAI4_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_SAI4_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_SAI4_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_SAI4_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_SAI4_ClockRoot_MuxSysPll3Pfd3 = 4U
, kCLOCK_SAI4_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_SAI4_ClockRoot_MuxAudioPllOut = 6U
, kCLOCK_SAI4_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_GC355_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_GC355_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_GC355_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_GC355_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_GC355_ClockRoot_MuxSysPll2Out = 4U
, kCLOCK_GC355_ClockRoot_MuxSysPll2Pfd1 = 5U
kCLOCK_GC355_ClockRoot_MuxSysPll3Out = 6U
, kCLOCK_GC355_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_LCDIF_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LCDIF_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LCDIF_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LCDIF_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LCDIF_ClockRoot_MuxSysPll2Out = 4U
, kCLOCK_LCDIF_ClockRoot_MuxSysPll2Pfd2 = 5U
kCLOCK_LCDIF_ClockRoot_MuxSysPll3Pfd0 = 6U
, kCLOCK_LCDIF_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_LCDIFV2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_LCDIFV2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_LCDIFV2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_LCDIFV2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_LCDIFV2_ClockRoot_MuxSysPll2Out = 4U
, kCLOCK_LCDIFV2_ClockRoot_MuxSysPll2Pfd2 = 5U
kCLOCK_LCDIFV2_ClockRoot_MuxSysPll3Pfd0 = 6U
, kCLOCK_LCDIFV2_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_MIPI_REF_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_MIPI_REF_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_MIPI_REF_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_MIPI_REF_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_MIPI_REF_ClockRoot_MuxSysPll2Out = 4U
, kCLOCK_MIPI_REF_ClockRoot_MuxSysPll2Pfd0 = 5U
kCLOCK_MIPI_REF_ClockRoot_MuxSysPll3Pfd0 = 6U
, kCLOCK_MIPI_REF_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_MIPI_ESC_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_MIPI_ESC_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll2Out = 4U
, kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll2Pfd0 = 5U
kCLOCK_MIPI_ESC_ClockRoot_MuxSysPll3Pfd0 = 6U
, kCLOCK_MIPI_ESC_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_CSI2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CSI2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CSI2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CSI2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CSI2_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_CSI2_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_CSI2_ClockRoot_MuxSysPll2Pfd0 = 6U
, kCLOCK_CSI2_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CSI2_ESC_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CSI2_ESC_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_CSI2_ESC_ClockRoot_MuxSysPll2Pfd0 = 6U
, kCLOCK_CSI2_ESC_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_CSI2_UI_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CSI2_UI_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CSI2_UI_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CSI2_UI_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CSI2_UI_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_CSI2_UI_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_CSI2_UI_ClockRoot_MuxSysPll2Pfd0 = 6U
, kCLOCK_CSI2_UI_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_CSI_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CSI_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CSI_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CSI_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CSI_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_CSI_ClockRoot_MuxSysPll3Out = 5U
kCLOCK_CSI_ClockRoot_MuxSysPll3Pfd1 = 6U
, kCLOCK_CSI_ClockRoot_MuxVideoPllOut = 7U
, kCLOCK_CKO1_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CKO1_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CKO1_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CKO1_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CKO1_ClockRoot_MuxSysPll2Pfd2 = 4U
, kCLOCK_CKO1_ClockRoot_MuxSysPll2Out = 5U
kCLOCK_CKO1_ClockRoot_MuxSysPll3Pfd1 = 6U
, kCLOCK_CKO1_ClockRoot_MuxSysPll1Div5 = 7U
, kCLOCK_CKO2_ClockRoot_MuxOscRc48MDiv2 = 0U
, kCLOCK_CKO2_ClockRoot_MuxOsc24MOut = 1U
kCLOCK_CKO2_ClockRoot_MuxOscRc400M = 2U
, kCLOCK_CKO2_ClockRoot_MuxOscRc16M = 3U
, kCLOCK_CKO2_ClockRoot_MuxSysPll2Pfd3 = 4U
, kCLOCK_CKO2_ClockRoot_MuxOscRc48M = 5U
kCLOCK_CKO2_ClockRoot_MuxSysPll3Pfd1 = 6U
, kCLOCK_CKO2_ClockRoot_MuxAudioPllOut = 7U
| The enumerator of clock roots' clock source mux value. More...
enum | _clock_group { kCLOCK_Group_FlexRAM = 0
, kCLOCK_Group_MipiDsi = 1
, kCLOCK_Group_Last
| Clock group enumeration. More...
enum | _clock_osc { kCLOCK_RcOsc = 0U
, kCLOCK_XtalOsc = 1U
, kCLOCK_RcOsc = 0U
| OSC 24M sorce select. More...
enum | _clock_gate_value {
kCLOCK_ClockNotNeeded = 0U
, kCLOCK_ClockNeededRun = 1U
, kCLOCK_ClockNeededRunWait = 3U
, kCLOCK_Off = (int)~CCM_LPCG_DIRECT_ON_MASK
kCLOCK_On = CCM_LPCG_DIRECT_ON_MASK
| Clock gate value. More...
enum | _clock_mode_t {
kCLOCK_ModeRun = 0U
, kCLOCK_ModeWait = 1U
, kCLOCK_ModeStop = 2U
, kCLOCK_ModeRun = 0U
| System clock mode. More...
enum | _clock_usb_src { kCLOCK_Usb480M = 0
, kCLOCK_UsbSrcUnused = (int)0xFFFFFFFFU
, kCLOCK_Usb480M = 0
| USB clock source definition. More...
enum | _clock_usb_phy_src { kCLOCK_Usbphy480M = 0
, kCLOCK_Usbphy480M = 0
| Source of the USB HS PHY. More...
enum | _clock_pll_clk_src { kCLOCK_PllClkSrc24M = 0U
, kCLOCK_PllSrcClkPN = 1U
, kCLOCK_PllClkSrc24M = 0U
| PLL clock source, bypass cloco source also. More...
enum | _clock_pll_post_div { kCLOCK_PllPostDiv8 = 0U
, kCLOCK_PllPostDiv4 = 1U
| PLL post divider enumeration. More...
enum | _clock_pll {
kCLOCK_PllArm = CCM_ANALOG_TUPLE(PLL_ARM_OFFSET, CCM_ANALOG_PLL_ARM_ENABLE_SHIFT)
, kCLOCK_PllSys = CCM_ANALOG_TUPLE(PLL_SYS_OFFSET, CCM_ANALOG_PLL_SYS_ENABLE_SHIFT)
, kCLOCK_PllUsb1 = CCM_ANALOG_TUPLE(PLL_USB1_OFFSET, CCM_ANALOG_PLL_USB1_ENABLE_SHIFT)
, kCLOCK_PllAudio = CCM_ANALOG_TUPLE(PLL_AUDIO_OFFSET, CCM_ANALOG_PLL_AUDIO_ENABLE_SHIFT)
kCLOCK_PllVideo = CCM_ANALOG_TUPLE(PLL_VIDEO_OFFSET, CCM_ANALOG_PLL_VIDEO_ENABLE_SHIFT)
, kCLOCK_PllEnet = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENABLE_SHIFT)
, kCLOCK_PllEnet25M = CCM_ANALOG_TUPLE(PLL_ENET_OFFSET, CCM_ANALOG_PLL_ENET_ENET_25M_REF_EN_SHIFT)
, kCLOCK_PllUsb2 = CCM_ANALOG_TUPLE(PLL_USB2_OFFSET, CCM_ANALOG_PLL_USB2_ENABLE_SHIFT)
kCLOCK_PllArm
, kCLOCK_PllSys1
, kCLOCK_PllSys2
, kCLOCK_PllSys3
kCLOCK_PllAudio
, kCLOCK_PllVideo
, kCLOCK_PllInvalid = -1
| PLL name. More...
enum | _clock_pfd {
kCLOCK_Pfd0 = 0U
, kCLOCK_Pfd1 = 1U
, kCLOCK_Pfd2 = 2U
, kCLOCK_Pfd3 = 3U
kCLOCK_Pfd0 = 0U
, kCLOCK_Pfd1 = 1U
, kCLOCK_Pfd2 = 2U
, kCLOCK_Pfd3 = 3U
| PLL PFD name. More...
enum | _clock_control_mode { kCLOCK_SoftwareMode = 0U
, kCLOCK_GpcMode
| The enumeration of control mode. More...
enum | _clock_24MOsc_mode { kCLOCK_24MOscHighGainMode = 0U
, kCLOCK_24MOscBypassMode = 1U
, kCLOCK_24MOscLowPowerMode = 2U
| The enumeration of 24MHz crystal oscillator mode. More...
enum | _clock_16MOsc_source { kCLOCK_16MOscSourceFrom16MOsc = 0U
, kCLOCK_16MOscSourceFrom24MOsc = 1U
| The enumeration of 16MHz RC oscillator clock source. More...
enum | _clock_1MHzOut_behavior { kCLOCK_1MHzOutDisable = 0U
, kCLOCK_1MHzOutEnableLocked1Mhz = 1U
, kCLOCK_1MHzOutEnableFreeRunning1Mhz = 2U
| The enumeration of 1MHz output clock behavior, including disabling 1MHz output, enabling locked 1MHz clock output, and enabling free-running 1MHz clock output. More...
enum | _clock_level {
kCLOCK_Level0 = 0x0UL
, kCLOCK_Level1 = 0x1UL
, kCLOCK_Level2 = 0x2UL
, kCLOCK_Level3 = 0x3UL
kCLOCK_Level4 = 0x4UL
| The clock dependence level. More...
typedef enum _clock_lpcg | clock_lpcg_t |
| Clock LPCG index.
typedef enum _clock_name | clock_name_t |
| Clock name.
typedef enum _clock_root | clock_root_t |
| Root clock index.
typedef enum _clock_root_mux_source | clock_root_mux_source_t |
typedef enum _clock_group | clock_group_t |
typedef struct _clock_group_config | clock_group_config_t |
| The structure used to configure clock group.
typedef enum _clock_osc | clock_osc_t |
typedef enum _clock_gate_value | clock_gate_value_t |
| Clock gate value.
typedef enum _clock_mode_t | clock_mode_t |
| System clock mode.
typedef enum _clock_usb_src | clock_usb_src_t |
typedef enum _clock_usb_phy_src | clock_usb_phy_src_t |
typedef enum _clock_pll_post_div | clock_pll_post_div_t |
typedef struct _clock_arm_pll_config | clock_arm_pll_config_t |
| PLL configuration for ARM. More...
typedef struct _clock_usb_pll_config | clock_usb_pll_config_t |
| PLL configuration for USB.
typedef struct _clock_pll_ss_config | clock_pll_ss_config_t |
| Spread specturm configure Pll.
typedef struct _clock_sys_pll2_config | clock_sys_pll2_config_t |
| PLL configure for Sys Pll2.
typedef struct _clock_sys_pll1_config | clock_sys_pll1_config_t |
| PLL configure for Sys Pll1.
typedef struct _clock_audio_pll_config | clock_av_pll_config_t |
| PLL configuration for AUDIO and VIDEO.
typedef struct _clock_audio_pll_config | clock_audio_pll_config_t |
typedef struct _clock_audio_pll_config | clock_video_pll_config_t |
typedef struct _clock_audio_pll_gpc_config | clock_audio_pll_gpc_config_t |
| PLL configuration fro AUDIO PLL, SYSTEM PLL1 and VIDEO PLL.
typedef struct _clock_audio_pll_gpc_config | clock_video_pll_gpc_config_t |
typedef struct _clock_audio_pll_gpc_config | clock_sys_pll1_gpc_config_t |
typedef struct _clock_enet_pll_config | clock_enet_pll_config_t |
| PLL configuration for ENET.
typedef struct _clock_root_config_t | clock_root_config_t |
| Clock root configuration.
typedef struct _clock_root_setpoint_config_t | clock_root_setpoint_config_t |
| Clock root configuration in SetPoint Mode.
typedef enum _clock_pll | clock_pll_t |
| PLL name.
typedef enum _clock_pfd | clock_pfd_t |
| PLL PFD name.
typedef enum _clock_control_mode | clock_control_mode_t |
typedef enum _clock_24MOsc_mode | clock_24MOsc_mode_t |
typedef enum _clock_16MOsc_source | clock_16MOsc_source_t |
typedef enum _clock_1MHzOut_behavior | clock_1MHzOut_behavior_t |
typedef enum _clock_level | clock_level_t |
void | CLOCK_SetGroupConfig (clock_group_t group, const clock_group_config_t *config) |
| Set the clock group configuration. More...
