RTEMS 6.1-rc1
Classic API Configuration
#define CONFIGURE_MAXIMUM_BARRIERS
 This configuration option is an integer define. More...
#define CONFIGURE_MAXIMUM_MESSAGE_QUEUES
#define CONFIGURE_MAXIMUM_PARTITIONS
#define CONFIGURE_MAXIMUM_PERIODS
#define CONFIGURE_MAXIMUM_PORTS
#define CONFIGURE_MAXIMUM_REGIONS
#define CONFIGURE_MAXIMUM_SEMAPHORES
#define CONFIGURE_MAXIMUM_TASKS
#define CONFIGURE_MAXIMUM_TIMERS
#define CONFIGURE_MAXIMUM_USER_EXTENSIONS
#define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
This section describes configuration options related to the Classic API.
◆ CONFIGURE_MAXIMUM_BARRIERS
The value of this configuration option defines the maximum number of Classic API Barriers that can be concurrently active.
Default Value
The default value is 0.
Constraints
The following constraints apply to this configuration option:
  • The value of the configuration option shall be greater than or equal to zero.
  • The value of the configuration option shall be less than or equal to 65535.
  • The value of the configuration option shall be less than or equal to a BSP-specific and application-specific value which depends on the size of the memory available to the application.
  • The value of the configuration option may be defined through rtems_resource_unlimited() the enable unlimited objects for the object class, if the value passed to rtems_resource_unlimited() satisfies all other constraints of the configuration option.
Notes
This object class can be configured in unlimited allocation mode, see Unlimited Objects.
◆ CONFIGURE_MAXIMUM_MESSAGE_QUEUES
The value of this configuration option defines the maximum number of Classic API Message Queues that can be concurrently active.
Default Value
Constraints
Notes
This object class can be configured in unlimited allocation mode, see Unlimited Objects. You have to account for the memory used to store the messages of each message queue, see CONFIGURE_MESSAGE_BUFFER_MEMORY.
◆ CONFIGURE_MAXIMUM_PARTITIONS
The value of this configuration option defines the maximum number of Classic API Partitions that can be concurrently active.
Default Value
Constraints
Notes
◆ CONFIGURE_MAXIMUM_PERIODS
The value of this configuration option defines the maximum number of Classic API Periods that can be concurrently active.
Default Value
Constraints
Notes
◆ CONFIGURE_MAXIMUM_PORTS
The value of this configuration option defines the maximum number of Classic API Ports that can be concurrently active.
Default Value
Constraints
Notes
◆ CONFIGURE_MAXIMUM_REGIONS
The value of this configuration option defines the maximum number of Classic API Regions that can be concurrently active.
Default Value
Constraints
Notes
◆ CONFIGURE_MAXIMUM_SEMAPHORES
The value of this configuration option defines the maximum number of Classic API Semaphore that can be concurrently active.
Default Value
Constraints
Notes
In SMP configurations, the size of a Semaphore Control Block depends on the scheduler count (see Configuration Step 3 - Scheduler Table). The semaphores using the Multiprocessor Resource Sharing Protocol (MrsP) need a ceiling priority per scheduler.
◆ CONFIGURE_MAXIMUM_TASKS
The value of this configuration option defines the maximum number of Classic API Tasks that can be concurrently active.
Default Value
Constraints
  • The value of the configuration option shall be small enough so that the task stack space calculation carried out by <rtems/confdefs.h> does not overflow an integer of type uintptr_t.
Notes
The calculations for the required memory in the RTEMS Workspace for tasks assume that each task has a minimum stack size and has floating point support enabled. The configuration option CONFIGURE_EXTRA_TASK_STACKS is used to specify task stack requirements above the minimum size required.
The maximum number of POSIX threads is specified by CONFIGURE_MAXIMUM_POSIX_THREADS.
A future enhancement to <rtems/confdefs.h> could be to eliminate the assumption that all tasks have floating point enabled. This would require the addition of a new configuration parameter to specify the number of tasks which enable floating point support.
◆ CONFIGURE_MAXIMUM_TIMERS
The value of this configuration option defines the maximum number of Classic API Timers that can be concurrently active.
Default Value
Constraints
Notes
◆ CONFIGURE_MAXIMUM_USER_EXTENSIONS
The value of this configuration option defines the maximum number of Classic API User Extensions that can be concurrently active.
Default Value
Constraints
Notes
This object class cannot be configured in unlimited allocation mode.
◆ CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE
The value of this configuration option defines the minimum count of Classic API Tasks which are constructed by rtems_task_construct().
Default Value
Constraints
  • The value of the configuration option shall be less than or equal to CONFIGURE_MAXIMUM_TASKS.
Notes
By default, the calculation for the required memory in the RTEMS Workspace for tasks assumes that all Classic API Tasks are created by rtems_task_create(). This configuration option can be used to reduce the required memory for the system-provided task storage areas since tasks constructed by rtems_task_construct() use a user-provided task storage area.
