RTEMS 6.3
TQM8XX Board Support Package. More...
file  bsps/powerpc/tqm8xx/include/bsp.h
 Global BSP definitions.
#define BSP_HAS_TQMMON
#define NOCACHE_MEM_SIZE   512*1024
#define PGHPLUS_SPI_ADDR_EEPROM   0
#define PGHPLUS_SPI_ADDR_DISP4   1
#define PGHPLUS_SPI_ADDR_DISP4_DATA   (PGHPLUS_SPI_ADDR_DISP4)
#define PGHPLUS_SPI_ADDR_DISP4_CTRL   (PGHPLUS_SPI_ADDR_DISP4_DATA+1)
#define PGHPLUS_PB_SPI_EEP_CE_MSK   (1<< 0)
#define PGHPLUS_PB_SPI_DISP4_RS_MSK   (1<<15)
#define PGHPLUS_PB_SPI_DISP4_CE_MSK   (1<<14)
 LINKER_SYMBOL (TopRamReserved)
 LINKER_SYMBOL (bsp_ram_start)
 LINKER_SYMBOL (bsp_ram_end)
 LINKER_SYMBOL (bsp_ram_size)
 LINKER_SYMBOL (bsp_rom_start)
 LINKER_SYMBOL (bsp_rom_end)
 LINKER_SYMBOL (bsp_rom_size)
 LINKER_SYMBOL (bsp_section_text_start)
 LINKER_SYMBOL (bsp_section_text_end)
 LINKER_SYMBOL (bsp_section_text_size)
 LINKER_SYMBOL (bsp_section_data_start)
 LINKER_SYMBOL (bsp_section_data_end)
 LINKER_SYMBOL (bsp_section_data_size)
 LINKER_SYMBOL (bsp_section_bss_start)
 LINKER_SYMBOL (bsp_section_bss_end)
 LINKER_SYMBOL (bsp_section_bss_size)
 LINKER_SYMBOL (bsp_work_area_start)
int BSP_disconnect_clock_handler (void)
int BSP_connect_clock_handler (rtems_irq_hdl)
char serial_getc (void)
int serial_tstc (void)
void serial_init (void)
int mbx8xx_console_get_configuration (void)
void _InitTQM8xx (void)
rtems_status_code bsp_register_spi (void)
void * bsp_idle_thread (uintptr_t ignored)
 Optimized idle task.
void cpu_init (void)
uint32_t BSP_bus_frequency
uint32_t bsp_clock_speed
◆ bsp_idle_thread()
void * bsp_idle_thread ( uintptr_t ignored)
This idle task sets the power mode to idle. This causes the processor clock to be stopped, while on-chip peripherals remain active. Any enabled interrupt from a peripheral or an external interrupt source will cause the processor to resume execution.
To enable the idle task use the following in the system configuration:
#include <bsp.h>
#define CONFIGURE_INIT
#define CONFIGURE_IDLE_TASK_BODY bsp_idle_thread
#include <confdefs.h>
This header file evaluates the application configuration options defined by the application.
