RTEMS 6.1-rc1
#define | CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
This configuration option is a boolean feature define. More... | |
#define | CONFIGURE_APPLICATION_EXTRA_DRIVERS |
This configuration option is an initializer define. More... | |
#define | CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER |
#define | CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER |
#define | CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS |
#define | CONFIGURE_ATA_DRIVER_TASK_PRIORITY |
This configuration option is an integer define. More... | |
#define | CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING |
#define | CONFIGURE_MAXIMUM_DRIVERS |
This section describes configuration options related to the device drivers. Note that network device drivers are not covered by the following options.
#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER |
In case this configuration option is defined, then no Clock Driver is initialized during system initialization.
This configuration parameter is intended to prevent the common user error of using the Hello World example as the baseline for an application and leaving out a clock tick source.
The application shall define exactly one of the following configuration options
, orotherwise a compile time error in the configuration file will occur.
#define CONFIGURE_APPLICATION_EXTRA_DRIVERS |
The value of this configuration option is used to initialize the Device Driver Table.
The value of this configuration option is placed after the entries of other device driver configuration options.
See CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS for an alternative placement of application device driver initializers.
#define CONFIGURE_APPLICATION_NEEDS_ATA_DRIVER |
In case this configuration option is defined, then the ATA Driver is initialized during system initialization.
Most BSPs do not include support for an ATA Driver.
If this option is defined and the BSP does not have this device driver, then the user will get a link time error for an undefined symbol.
#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER |
In case this configuration option is defined, then the Clock Driver is initialized during system initialization.
The Clock Driver is responsible for providing a regular interrupt which invokes a clock tick directive.
,otherwise a compile time error in the configuration file will occur.
#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER |
In case this configuration option is defined, then the Console Driver is initialized during system initialization.
The Console Driver is responsible for providing the /dev/console
device file. This device is used to initialize the standard input, output, and error file descriptors.
BSPs should be constructed in a manner that allows printk() to work properly without the need for the Console Driver to be configured.
The
,configuration options are mutually exclusive.
#define CONFIGURE_APPLICATION_NEEDS_FRAME_BUFFER_DRIVER |
In case this configuration option is defined, then the Frame Buffer Driver is initialized during system initialization.
Most BSPs do not include support for a Frame Buffer Driver. This is because many boards do not include the required hardware.
#define CONFIGURE_APPLICATION_NEEDS_IDE_DRIVER |
In case this configuration option is defined, then the IDE Driver is initialized during system initialization.
Most BSPs do not include support for an IDE Driver.
#define CONFIGURE_APPLICATION_NEEDS_NULL_DRIVER |
In case this configuration option is defined, then the /dev/null
#define CONFIGURE_APPLICATION_NEEDS_RTC_DRIVER |
In case this configuration option is defined, then the Real-Time Clock Driver is initialized during system initialization.
Most BSPs do not include support for a real-time clock (RTC). This is because many boards do not include the required hardware.
If this is defined and the BSP does not have this device driver, then the user will get a link time error for an undefined symbol.
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER |
In case this configuration option is defined, then the Simple Console Driver is initialized during system initialization.
This device driver is responsible for providing the /dev/console
This device driver reads via getchark().
This device driver writes via rtems_putc().
The Termios framework is not used. There is no support to change device settings, e.g. baud, stop bits, parity, etc.
The
, andconfiguration options are mutually exclusive.
#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_TASK_CONSOLE_DRIVER |
In case this configuration option is defined, then the Simple Task Console Driver is initialized during system initialization.
This device driver writes into a write buffer. The count of characters written into the write buffer is returned. It might be less than the requested count, in case the write buffer is full. The write is non-blocking and may be called from interrupt context. A dedicated task reads from the write buffer and outputs the characters via rtems_putc(). This task runs with the least important priority. The write buffer size is 2047 characters and it is not configurable.
Use fsync( STDOUT_FILENO )
or fdatasync( STDOUT_FILENO )
to drain the write buffer.
The
#define CONFIGURE_APPLICATION_NEEDS_STUB_DRIVER |
In case this configuration option is defined, then the Stub Driver is initialized during system initialization.
#define CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER |
In case this configuration option is defined, then the Benchmark Timer Driver is initialized during system initialization.
The Benchmark Timer Driver is intended for the benchmark tests of the RTEMS Testsuite. Applications should not use this driver.
,otherwise a compile time error will occur.
#define CONFIGURE_APPLICATION_NEEDS_WATCHDOG_DRIVER |
In case this configuration option is defined, then the Watchdog Driver is initialized during system initialization.
Most BSPs do not include support for a watchdog device driver. This is because many boards do not include the required hardware.
#define CONFIGURE_APPLICATION_NEEDS_ZERO_DRIVER |
In case this configuration option is defined, then the /dev/zero
#define CONFIGURE_APPLICATION_PREREQUISITE_DRIVERS |
The value of this configuration option is placed after the entries defined by #CONFIGURE_BSP_PREREQUISITE_DRIVERS and before all other device driver configuration options.
See CONFIGURE_APPLICATION_EXTRA_DRIVERS for an alternative placement of application device driver initializers.
#define CONFIGURE_ATA_DRIVER_TASK_PRIORITY |
The value of this configuration option defines the ATA task priority.
#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING |
In case this configuration option is defined, then the machine exception to POSIX signal mapping is configured during system initialization.
This device driver is responsible for setting up a mapping from machine exceptions to POSIX signals so that applications may consume them and alter task execution as necessary.
This is especially useful for applications written in Ada or C++.
#define CONFIGURE_MAXIMUM_DRIVERS |
The value of this configuration option defines the number of device drivers.
This is computed by default, and is set to the number of statically configured device drivers configured using the following configuration options:
If the CONFIGURE_DISABLE_BSP_SETTINGS configuration option is not defined and the BSP provides #CONFIGURE_BSP_PREREQUISITE_DRIVERS, then the BSP-provided prerequisite device drivers are also taken into account.
The following constraints apply to this configuration option:
