RTEMS 6.3
Test context for spec:/rtems/ratemon/req/cancel test case. More...
struct  [struct].Map
rtems_id period_id
 This member contains a valid identifier of a period.
rtems_rate_monotonic_period_status period_status
 This member is used to receive the rtems_rate_monotonic_period_status after the action.
rtems_id id_param
 This member specifies the id parameter for the action.
rtems_status_code status
 This member contains the returned status code of the action.
void(*) do_action (void *ctx)
 This member contains the pointer to the function which executes the action.
rtems_id task_id
 This member contains the task identifier of the owner task.
rtems_id worker_id
 This member contains the task identifier of the worker task (which is not the owner task).
rtems_id original_priority
 This member contains a backup of the task priority before the execution of this test.
uint32_t postponed_jobs_count
 This member contains the number of postponed jobs before the action.
rtems_rate_monotonic_period_states previous_state
 This member contains the state before the action.
struct  Map
Field Documentation
◆ do_action
void(*) RtemsRatemonReqCancel_Context::do_action(void *ctx)
The action is either executed by the owner task or by the worker task depending on the function pointer used here. argument is a pointer to this context structure.
