RTEMS 6.3
This group contains the Interrupt Manager implementation parts specific to the ARM Generic Interrupt Controller. More...
Files | |
| file | bsps/aarch64/include/dev/irq/arm-gic-arch.h |
| This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the AArch64 architecture. | |
| file | bsps/arm/include/dev/irq/arm-gic-arch.h |
| This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the Arm architecture. | |
| file | bsps/include/dev/irq/arm-gic-irq.h |
| This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support. | |
| file | bsps/include/dev/irq/arm-gic-regs.h |
| This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) memory-mapped registers. | |
| file | bsps/include/dev/irq/arm-gic-tm27.h |
| This header file provides the TM27 support for the ARM Generic Interrupt Controller (GIC). | |
| file | bsps/include/dev/irq/arm-gic.h |
| file | bsps/include/dev/irq/arm-gicv3.h |
| This header file provides interfaces of the ARM Generic Interrupt Controller (GIC) support specific to the GICv3. | |
| file | bsps/shared/dev/irq/arm-gicv2-get-attributes.c |
| This source file contains the implementation of bsp_interrupt_get_attributes() for the GICv2. | |
| file | bsps/shared/dev/irq/arm-gicv2-zynqmp.c |
| This source file contains the implementation of bsp_interrupt_get_attributes() for the GICv2 of Xilinx Zynq UltraScale+ MPSoC and RFSoC devices. | |
| file | bsps/shared/dev/irq/arm-gicv2.c |
| This source file contains the implementation of the generic GICv2 support. | |
| file | bsps/shared/dev/irq/arm-gicv3.c |
| This source file contains the implementation of the generic GICv3 support. | |
| struct | gic_cpuif |
| struct | gic_dist |
| struct | gic_redist |
| struct | gic_sgi_ppi |
| #define | ARM_GIC_IRQ_SGI_0 0 |
| #define | ARM_GIC_IRQ_SGI_1 1 |
| #define | ARM_GIC_IRQ_SGI_2 2 |
| #define | ARM_GIC_IRQ_SGI_3 3 |
| #define | ARM_GIC_IRQ_SGI_5 5 |
| #define | ARM_GIC_IRQ_SGI_6 6 |
| #define | ARM_GIC_IRQ_SGI_7 7 |
| #define | ARM_GIC_IRQ_SGI_8 8 |
| #define | ARM_GIC_IRQ_SGI_9 9 |
| #define | ARM_GIC_IRQ_SGI_10 10 |
| #define | ARM_GIC_IRQ_SGI_11 11 |
| #define | ARM_GIC_IRQ_SGI_12 12 |
| #define | ARM_GIC_IRQ_SGI_13 13 |
| #define | ARM_GIC_IRQ_SGI_14 14 |
| #define | ARM_GIC_IRQ_SGI_15 15 |
| #define | ARM_GIC_IRQ_SGI_LAST 15 |
| #define | ARM_GIC_IRQ_PPI_LAST 31 |
| #define | ARM_GIC_DIST ((volatile gic_dist *) BSP_ARM_GIC_DIST_BASE) |
| #define | GIC_ID_TO_ONE_BIT_REG_INDEX(id) |
| #define | GIC_ID_TO_ONE_BIT_REG_BIT(id) |
| #define | GIC_ID_TO_TWO_BITS_REG_INDEX(id) |
| #define | GIC_ID_TO_TWO_BITS_REG_OFFSET(id) |
| #define | PRIORITY_DEFAULT 127 |
| #define | MPIDR_AFFINITY2(val) |
| #define | MPIDR_AFFINITY2_GET(reg) |
| #define | MPIDR_AFFINITY2_SET(reg, val) |
| #define | MPIDR_AFFINITY1(val) |
| #define | MPIDR_AFFINITY1_GET(reg) |
| #define | MPIDR_AFFINITY1_SET(reg, val) |
| #define | MPIDR_AFFINITY0(val) |
| #define | MPIDR_AFFINITY0_GET(reg) |
| #define | MPIDR_AFFINITY0_SET(reg, val) |
| #define | ICC_SGIR_AFFINITY3(val) |
| #define | ICC_SGIR_AFFINITY3_GET(reg) |
| #define | ICC_SGIR_AFFINITY3_SET(reg, val) |
| #define | ICC_SGIR_IRM BSP_BIT32(40) |
| #define | ICC_SGIR_AFFINITY2(val) |
| #define | ICC_SGIR_AFFINITY2_GET(reg) |
| #define | ICC_SGIR_AFFINITY2_SET(reg, val) |
| #define | ICC_SGIR_INTID(val) |
| #define | ICC_SGIR_INTID_GET(reg) |
| #define | ICC_SGIR_INTID_SET(reg, val) |
| #define | ICC_SGIR_AFFINITY1(val) |
| #define | ICC_SGIR_AFFINITY1_GET(reg) |
| #define | ICC_SGIR_AFFINITY1_SET(reg, val) |
| #define | ICC_SGIR_CPU_TARGET_LIST(val) |
| #define | ICC_SGIR_CPU_TARGET_LIST_GET(reg) |
| #define | ICC_SGIR_CPU_TARGET_LIST_SET(reg, val) |
| #define | ICC_IGRPEN0_EL1 "S3_0_C12_C12_6, %0" |
| #define | ICC_IGRPEN1_EL1 "S3_0_C12_C12_7, %0" |
| #define | ICC_IGRPEN1_EL3 "S3_6_C12_C12_7, %0" |
| #define | ICC_IGRPEN0 ICC_IGRPEN0_EL1 |
| #define | ICC_IGRPEN1 ICC_IGRPEN1_EL1 |
| #define | ICC_PMR "S3_0_C4_C6_0, %0" |
| #define | ICC_EOIR1 "S3_0_C12_C12_1, %0" |
| #define | ICC_SRE "S3_0_C12_C12_5, %0" |
| #define | ICC_BPR0 "S3_0_C12_C8_3, %0" |
| #define | ICC_BPR1 "S3_0_C12_C12_3, %0" |
| #define | ICC_CTLR "S3_0_C12_C12_4, %0" |
| #define | ICC_IAR1 "%0, S3_0_C12_C12_0" |
| #define | MPIDR "%0, mpidr_el1" |
| #define | MPIDR_AFFINITY3(val) |
| #define | MPIDR_AFFINITY3_GET(reg) |
| #define | MPIDR_AFFINITY3_SET(reg, val) |
| #define | ICC_SGI1 "S3_0_C12_C11_5, %0" |
| #define | WRITE64_SR(SR_NAME, VALUE) |
| #define | WRITE_SR(SR_NAME, VALUE) |
| #define | READ_SR(SR_NAME) |
Enumerations | |
| enum | gic_group { GIC_GROUP_0 , GIC_GROUP_1 } |
| enum | gic_trigger_mode { GIC_LEVEL_SENSITIVE , GIC_EDGE_TRIGGERED } |
| enum | gic_handling_model { GIC_N_TO_N , GIC_1_TO_N } |
| rtems_status_code | arm_gic_irq_set_group (rtems_vector_number vector, gic_group group) |
| rtems_status_code | arm_gic_irq_get_group (rtems_vector_number vector, gic_group *group) |
| void | arm_gic_trigger_sgi (rtems_vector_number vector, uint32_t targets) |
| #define GIC_ID_TO_ONE_BIT_REG_BIT | ( | id | ) |
| #define GIC_ID_TO_ONE_BIT_REG_INDEX | ( | id | ) |
| #define GIC_ID_TO_TWO_BITS_REG_INDEX | ( | id | ) |
| #define GIC_ID_TO_TWO_BITS_REG_OFFSET | ( | id | ) |
| #define ICC_SGIR_AFFINITY1 | ( | val | ) |
| #define ICC_SGIR_AFFINITY1_GET | ( | reg | ) |
| #define ICC_SGIR_AFFINITY1_SET | ( | reg, | |
| val ) |
| #define ICC_SGIR_AFFINITY2 | ( | val | ) |
| #define ICC_SGIR_AFFINITY2_GET | ( | reg | ) |
| #define ICC_SGIR_AFFINITY2_SET | ( | reg, | |
| val ) |
| #define ICC_SGIR_AFFINITY3 | ( | val | ) |
| #define ICC_SGIR_AFFINITY3_GET | ( | reg | ) |
| #define ICC_SGIR_AFFINITY3_SET | ( | reg, | |
| val ) |
| #define ICC_SGIR_CPU_TARGET_LIST | ( | val | ) |
| #define ICC_SGIR_CPU_TARGET_LIST_GET | ( | reg | ) |
| #define ICC_SGIR_CPU_TARGET_LIST_SET | ( | reg, | |
| val ) |
| #define ICC_SGIR_INTID | ( | val | ) |
| #define ICC_SGIR_INTID_GET | ( | reg | ) |
| #define ICC_SGIR_INTID_SET | ( | reg, | |
| val ) |
| #define MPIDR_AFFINITY0 | ( | val | ) |
| #define MPIDR_AFFINITY0_GET | ( | reg | ) |
| #define MPIDR_AFFINITY0_SET | ( | reg, | |
| val ) |
| #define MPIDR_AFFINITY1 | ( | val | ) |
| #define MPIDR_AFFINITY1_GET | ( | reg | ) |
| #define MPIDR_AFFINITY1_SET | ( | reg, | |
| val ) |
| #define MPIDR_AFFINITY2 | ( | val | ) |
| #define MPIDR_AFFINITY2_GET | ( | reg | ) |
| #define MPIDR_AFFINITY2_SET | ( | reg, | |
| val ) |
| #define MPIDR_AFFINITY3 | ( | val | ) |
| #define MPIDR_AFFINITY3_GET | ( | reg | ) |
| #define MPIDR_AFFINITY3_SET | ( | reg, | |
| val ) |
| #define READ_SR | ( | SR_NAME | ) |
| #define WRITE64_SR | ( | SR_NAME, | |
| VALUE ) |
| #define WRITE_SR | ( | SR_NAME, | |
| VALUE ) |
