RTEMS 6.3
This source file contains the implementation of _Scheduler_priority_affinity_SMP_Add_processor(), _Scheduler_priority_affinity_SMP_Ask_for_help(), _Scheduler_priority_affinity_SMP_Block(), _Scheduler_priority_affinity_SMP_Node_initialize(), _Scheduler_priority_affinity_SMP_Reconsider_help_request(), _Scheduler_priority_affinity_SMP_Remove_processor(), _Scheduler_priority_affinity_SMP_Set_affinity(), _Scheduler_priority_affinity_SMP_Unblock(), _Scheduler_priority_affinity_SMP_Update_priority(), _Scheduler_priority_affinity_SMP_Withdraw_node(), _Scheduler_priority_affinity_SMP_Make_sticky(), and _Scheduler_priority_affinity_SMP_Clean_sticky(). More...
void _Scheduler_priority_affinity_SMP_Node_initialize (const Scheduler_Control *scheduler, Scheduler_Node *node, Thread_Control *the_thread, Priority_Control priority)
 Initializes per thread scheduler information.
void _Scheduler_priority_affinity_SMP_Block (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Blocks a thread.
void _Scheduler_priority_affinity_SMP_Unblock (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Unblocks a thread.
void _Scheduler_priority_affinity_SMP_Update_priority (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
 Updates the priority of the node.
bool _Scheduler_priority_affinity_SMP_Ask_for_help (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Asks for help.
void _Scheduler_priority_affinity_SMP_Reconsider_help_request (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Reconsiders help.
void _Scheduler_priority_affinity_SMP_Withdraw_node (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node, Thread_Scheduler_state next_state)
 Withdraws node.
void _Scheduler_priority_affinity_SMP_Make_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Makes the node sticky.
void _Scheduler_priority_affinity_SMP_Clean_sticky (const Scheduler_Control *scheduler, Thread_Control *the_thread, Scheduler_Node *node)
 Cleans the sticky property from the node.
void _Scheduler_priority_affinity_SMP_Add_processor (const Scheduler_Control *scheduler, Thread_Control *idle)
 Adds idle to scheduler.
Thread_Control * _Scheduler_priority_affinity_SMP_Remove_processor (const Scheduler_Control *scheduler, Per_CPU_Control *cpu)
 Removes an idle thread from the given cpu.
void _Scheduler_priority_affinity_SMP_Yield (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node)
Status_Control _Scheduler_priority_affinity_SMP_Set_affinity (const Scheduler_Control *scheduler, Thread_Control *thread, Scheduler_Node *node_base, const Processor_mask *affinity)
 Sets affinity for the priority affinity SMP scheduler.
