RTEMS 6.1-rc1
#define | CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK |
This configuration option is an integer define. More... | |
#define | CONFIGURE_MP_APPLICATION |
This configuration option is a boolean feature define. More... | |
#define | CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS |
#define | CONFIGURE_MP_MAXIMUM_NODES |
#define | CONFIGURE_MP_MAXIMUM_PROXIES |
#define | CONFIGURE_MP_MPCI_TABLE_POINTER |
This configuration option is an initializer define. More... | |
#define | CONFIGURE_MP_NODE_NUMBER |
This section describes multiprocessing related configuration options. The options are only used if RTEMS was built when the multiprocessing build configuration option is enabled. The multiprocessing configuration is distinct from the SMP configuration. Additionally, this class of configuration options are only applicable if the configuration option CONFIGURE_MP_APPLICATION is defined. The multiprocessing (MPCI) support must not be confused with the SMP support.
#define CONFIGURE_EXTRA_MPCI_RECEIVE_SERVER_STACK |
The value of this configuration option defines the number of bytes the applications wishes to add to the MPCI task stack on top of CONFIGURE_MINIMUM_TASK_STACK_SIZE.
The following constraints apply to this configuration option:
<rtems/confdefs.h>
does not overflow an integer of type size_t. #define CONFIGURE_MP_APPLICATION |
This configuration option is defined to indicate that the application intends to be part of a multiprocessing configuration. Additional configuration options are assumed to be provided.
#define CONFIGURE_MP_MAXIMUM_GLOBAL_OBJECTS |
The value of this configuration option defines the maximum number of concurrently active global objects in a multiprocessor system.
This value corresponds to the total number of objects which can be created with the RTEMS_GLOBAL attribute.
This configuration option is only evaluated if CONFIGURE_MP_APPLICATION is defined.
#define CONFIGURE_MP_MAXIMUM_NODES |
The value of this configuration option defines the maximum number of nodes in a multiprocessor system.
#define CONFIGURE_MP_MAXIMUM_PROXIES |
The value of this configuration option defines the maximum number of concurrently active thread/task proxies on this node in a multiprocessor system.
Since a proxy is used to represent a remote task/thread which is blocking on this node. This configuration parameter reflects the maximum number of remote tasks/threads which can be blocked on objects on this node, see Proxies.
#define CONFIGURE_MP_MPCI_TABLE_POINTER |
The value of this configuration option initializes the MPCI Configuration Table.
&MPCI_table
.RTEMS provides a Shared Memory MPCI Device Driver which can be used on any Multiprocessor System assuming the BSP provides the proper set of supporting methods.
#define CONFIGURE_MP_NODE_NUMBER |
The value of this configuration option defines the node number of this node in a multiprocessor system.
NODE_NUMBER
.The following constraints apply to this configuration option:
In the RTEMS Multiprocessing Test Suite, the node number is derived from the Makefile variable NODE_NUMBER
. The same code is compiled with the NODE_NUMBER
set to different values. The test programs behave differently based upon their node number.
