RTEMS 6.1-rc1
94#define CONFIGURE_APPLICATION_NEEDS_LIBBLOCK
120#define CONFIGURE_BDBUF_BUFFER_MAX_SIZE
146#define CONFIGURE_BDBUF_BUFFER_MIN_SIZE
172#define CONFIGURE_BDBUF_CACHE_MEMORY_SIZE
203#define CONFIGURE_BDBUF_MAX_READ_AHEAD_BLOCKS
229#define CONFIGURE_BDBUF_MAX_WRITE_BLOCKS
248#define CONFIGURE_BDBUF_READ_AHEAD_TASK_PRIORITY
280#define CONFIGURE_BDBUF_TASK_STACK_SIZE
306#define CONFIGURE_SWAPOUT_BLOCK_HOLD
332#define CONFIGURE_SWAPOUT_SWAP_PERIOD
351#define CONFIGURE_SWAPOUT_TASK_PRIORITY
377#define CONFIGURE_SWAPOUT_WORKER_TASKS
397#define CONFIGURE_SWAPOUT_WORKER_TASK_PRIORITY
451#define CONFIGURE_MAXIMUM_BARRIERS
492#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
532#define CONFIGURE_MAXIMUM_PARTITIONS
572#define CONFIGURE_MAXIMUM_PERIODS
612#define CONFIGURE_MAXIMUM_PORTS
652#define CONFIGURE_MAXIMUM_REGIONS
701#define CONFIGURE_MAXIMUM_SEMAPHORES
762#define CONFIGURE_MAXIMUM_TASKS
802#define CONFIGURE_MAXIMUM_TIMERS
835#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
868#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
903#define CONFIGURE_INIT_TASK_ARGUMENTS
921#define CONFIGURE_INIT_TASK_ATTRIBUTES
978#define CONFIGURE_INIT_TASK_CONSTRUCT_STORAGE_SIZE
1001#define CONFIGURE_INIT_TASK_ENTRY_POINT
1020#define CONFIGURE_INIT_TASK_INITIAL_MODES
1042#define CONFIGURE_INIT_TASK_NAME
1062#define CONFIGURE_INIT_TASK_PRIORITY
1101#define CONFIGURE_INIT_TASK_STACK_SIZE
1135#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
1185#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
1213#define CONFIGURE_APPLICATION_EXTRA_DRIVERS
1237#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER
1270#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
1306#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
1331#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER
1355#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER
1374#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER
1399#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER
1439#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
1488#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER
1508#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER
1541#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
1566#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER
1585#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER
1614#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS
1637#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY
1662#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
1736#define CONFIGURE_MAXIMUM_DRIVERS
1776#define CONFIGURE_RECORD_EXTENSIONS_ENABLED
1805#define CONFIGURE_RECORD_FATAL_DUMP_BASE64
1833#define CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB
1858#define CONFIGURE_RECORD_INTERRUPTS_ENABLED
1895#define CONFIGURE_RECORD_PER_PROCESSOR_ITEMS
1946#define CONFIGURE_POSIX_TIMERS_FACE_BEHAVIOR
2022#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
2052#define CONFIGURE_FILESYSTEM_ALL
2073#define CONFIGURE_FILESYSTEM_DOSFS
2090#define CONFIGURE_FILESYSTEM_FTPFS
2113#define CONFIGURE_FILESYSTEM_IMFS
2130#define CONFIGURE_FILESYSTEM_JFFS2
2147#define CONFIGURE_FILESYSTEM_NFS
2168#define CONFIGURE_FILESYSTEM_RFS
2185#define CONFIGURE_FILESYSTEM_TFTPFS
2201#define CONFIGURE_IMFS_DISABLE_CHMOD
2217#define CONFIGURE_IMFS_DISABLE_CHOWN
2233#define CONFIGURE_IMFS_DISABLE_LINK
2249#define CONFIGURE_IMFS_DISABLE_MKNOD
2265#define CONFIGURE_IMFS_DISABLE_MKNOD_DEVICE
2281#define CONFIGURE_IMFS_DISABLE_MKNOD_FILE
2297#define CONFIGURE_IMFS_DISABLE_MOUNT
2314#define CONFIGURE_IMFS_DISABLE_READDIR
2330#define CONFIGURE_IMFS_DISABLE_READLINK
2346#define CONFIGURE_IMFS_DISABLE_RENAME
2362#define CONFIGURE_IMFS_DISABLE_RMNOD
2378#define CONFIGURE_IMFS_DISABLE_SYMLINK
2394#define CONFIGURE_IMFS_DISABLE_UNMOUNT
2410#define CONFIGURE_IMFS_DISABLE_UTIME
2426#define CONFIGURE_IMFS_ENABLE_MKFIFO
2476#define CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK
2529#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
2567#define CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM
2610#define CONFIGURE_DIRTY_MEMORY
2643#define CONFIGURE_DISABLE_BSP_SETTINGS
2665#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
2701#define CONFIGURE_EXECUTIVE_RAM_SIZE
2735#define CONFIGURE_EXTRA_TASK_STACKS
2756#define CONFIGURE_INIT
2780#define CONFIGURE_INITIAL_EXTENSIONS
2833#define CONFIGURE_INTERRUPT_STACK_SIZE
2856#define CONFIGURE_MALLOC_DIRTY
2890#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS
2929#define CONFIGURE_MAXIMUM_PROCESSORS
2979#define CONFIGURE_MAXIMUM_THREAD_LOCAL_STORAGE_SIZE
3020#define CONFIGURE_MAXIMUM_THREAD_NAME_SIZE
3060#define CONFIGURE_MEMORY_OVERHEAD
3140#define CONFIGURE_MESSAGE_BUFFER_MEMORY
3192#define CONFIGURE_MICROSECONDS_PER_TICK
3243#define CONFIGURE_MINIMUM_TASK_STACK_SIZE
3268#define CONFIGURE_STACK_CHECKER_ENABLED
3298#define CONFIGURE_TICKS_PER_TIMESLICE
3327#define CONFIGURE_UNIFIED_WORK_AREAS
3359#define CONFIGURE_UNLIMITED_ALLOCATION_SIZE
3387#define CONFIGURE_UNLIMITED_OBJECTS
3407#define CONFIGURE_VERBOSE_SYSTEM_INITIALIZATION
3430#define CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY
3480#define CONFIGURE_IDLE_TASK_BODY
3528#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
3564#define CONFIGURE_IDLE_TASK_STACK_SIZE
3619#define CONFIGURE_IDLE_TASK_STORAGE_SIZE
3676#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK
3699#define CONFIGURE_MP_APPLICATION
3734#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS
3764#define CONFIGURE_MP_MAXIMUM_NODES
3802#define CONFIGURE_MP_MAXIMUM_PROXIES
3831#define CONFIGURE_MP_MPCI_TABLE_POINTER
3868#define CONFIGURE_MP_NODE_NUMBER
3925#define CONFIGURE_MAXIMUM_POSIX_KEYS
3972#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS
4018#define CONFIGURE_MAXIMUM_POSIX_MESSAGE_QUEUES
4063#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS
4114#define CONFIGURE_MAXIMUM_POSIX_SEMAPHORES
4159#define CONFIGURE_MAXIMUM_POSIX_SHMS
4212#define CONFIGURE_MAXIMUM_POSIX_THREADS
4262#define CONFIGURE_MAXIMUM_POSIX_TIMERS
4291#define CONFIGURE_MINIMUM_POSIX_THREAD_STACK_SIZE
4330#define CONFIGURE_POSIX_INIT_THREAD_ENTRY_POINT
4358#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE
4393#define CONFIGURE_POSIX_INIT_THREAD_TABLE
4465#define CONFIGURE_CBS_MAXIMUM_SERVERS
4525#define CONFIGURE_MAXIMUM_PRIORITY
4577#define CONFIGURE_SCHEDULER_ASSIGNMENTS
4606#define CONFIGURE_SCHEDULER_CBS
4634#define CONFIGURE_SCHEDULER_EDF
4669#define CONFIGURE_SCHEDULER_EDF_SMP
4732#define CONFIGURE_SCHEDULER_NAME
4766#define CONFIGURE_SCHEDULER_PRIORITY
4801#define CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP
4835#define CONFIGURE_SCHEDULER_PRIORITY_SMP
4863#define CONFIGURE_SCHEDULER_SIMPLE
4894#define CONFIGURE_SCHEDULER_SIMPLE_SMP
4921#define CONFIGURE_SCHEDULER_STRONG_APA
4986#define CONFIGURE_SCHEDULER_TABLE_ENTRIES
5031#define CONFIGURE_SCHEDULER_USER
5082#define CONFIGURE_TASK_STACK_ALLOCATOR
5102#define CONFIGURE_TASK_STACK_ALLOCATOR_AVOIDS_WORK_SPACE
5152#define CONFIGURE_TASK_STACK_ALLOCATOR_FOR_IDLE
5185#define CONFIGURE_TASK_STACK_ALLOCATOR_INIT
5217#define CONFIGURE_TASK_STACK_DEALLOCATOR
5243#define CONFIGURE_TASK_STACK_FROM_ALLOCATOR
