RTEMS 6.3
bsp.h File Reference
Global BSP definitions. More...
#include <libcpu/powerpc-utility.h>
#include <bspopts.h>
#include <rtems/irq.h>
#include <mpc8xx.h>
#include <mpc8xx/cpm.h>
#include <mpc8xx/mmu.h>
#include <mpc8xx/console.h>
#include <bsp/vectors.h>
#include <bsp/tqm.h>
#include <bsp/default-initial-extension.h>
#define BSP_HAS_TQMMON
#define NOCACHE_MEM_SIZE   512*1024
#define PGHPLUS_SPI_ADDR_EEPROM   0
#define PGHPLUS_SPI_ADDR_DISP4   1
#define PGHPLUS_SPI_ADDR_DISP4_DATA   (PGHPLUS_SPI_ADDR_DISP4)
#define PGHPLUS_SPI_ADDR_DISP4_CTRL   (PGHPLUS_SPI_ADDR_DISP4_DATA+1)
#define PGHPLUS_PB_SPI_EEP_CE_MSK   (1<< 0)
#define PGHPLUS_PB_SPI_DISP4_RS_MSK   (1<<15)
#define PGHPLUS_PB_SPI_DISP4_CE_MSK   (1<<14)
 LINKER_SYMBOL (TopRamReserved)
 LINKER_SYMBOL (bsp_ram_start)
 LINKER_SYMBOL (bsp_ram_end)
 LINKER_SYMBOL (bsp_ram_size)
 LINKER_SYMBOL (bsp_rom_start)
 LINKER_SYMBOL (bsp_rom_end)
 LINKER_SYMBOL (bsp_rom_size)
 LINKER_SYMBOL (bsp_section_text_start)
 LINKER_SYMBOL (bsp_section_text_end)
 LINKER_SYMBOL (bsp_section_text_size)
 LINKER_SYMBOL (bsp_section_data_start)
 LINKER_SYMBOL (bsp_section_data_end)
 LINKER_SYMBOL (bsp_section_data_size)
 LINKER_SYMBOL (bsp_section_bss_start)
 LINKER_SYMBOL (bsp_section_bss_end)
 LINKER_SYMBOL (bsp_section_bss_size)
 LINKER_SYMBOL (bsp_work_area_start)
int BSP_disconnect_clock_handler (void)
int BSP_connect_clock_handler (rtems_irq_hdl)
char serial_getc (void)
int serial_tstc (void)
void serial_init (void)
int mbx8xx_console_get_configuration (void)
void _InitTQM8xx (void)
rtems_status_code bsp_register_spi (void)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
void cpu_init (void)
uint32_t BSP_bus_frequency
uint32_t bsp_clock_speed
