RTEMS 6.3
| #define | CONFIGURE_MAXIMUM_BARRIERS |
| This configuration option is an integer define. | |
| #define | CONFIGURE_MAXIMUM_MESSAGE_QUEUES |
| #define | CONFIGURE_MAXIMUM_PARTITIONS |
| #define | CONFIGURE_MAXIMUM_PERIODS |
| #define | CONFIGURE_MAXIMUM_PORTS |
| #define | CONFIGURE_MAXIMUM_REGIONS |
| #define | CONFIGURE_MAXIMUM_SEMAPHORES |
| #define | CONFIGURE_MAXIMUM_TASKS |
| #define | CONFIGURE_MAXIMUM_TIMERS |
| #define | CONFIGURE_MAXIMUM_USER_EXTENSIONS |
| #define | CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE |
This section describes configuration options related to the Classic API.
| #define CONFIGURE_MAXIMUM_BARRIERS |
The value of this configuration option defines the maximum number of Classic API Barriers that can be concurrently active.
The following constraints apply to this configuration option:
| #define CONFIGURE_MAXIMUM_MESSAGE_QUEUES |
The value of this configuration option defines the maximum number of Classic API Message Queues that can be concurrently active.
| #define CONFIGURE_MAXIMUM_PARTITIONS |
The value of this configuration option defines the maximum number of Classic API Partitions that can be concurrently active.
| #define CONFIGURE_MAXIMUM_PERIODS |
The value of this configuration option defines the maximum number of Classic API Periods that can be concurrently active.
| #define CONFIGURE_MAXIMUM_PORTS |
The value of this configuration option defines the maximum number of Classic API Ports that can be concurrently active.
| #define CONFIGURE_MAXIMUM_REGIONS |
The value of this configuration option defines the maximum number of Classic API Regions that can be concurrently active.
| #define CONFIGURE_MAXIMUM_SEMAPHORES |
The value of this configuration option defines the maximum number of Classic API Semaphore that can be concurrently active.
This object class can be configured in unlimited allocation mode, see Unlimited Objects.
In SMP configurations, the size of a Semaphore Control Block depends on the scheduler count (see Configuration Step 3 - Scheduler Table). The semaphores using the Multiprocessor Resource Sharing Protocol (MrsP) need a ceiling priority per scheduler.
| #define CONFIGURE_MAXIMUM_TASKS |
The value of this configuration option defines the maximum number of Classic API Tasks that can be concurrently active.
The calculations for the required memory in the RTEMS Workspace for tasks assume that each task has a minimum stack size and has floating point support enabled. The configuration option CONFIGURE_EXTRA_TASK_STACKS is used to specify task stack requirements above the minimum size required.
The maximum number of POSIX threads is specified by CONFIGURE_MAXIMUM_POSIX_THREADS.
A future enhancement to <rtems/confdefs.h> could be to eliminate the assumption that all tasks have floating point enabled. This would require the addition of a new configuration parameter to specify the number of tasks which enable floating point support.
| #define CONFIGURE_MAXIMUM_TIMERS |
The value of this configuration option defines the maximum number of Classic API Timers that can be concurrently active.
| #define CONFIGURE_MAXIMUM_USER_EXTENSIONS |
The value of this configuration option defines the maximum number of Classic API User Extensions that can be concurrently active.
| #define CONFIGURE_MINIMUM_TASKS_WITH_USER_PROVIDED_STORAGE |
The value of this configuration option defines the minimum count of Classic API Tasks which are constructed by rtems_task_construct().
